Old 10-31-2013, 01:49 PM   #589
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by Dan@AWD View Post
It does, but what you both need to consider all aspects of the time slip.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Yup yup good times. How does it feel with that power, and care to tell me your full specs
Old 10-31-2013, 01:50 PM   #590
Dan@AWD
Drives: 2013 Argento FR-S
Originally Posted by ft_sjo View Post
I'd expect mid 12's from a 1250kg rwd car on street tyres. Infact i've experienced it and it's fairly repeatable, driver-dependant. Oh and that was only with 330bhp, not "430hp", which I assume is measured at the wheels, so ~500bhp.
It is what it is. Either the car is not very good at drag, the driver is not great, or it's not putting out as much power as claimed.
It's making the power.
Dan@AWD is offline   Reply With Quote
Old 10-31-2013, 01:58 PM   #591
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Its easy to tell by the trap speed that the car is making decent power. ET doesn't necessarily tell you anything about the power.
cruizin01 is offline   Reply With Quote
Old 10-31-2013, 02:20 PM   #592
mike the snake
Wow, 20 and 22 pounds of boost? Is this a built low compression engine?
Also I assume this is with E85 as well?
Old 10-31-2013, 02:40 PM   #593
Dan@AWD
E85 stock motor
Old 10-31-2013, 03:15 PM   #594
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
I think that was driver error. I ran a 13.4 at 112 on my street tires and I only have about 260-270 horses. for 116 ts your time is ok because our launches suck but I def think your trap speed should be a good bit higher
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
Old 10-31-2013, 03:15 PM   #595
mike the snake
WOW! Impressive. My turbo kit is going on in a week or so. I'm sentenced to 91 gas where I live, but I AM going with WMI, so I'm hoping for some decent numbers, but I doubt I'll get anywhere near 430. I'd be pleased as punch with 350.
Old 10-31-2013, 03:34 PM   #596
Dan@AWD
My best trap so far was 118.5mph.
Old 10-31-2013, 03:42 PM   #597
bgibbsunc
bgibbsunc's Avatar
Your in Dallas Correct? Which track are you going to out there? Also what size street tires are you using Im on 225 so Im sure if I threw some bigger tires on I would easily pull between a 12.9-13.2 depending on size. I just really think your Trap should be higher. I run consistently at 110-111 trap. Slick are definitely a world changer in our cars though because a hole shot is the biggest part of a pull.
San Antonio TX
Old 10-31-2013, 03:45 PM   #598
Dan@AWD
I'm in South Florida. I'm on 255/45/18. Why do you feel my my traps are low?
Old 10-31-2013, 04:03 PM   #599
bgibbsunc
bgibbsunc's Avatar
Oh crap I thought you were out of Dallas. lol I could be completely wrong but relative to what my traps it just seems like it should be higher with the difference in power and not to mention your tires should be a good helper at getting the power to the ground. Ive never seen a car with a weight of less then 3G with over 400 HP run that low of a trap. If I calculate correctly you should be running 125+. I guess I will see soon once I start running e85.
San Antonio TX
Old 10-31-2013, 05:52 PM   #600
JerryMichaels7
Drives: Whiteout FRS
your traps should be higher...with your trap speed and a guess of 3000 pounds every HP calc is saying around 350 range. Also still using 3000 pounds assuming traction and a good run should be low 11 secs at around 125ish
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 11-01-2013, 01:06 PM   #601
bgibbsunc
bgibbsunc's Avatar
Exactly my thought. When I calculate mine based off 3000 lbs and my time I get around 260 hp which is in the exact range that I guess and exactly what I get from Virtual Dyno
San Antonio TX
Old 11-04-2013, 02:41 PM   #602
SmsAlSuwaidi
Boosted
Our BRZ got dropped off at @Evasive Motorsports for the FA20club UEL 60 trim install
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 12:48 PM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 01:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 09:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 02:26 PM
