Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
12-31-2015, 06:10 PM | #57 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (12-31-2015) |
12-31-2015, 06:11 PM | #58 |
12-31-2015, 06:18 PM | #59 |
extra what?
Yeah, I can see that. I've wanted it to work many times but I always end up grabbing the breaker bar. :/
12-31-2015, 06:30 PM | #60 |
12-31-2015, 06:37 PM | #61 |
extra what?
Maybe I just have a shitty impact wrench. I've had it apart to clean & service.
12-31-2015, 06:37 PM | #62 |
Drives: 2015 Lightning Red BRZ
If you don't have a breaker bar, a dead blow works too. Be sure to put pressure on your wrench before using the hammer though and understand this is horrible for your socket wrench.
Sent from my SGH-T999L using Tapatalk |
12-31-2015, 06:45 PM | #63 |
extra what?
Actually, I've had some luck with this. Never with a ratchet but I'll beat the hell out of a box end. Maybe 1/10 I'm in a situation where I can get a good swing. :/
12-31-2015, 06:54 PM | #64 |
12-31-2015, 07:07 PM | #65 |
I find this a useful addition to the old tool box.
POW ..... with a BFH and either it comes lose ..... or buggers it up to the point where you have to chisel it off .... humfrz |
12-31-2015, 07:11 PM | #66 |
The Following User Says Thank You to Ashikabi For This Useful Post: | Ultramaroon (12-31-2015) |
12-31-2015, 07:16 PM | #67 |
extra what?
The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (12-31-2015) |
12-31-2015, 10:24 PM | #68 |
Drives: 2013 FR-S in Asphalt
The Following User Says Thank You to Qadthane For This Useful Post: | Ultramaroon (01-01-2016) |
01-01-2016, 10:50 PM | #69 |
Turbo E85
Drives: 13 wrb brz
im happy your learning to work on your own vehicle, it saves you money and obviously give you a sense of pride you know you worked on your own car. stripping a drain bolt is uncommon but it happens to anyone. while installing my turbo kit, i admit i suck with brass fitting i can say i stripped 3 fittings and almost needed to replace my timing chain cover. luckily i had the right tool to remove the stripped fitting.
Flex Fuel Turbo BRZ
01-02-2016, 09:42 PM | #70 | |
Drives: 2013 Subaru BRZ Premium
Tags |
damage, oil change |
Similar Threads | ||||
FR-Sandwhich: Total or not total? | Joshwahhhs | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 10-03-2015 08:11 PM |
Looking for a set of OEM BRZ DRL Strips | s0sl0w | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 04-13-2015 09:18 PM |
What headlights to pair with LED strips? | l0aded | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 06-24-2014 04:37 PM |
Rubber Strips on the top of the car | zackcp04 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 05-31-2014 10:44 PM |
RGB LED strips help | BadLuckZN6 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-21-2014 01:21 PM |
