Old 05-16-2020, 11:48 PM   #69931
Ultramaroon
not playing cards
Ultramaroon's Avatar
Huh never seen that style before. Is it work w all the different thread pitch? Or they have that specific ones for it?
The typical ones have eight different pitches cut into them. I have one imperial and one metric.
If I couldn't clean it up with a good wire brush then it would have got thrown away and replaced.
Wire brushes don't get down into the thread. External threads are found plenty of places where replacement is impossible.
Ultramaroon is offline
Old 05-17-2020, 12:33 AM   #69932
soundman98
ProCrastinationConsultant
soundman98's Avatar
Not sure anyone do this, but recently when I work on my car I start using this tool on all the bolts and nuts I've taken off. It helps reduce the cross threading or for me to snap bolt in half.
Harbor freight set can be sketch with their tolerances and finish. I still have that same set for imperial stuff. I sprung for the good metric ones back fifteen years ago. No contest.
exactly what i was going to say. i've got some pre-harbor freight tap and die sets-- same quality, probably the same factory, but different name.
i've snapped a few, and de-threaded a few others, thanks to the quality.
they're not much better than for chasing threads!
looking those up now.. they'll come in handy!
soundman98 is offline
Old 05-17-2020, 12:49 AM   #69933
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Really? I went through roughly 20~25 bolts & 10~15 nuts. Not one hiccup
ichitaka05 is offline
Old 05-17-2020, 12:50 AM   #69934
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Now what could go wrong there -
Follow up with compressed air. If you don't clean them out good, and torque new head bolts, bad things can happen. I learned the hard and expensive way.
Sapphireho is offline
Old 05-17-2020, 01:16 AM   #69935
soundman98
soundman98's Avatar
cleaning threads is very different than cutting threads. i was cutting
it also helps to have a firm grasp of the thread pitch and size(which i didn't at first)... though the quality of the set i have, an official m6x1.5 is more like a 5.65x1.49 internal, and a 6.13x1.49 external...
Old 05-17-2020, 02:01 AM   #69936
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
'I'm not a thread chaser' says the guy who posts in literally all the threads.
Ok I paraphrased. And maybe not ALL the threads, just like 90%.
Spuds is offline
Old 05-17-2020, 02:10 AM   #69937
Probably fewer than 50% actually. I have my favourite subjects that I post to but many many subjects that I have zero interest in and don't even read. The truly scary part is that I have read hundreds of posts for every one I have made.
Tcoat is offline
Old 05-17-2020, 02:17 AM   #69938
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Old 05-17-2020, 02:30 AM   #69939
When you can snatch the pebble from my hand it will be time to leave this place.
Tcoat is offline
Old 05-17-2020, 02:47 AM   #69940
humfrz
Well, first off, there won't be anything (except air) in the hole left by the head bolt after you take it out. Now, if something gets in there, because someone is sloppy, if you screw a tap into the hole the tap isn't gonna bring it out - it will just smash it further into the hole.
However, I would agree with the compressed air - but just start and finish with that. Of course, if you did see yourself drop something in the hole, fish it out first.
Bubba has spoke -
humfrz is offline
Old 05-17-2020, 03:24 AM   #69941
Ultramaroon
not playing cards
Bubba has spoke -
Helicoil®
Old 05-17-2020, 03:39 AM   #69942
humfrz
Helicoil®
Well, ya, iffen you had already buggered up the hole.
But if you just dropped something in there, Bubba says just to use a tinker toy with a piece of well chewed bubble gum stuck on the end of it, to fish out the object -
Ain't it past your bed time , old man?
humfrz is offline
Old 05-17-2020, 03:46 AM   #69943
Ultramaroon
not playing cards
Yeah, but it's usually when I get my best ideas.
Old 05-17-2020, 04:02 AM   #69944
humfrz
Poor mrs Ultramaroon -
humfrz is offline
