#57 |
Those results only make me more excited to finish my own testing!
#58 |
Drives: 2017 86 860 Special Edition
144whp sounds pretty low to me for a stock kouki motor. Most i've seen are at around 170. Might be heart break dyno. 60 over 170 puts it at around 230whp before any head work or cams. That's very impressive.
Also that torque number is totally believable, a healthy bump is well within the benefits of a ITB's. I do wonder why power and torque start to taper at ~6800. What's restricting it? Cams? Head flow? Runner length? |
#59 | |
These trumpets are on the smaller end for our displacement, so I would expect to see a healthy midrange boost, that chokes up top. |
#60 |
#61 | |
Drives: 14' Raven M/T - 02' is300
#62 | |
I know to calculate second and third harmonic pulses you need to account for runner length which is bell mouth to the valve seat. I’m not completely sure about the fa20/boxer motors but Honda and Toyota runners in the head portion were pretty short so to boost mid/low range power you had to run decently long stacks. |
#63 |
Drives: 2013 FR-S, 2016 Miata Club
Kinda like how BPB lengthen the intake to shift power lower.
#64 |
Length =/= diameter. I'm referring to diameter!
#65 |
Drives: Whiteout FRS
If I am correct, on one of his IG post, I think he did mention it was a new dyno that they used when tuning the ITB's where as the stock numbers were on the old dyno. Can't be too sure that the gains are that accurate imo.
#66 |
Drives: 2014 GT86
No biggie, it's normal for forum members to draw conclusions from different dynos numbers without baseline
#67 |
Drives: 2015 BRZ Limited
This looks exciting! It's fun to see a car actually running these NA. They sound FANTASTIC. I'm interested to hear how they feel, regardless of power. I hope they get their forum user working, we need answers!
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
#68 |
Only happy when it rains.
Drives: series.blue
#69 |
Drives: 2014 GT86
At very least having stock baseline is single biggest variable elimination to roughly/remotely add some comparison ground to compare relative gains against it, instead of marking all of dyno results out there as completely unusuable. Reducing differences between eg. +/-30% to eg. +/-5to10%. "Better then nothing".
#70 |
Wes
I commented on his post on IG and he said the most expensive part was the Motec. He mentioned that the price for the build was as much as a top end turbo kit or even a swap. But then again, he's planning to use it as a track car only. If I got this upgrade, I would need to know that the car would still be driveable in the winter
Instagram: @gt86ws
| In for the long haul Ultimate NA build thread. | celek | Engine, Exhaust, Transmission | 669 | 06-07-2020 07:26 PM |
| TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL | Andrew666 | AUSTRALIA | 8 | 11-19-2018 05:24 AM |
| RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** | RallySport Direct | Transmission and Driveline | 92 | 09-01-2015 01:17 PM |
| RallySport Direct's Ultimate Interior Thread! | RallySport Direct | Interior Parts (Incl. Lighting) | 45 | 03-25-2015 02:12 PM |
| Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! | THMotorsports.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-11-2013 06:25 PM |
