Old 05-26-2017, 06:11 PM   #617
wooly35
Drives: 2014 Scion FR-S LS3
Originally Posted by ILLSMOQ View Post
Glad they increased the size...did they have any kind of eta? Haha
"Soon"... ha ha ha ha
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
Old 05-26-2017, 08:55 PM   #618
ILLSMOQ
Drives: 2017 WR BLUE BRZ
I've read the posts, but so far, I've actually got my items sooner than expected. Only thing I'm waiting on now are those headers which I wanted bigger primaries anyway so I'm happy to hear the news Haha!
ILLSMOQ is offline   Reply With Quote
Old 05-27-2017, 12:10 AM   #619
fika84
fika84's Avatar
Originally Posted by DustinS View Post
I have not. Between 2500-3500 RPM is when it seems to come around. I still want to take the spark plugs out and check them. Took a few friends for rides last night, they couldn't really pin point anything else either. Hopefully the dyno will help a bit.
Hey Dustin.. gotta admit, haven't ready every post to know if you are using solid (or close to solid) motor mounts or not, but even on the stock motor with Cusco mounts, tranny insert and a bunch of bushings, there is some vibration that feels bad between certain RPM's.
Could yours just be normal vibration that you're feeling more in the cabin due to more solid mounting?
fika84 is offline   Reply With Quote
Old 05-30-2017, 10:43 AM   #620
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by spitfire481 View Post
Did you check the pinion angle?
I did not. I assumed that would be taken care of when Vorshlag designed the mounts. I could be wrong. Next chance I get, I will check what it is.
It is possible. I just wouldn't expect it to be as bad as it is. I really wish there was a good way to portray it on camera.
Going to see if I can somehow get diagnostics pulled up on my code reader and see if it will tell me if it reads a misfire while it's running. Also going to have the driveshaft double checked for balance.
I have confirmed that 1/4 Tank mark on Gas gauge is empty. My fuel gauge moves smoothly from Full to 1/4, nothing seems to be sticking or causing issues with the level sender. Car is getting miserable gas mileage, not something I was expecting. With as somewhat light the car is, I though at least 15mpg would be possible. I am getting more along the lines of 10.... Though I am sure it is tuned quite conservative and rich. Exhaust tips are very black now, not so easy to clean. I think getting a dyno tune/steady road tune may be worth it, except I don't want to void the warranty.
Check Engine Light is still on and I can't find a code or any reason it should be on. I had my second instance of the car going into limp mode. ABS, Traction Control, Steering malfunction lights turn on and the car beeps at me for a second. Power Steering goes into a limp mode and doesn't assist as much. Simply restarting the car fixes it.
Oil will be changed today. I was going to change the Transmission oil as well, but the local Amsoil dealer I bought from sold/delivered me the Low Viscosity High Fuel Mileage ATF -_- Working on getting it exchanged at the moment.
DustinS is offline   Reply With Quote
Old 05-30-2017, 01:05 PM   #621
MRS-Colin
Drives: 2001 Impreza 2.5 RS
Hm. Power Steering ECU will retain power steering functionality and not throw a warning if CAN communication is lost momentarily. I've never heard of a malfunction like that. Double check your wiring, especially to my IGN wire.
I might send you a tool to log your car to confirm my programming. I'll let you know.
Colin Beck
MRS-Colin is offline   Reply With Quote
Old 05-30-2017, 01:06 PM   #622
DustinS
DustinS's Avatar
Will do.
Old 05-30-2017, 01:08 PM   #623
MRS-Colin
Will do.
Also, just to entertain me, can you simulate a CEL (unplug MAP, something) and see what it does?
Colin Beck
Old 05-30-2017, 01:10 PM   #624
DustinS
DustinS's Avatar
Yes. I will do that on my lunch break and video it. I will have it ready to post when I get back.
Old 05-30-2017, 01:52 PM   #625
fika84
fika84's Avatar
Well schnikeys, if it feels like a cylinder is misfiring then it is far worse than my vibrations
Old 05-30-2017, 02:09 PM   #626
DustinS
DustinS's Avatar
@MRS-Colin
[ame="http://youtu.be/Y7mEbEgBMuY"]http://youtu.be/Y7mEbEgBMuY[/ame]
Old 05-30-2017, 03:06 PM   #627
MRS-Colin
@MRS-Colin
Working with Rick to fix this today or tomorrow! I'll either swap you modules or send you a programming and logging cable so we can further add features.
Colin Beck
Old 05-30-2017, 03:18 PM   #628
DustinS
DustinS's Avatar
One extra thing to add. I went and clicked on the option to select the car as a '13 FRS and the code reader gives a fault and kicks me back out to the menu.
Old 05-30-2017, 03:35 PM   #629
MRS-Colin
Some of those more "advanced" scanners might use some more factory like polling parameters and they might not be able to work with the system. If you use the Generic profile it should work fine.
I figured out the code issue.
[ame="https://www.youtube.com/watch?v=0IRp-fYPe3s"]BRZ/FRS MIL indication - YouTube[/ame]
Showing control over the three MIL indication modes.
Colin Beck
Old 06-02-2017, 01:00 PM   #630
DustinS
DustinS's Avatar
Sorry for the shaky filming. Quick Rev Video. Need to get a good fly by video as well. She was scared to rev it too high.
[ame="http://youtu.be/byJgKpG2Ftc"]http://youtu.be/byJgKpG2Ftc[/ame]
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
