#57 |
Anti stance.
Sure, but this is one the best, most even flowing factory manifolds I’ve ever flow benched.
#58 |
Drives: 2014 frs
#59 |
The Fail Boat
Drives: CWP S.B.
What kind Apples to oranges are you talking about to ruin a thread?
Why is ITB on NA cars a strange things? tell that to BMWs? IT's just good for some ppl's build, FI or not. Not everything is about right or wrong, this is not stupid politics, just drop it. |
#60 |
Human
Drives: 2015 BRZ Black
Is it weird i keep coming back to this thread just to see how much this argument has progressed?
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
#61 | |
Anti stance.
Comparing two completely different engines, one with boost and one NA, as some type of justification is stupid. |
#62 |
Drives: 2017 BRZ
Why all the focus on ITB's when a plenum is being added? That and the new runners will have a bigger effect on power.
#63 |
Only users lose drugs.
Drives: All the time
BMW obviously doesn't know what they're doing by putting ITBs on hugely successful STREET motors like the S14, M88/S38, S50, S54, S62, S85, etc. Or Ford with any of their Cosworth offerings. Or is the argument now simply going to be that a forced induction motor was referenced earlier? I seriously doubt the RB26 was referenced as a comparable motor to the FA20; only that ITBs were quite successfully used on it as a road-going motor. If that's the case, then there's really no point comparing ANY motor with another unless they are 100% identical, which is really pretty pointless.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#64 | |
Anti stance.
Make an apples to apples comparison or don’t bother. Post some gains made on an NA Honda from going ITB. That could actually be useful info. |
#65 |
I bet BMW and Ford have plenty. Are you suggesting that removing the ITBs and going with a single TB would have no effect on power output or delivery? Or even more absurd, would IMPROVE either? I'm sure that data is readily available (in fact, you can't Google 'Honda' and 'ITB' and not find tons of info), but then we'd be comparing apples to oranges, according to you...
#66 |
Anti stance.
Edited.
#67 | ||
LMGTFY
Drives: 13 FRS, 91 Miata
#68 |
Only in that the RB26 operates in the same rpm range as ours, meaning ITBs are not some sort of component reserved for super high rpm motors. Likewise, the M88/S38 motors only make peak power in the mid 6000rpm range, but still use ITBs.
#69 |
Typical ITB results on a NA S2000.
#70 |
Anti stance.
| Part throttle faster than full throttle | brn12345 | Engine, Exhaust, Transmission | 38 | 10-21-2021 01:20 PM |
| SARD CF Intake Pipe, SARD Oil Catch Can, TRD Oil Cap, Rad Cap, Battery Clamp | Trojan_SC | Engine, Exhaust, Bolt-Ons | 19 | 03-28-2018 08:52 PM |
| Bad news good news | ls1ac | BRZ First-Gen (2012+) — General Topics | 2 | 10-01-2016 10:11 PM |
| SARD 86 GT1 Body Kit + SARD LSR Wing | nigel-jdmparts | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 04-27-2015 01:41 PM |
