| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#6763 |
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I removed the absolutely fugly BRZ fuel door sticker and found scratches underneath. I hope they buff out.
#6764 |
Drives: 2010 MS3
#6765 |
Drives: 2013 Subaru BRZ Limited SWP
duplicolor perfect match off the clearance rack at advance auto. i think it was chrysler sand drift. i painted the lettering red with a small brush because i had just got done doing that to the 86 fender vents i swapped for.
#6766 |
Drives: 2010 MS3
Thank you. Looks really good. Not ricey at all. haha
#6767 |
Drives: 2013 BRZ Limited WRB
Tapturn! +5HP
#6768 | |
![]() Dimmest setting ![]() If you know how to solder: not much. If you don't know how to solder: just a little more than not much. It just takes some time. Total cost in LEDs is probably <$10, and that's if you get really nice LEDs. Mine were from a batch I ordered off a Chinese vendor on ebay a couple years ago to do another project. I only needed 3 for speedo, 3 for tach, and 1 each for gas and coolant temp, so 8 PLCC2 3528 LEDs total. |
#6769 | |
Perfect Sent from my iPhone using Tapatalk |
#6770 |
Drives: brz limited
so i got the chance to install a few things over the weekend
![]() added some more color under the hood, beatsonic sharkfin, grimmspeed master cylinder brace, perrin strut tower, lamin-x yellow covers |
#6771 |
Drives: 2014 BRZ World Rally Blue
STi-R clear lens upgrade.
#6772 |
Drives: 2014 SSM BRZ
@Hachiroku how hard was it to do? Been eyeballing the same setup since I miss the sharp cutoff my old cars retrofit had.
#6773 | |
#6774 |
Awesome. Can't remember if you can bake the brz housings but would love to switch to these and a phillips bulb from trs but saw we use a different type than normal
#6775 |
You can most definitely bake the BRZ headlights. They use the soft sealant.
The BRZ uses D4S bulbs and ballasts, so switching bulbs isn't as easy (D4S isn't nearly as common in the aftermarket) as with, say, the STI, which uses D2S bulbs and ballasts. |
#6776 |
Awesome. Thanks for the info. Definitely don't want to switch to aftermarket ballasts to run d2s but I'll definitely be doing the lens. The Fxr were awesome on the m3
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 01:40 PM |
| Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 11:35 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 02:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 11:19 PM |
| sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) — General Topics | 8 | 03-31-2012 09:53 AM |
