Old 06-06-2018, 07:07 PM   #57
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
MOAR WEIGHT REDUCTION TODAY
Installed the front WRX Wilwood kit today
Stock front rotor/pads/Caliper/Bolts = 32.25lbs per side
Wilwood Kit rotors/pads/caliper/bolts = 17.25lbs per side
Total Weight Reduction today = 30lbs !!!!!!
Installed wheels are still dirty
New Weight after AC delete and Wilwood Brakes = 2545lbs !!
SuperTom is offline   Reply With Quote
Old 06-07-2018, 02:49 PM   #58
SuperTom
SuperTom's Avatar
weight Reduction Thursdays
Saved some more weight today!!
Door Speakers , Not a huge sound person but am keeping dash and rear speakers = 4.75lbs
Some Bracket/shield (no heat from exhaust on that side) rear driver firewall .75lbs
Lighted up my battery cradle .75lbs
Total Loss today 6.25lbs of MASS!!!
New weight = 2538.75
Lightweight bucket seats next! Should get me to 2500lbs
Old 06-08-2018, 12:13 PM   #59
SuperTom
SuperTom's Avatar
no weight reduction today may have added a few ounces Loden Black Chrome Emblem. Feels like solid metal. They sent me the wrong one for the rear so I'm waiting on a reply from them
Old 07-08-2018, 03:49 PM   #60
SuperTom
SuperTom's Avatar
Knocked out two interior projects today.
Wrapped my Climate controls in Alcantara
Write up here
http://www.ft86club.com/forums/showthread.php?t=128825
Covered up the Fasteners on my rear seat delete with a strip and TRD badge
Write up here
http://www.ft86club.com/forums/showthread.php?t=121565
Old 07-08-2018, 09:36 PM   #61
mrg666
pessimistic skeptic
mrg666's Avatar
You have the WRX Wilwood front brake kit, right? Are you happy with it? How is it working with stock rear brakes? Too much dust?
Do you know anything about the following kit?
https://www.rr-racing.com/v/mobile/p...tid=gt86fbk005
Old 07-08-2018, 09:56 PM   #62
SuperTom
SuperTom's Avatar
So far really loving the WRX brake kit . It comes with BP10 pads which aren't over aggressive and don't have any dust. On my C5 I have BP30 fr and BP10 rear and the fronts have terrible amount of dust.
It looks like you are supercharged so I don't recommend this kit for a heavier high powered car. I would go with the Specific Wilwood kit. Those RR brakes look decent too
My setup is really because I'm down to ~2500lbs and wanted a lightweight brake kit that gave a bump in performance. Its basically a Stock + kit that improves driving response (-30lbs unsprung front weight loss)
Old 07-09-2018, 05:16 AM   #63
mrg666
pessimistic skeptic
mrg666's Avatar
Thanks! I have JRSC and it adds only 30 lbs. My lighter exhaust and wheels have already saved about that much. So my car is not heavier than stock. If the brakes save extra 30 lbs, it will be lighter actually. RR kit seem to be heavier than the WRX kit since they specify as saving only 4 lbs per corner. I think I will go with WRX kit.
Old 07-09-2018, 07:39 AM   #64
SuperTom
SuperTom's Avatar
Yeah but you don't understand this kit has rotors that are thinner than stock. The first guy to use them was named Swift(something) he was supercharged. He said they were ok at first but with that much extra power needed something more.
If I went FI I would be going with a Bigger Brakes, wheels/tires, clutch ect
Old 07-09-2018, 08:01 AM   #65
new2subaru
Weight Weenie
Drives: 15 FR-S
@mrg666
I think the WRX kit would be fine if you're not tracking it. If you are I'd look at something else.
This kit is very durable and drops 10lbs a corner.
http://www.ft86club.com/forums/showthread.php?t=94608
Old 07-09-2018, 08:18 AM   #66
new2subaru
Weight Weenie
Drives: 15 FR-S
Tom, what size wheels and tires are you using with the WRX kit?
I wonder if 16" wheels will fit over them.
Old 07-09-2018, 08:36 AM   #67
SuperTom
SuperTom's Avatar
I have 17x8 konig hypergrams
16s will fit. on the website they say 15's may even fit
https://www.wilwood.com/BrakeKits/Br...temno=140-9193
Old 07-09-2018, 10:28 AM   #68
DaSilva3525
Drives: 2013 Brz
Nice work man! Car is looking great. I am a weight reduction nut as well. Do you have the part number for that wrx wildwood kit? I'm all about the smaller / thinner rotors.. It's not the same thing but I have Strange Drag brakes on my Stang and it was a huge difference overall.
DaSilva3525 is offline   Reply With Quote
Old 07-09-2018, 11:33 AM   #69
SuperTom
SuperTom's Avatar
Thanks!
Its only really 1mm thinner than stock. I just don't want a 300hp FI person thinking its going to be significantly better than stock. Its meant to be 30lbs lighter while giving equal to slightly better performance.
The link above is for the stock WRX kit.
The only thing extra is the different caliper mounting bolts. Wilwood part #230-10425
Or you can buy the whole kit from ft86speedfactory with the bolts. http://www.ft86speedfactory.com/wilw...l#.W0NxUmcUnX4
Old 07-09-2018, 12:13 PM   #70
DaSilva3525
Drives: 2013 Brz
Thanks!
Thanks for the details, I musta been blind earlier to miss that link
My car will be down to 2350-2400 so more then enough
mothespaceman: 14' Satin White BRZ Build! mothespaceman Member's Car Journals 25 09-19-2014 06:30 PM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 03:04 PM
white trd 2013 build Pcharliep04 Member's Car Journals 0 04-24-2014 02:25 AM
Build-thread White Wasp FR-S by Mit_Peid mit_peid Member's Car Journals 7 01-05-2014 08:47 PM
White GT manual Jan Build availlable 86•BRZ AUSTRALIA 2 01-02-2013 12:45 AM
