Old 12-23-2015, 03:20 AM   #659
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I mean, I could do Intel, but that would make for a more expensive build. The A10-7850K and 7870K are APUs, which means that they have both CPU and GPU capability in one chip. Intel chips technically has GPU capability, but they absolutely fail in comparison to the Kaveri and Godavari APUs, which means I'll have to use a graphics card (no problem as I've got a GTX 650 Ti Boost that was in my main rig).
To be honest, I had a 7850K, but it seemed to have failed due to me using too much thermal paste. I still have all the parts for it, but if Intel is really that much better, then I will take it into consideration, though this will be running SteamOS exclusively and nothing else.
Ahh, I should have mentioned that this would also have been used for gaming and would have exclusively run SteamOS, as I mentioned above.
Well, if you're just replacing a CPU, I guess you can go cheap. I wouldn't expect thermal paste to kill a CPU, not anymore. Should shut the system off before the CPU fries. I think you just got good old AMD technology.
SteamOS? How many people even use that? I read it performs much worse than Windows.
As for broken CPUs with aftermarket heatsinks, well, that's the problem of the person who buys some weird-ass heatsink. That's like people who say, "I put a turbo on my car and now it done broke!"
I just keep having Intel systems stack up. If they die, it's because of something unrelated to Intel, like a dropped screw or bad solder for the Nvidia GPU.
Old 12-23-2015, 10:23 AM   #660
Originally Posted by jsimon7777 View Post
The only AMD system I ever bought was the least reliable and least compatible system I've ever owned. Considering how cheap Intel systems are, there is essentially zero reason to get an AMD system. If you're going for a phone, many other chip makers have great stuff, but for PC? Intel 100%.
Interesting experience. I've built dozens of PCs over the years, and about 50% were AMD back in the day when the price delta was just too big to ignore, and never had a single compatibility issue with an AMD. I will say that if the price delta is small though I usually buy the Intel chip.
I've also always used ATI/AMD video cards, going back to the "EGA Wonder" card.
Old 12-23-2015, 10:38 AM   #661
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
Even I feel the same. I have had two amd systems in the past and they both failed eventually. On the other hand, I still have one system running i7 990x that I got even before it got released to market around 6 years ago and its still running strong without any failure. I know intel system cost just a little more than amd, but they hold there value more than amd and lost longer than amd to justify spending little extra.
Sideways is offline   Reply With Quote
Old 12-23-2015, 12:42 PM   #662
EAGLE5
Dismember
EAGLE5's Avatar
My constantly crashing nas4free amd box is now a rock solid i3 box. I will never buy amd again.
Old 12-23-2015, 01:36 PM   #663
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
LOL wtf. Thanks for the laugh.
Originally Posted by radroach View Post
Also from a political standpoint, I don't support Intel as I think they are part of Israeli spy programs and are purposefully building in backdoors for NSA, and coding in hardware DRM, etc.
Originally Posted by humfrz
I'm old and lazy
Old 12-23-2015, 01:47 PM   #664
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
This ^^^
I'd like to know why he thinks that...
Old 12-23-2015, 01:59 PM   #665
Vladimir Tutin
Vladimir Tutin's Avatar
Drives: '13 Hot-Lava FR-S
I have a buddy that literally killed their CPU with thermal paste a month ago. But to be fair he emptied a whole tube of it onto the CPU.
Vladimir Tutin is offline   Reply With Quote
Old 12-23-2015, 02:30 PM   #666
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
also depends on the thermal paste type, kind of hard to short a chip when using a non conductive thermal paste (ceramic and others)
fumanchu1 is offline   Reply With Quote
Old 12-23-2015, 02:35 PM   #667
radroach
Drives: car
@Clipdat
@jsimon7777
@Andrew025
Let's see what we've got going on in 2015: Windows 10 = spyware botnet, NSA has backdoors in every (FCC approved) modern phone and chipset, the good majority of our computer chips, by Intel, are designed in Israel. It makes sense that one of the NSA's strategies is to embed backdoors and spying tech into these chips. It would make sense that the NSA can outsource its development of spying tech to Israel to protect itself from public scrutiny. And Israel absolutely has a stake in having a strong spying / hacking industry, see the reasoning for the stuxnet worm attack.
If you want more info, just look at what Richard Stallman - founder of GNU, and his rejection of nonfree technology. He uses some weird russian MIPS-processor laptop and custom GNU/Linux, won't even touch a windows/mac/x86 based machine because it's already compromised out of the factory. http://www.gnu.org/philosophy/can-you-trust.en.html
I hope to not jack the thread any further!
Old 12-23-2015, 04:38 PM   #668
fumanchu1
@Clipdat
@jsimon7777
@Andrew025
You should probably take off the tin foil hat and take your medication
Old 12-23-2015, 04:48 PM   #669
EAGLE5
Dismember
EAGLE5's Avatar
So, to answer my question, yes, you are paranoid much. If the government seriously wanted to watch what you're doing, having an AMD chip or some Russian MIPS wouldn't make a damned bit of difference.
@Clipdat
@jsimon7777
@Andrew025
Old 12-23-2015, 04:54 PM   #670
elBarto
elBarto's Avatar
Drives: Toyota GT86
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 12-23-2015, 05:28 PM   #671
fumanchu1
also
Old 12-24-2015, 02:29 PM   #672
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
So, Steam Winter sale. Anyone buying any more shit?
[ame="https://www.youtube.com/watch?v=thILxw6wBJE"]STEAM HOLIDAY SALE IS COMING - YouTube[/ame]
pc master race, u no have 3080
gamers lounge Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 25 01-21-2014 05:32 PM
GT Acadamy Gamers Banned from Britsh GT Pro-Am WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 16 02-11-2013 07:37 PM
