Old 09-07-2012, 05:28 PM   #57
denverizzles
what do you mean by more poke/suck?
denverizzles is offline   Reply With Quote
Old 09-07-2012, 05:38 PM   #58
gmookher
Originally Posted by JoeBoxer View Post
I would probably go with 8.5 +38 front and 9.5 +38 rear, many others have and it fits well I don't see any reason to go more aggressive but i'm sure its possible with some negative camber and slightly stretched tires.
Stretched tires are all the fad but not kosher.
gmookher is offline   Reply With Quote
Old 09-07-2012, 07:47 PM   #59
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
Can some one give me some insight if 18x9.5 +45 will fit in the front??
Really appreciated!
shu5892001 is offline   Reply With Quote
Old 09-08-2012, 03:11 AM   #60
Zadkiel
Drives: CBS BRZ Limited 6MT
17x8 +35 on stock tire?
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Old 09-08-2012, 03:13 AM   #61
Zadkiel
Wether the offset will cause the tire to "poke" out of the wheel well more or "suck" it in further.
Old 09-08-2012, 04:13 AM   #62
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Really appreciated!
I believe you will rub on the strut/coil.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 09-08-2012, 04:13 AM   #63
ill86
ill86's Avatar
Drives: iG FR-S
That will work fine.
Old 09-08-2012, 10:06 PM   #64
Zadkiel
http://www.discounttiredirect.com/di...7.5&vid=022416
DR-34s 17x7.5 on stock tire with either a 42 or 45mm offset
Old 09-10-2012, 07:43 AM   #65
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Will someone confirm if the following will fit? Looking for function over aesthetics even with limiting myself to street driving
Ive seen some people do 235s on 8" wheels; wanted to see if 245s will work too. From my estimation the below will still clock in slightly below OEM tire/wheel weight. Although I see 235s weighing up to 2lb less, 235/40R17 is just not a common size.
* Stock suspension. Coil overs to lower are an option around 60k miles or so when my stock suspension wears out.
* stock engine. No plans ever to mod engine for power
* stock brakes. Pads and brake lines will be replaced later
* Weds Tc105n 17x8 +42 square setup
* 245/40R17 tires, probably the hankook Venus v12 Evo K110 (a mouthful) or dunlop star spec
* Hub centric rings
Another question, does tire rack list tire weights with air or is it just material?
F1point4 is offline   Reply With Quote
Old 09-10-2012, 07:46 AM   #66
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
* Hub centric rings
I wouldn't run a 245 on an 8" wheel, the tire will actually look what they call pinched and it will adversely affect handling. Just go with a 225/45R17 on the 17x8 wheel especially since you don't plan on engine mods. I would recommend the Continental DW the price is right and they are 5 pounds less per tire than Star Spec's.
JoeBoxer is offline   Reply With Quote
Old 09-10-2012, 08:00 AM   #67
ill86
ill86's Avatar
Drives: iG FR-S
245/40 on an 8 works fine... I've been running this setup since i bought the car. Street and circuit use... It does NOT adversely affect handling.. Grip levels are wonderful. Still nimble.
225 or 235 is ideal on an 8. 215 & 245 will also work fine.
Old 09-10-2012, 08:07 AM   #68
JoeBoxer
JoeBoxer's Avatar
I would think it would cause the sidewalls to be pretty flexible and "roll over" during hard cornering but if you say thats not the case I will agree. No problem admitting it when i'm wrong lol.
Old 09-10-2012, 08:13 AM   #69
ill86
ill86's Avatar
Drives: iG FR-S
I wouldn't say your wrong .. Just maybe a difference of opinion/preference.
But, no, it doesn't roll over. :happy0180: ultimately depends on tire selection.
Old 09-10-2012, 05:18 PM   #70
Zadkiel
What size tire do you guys recommend for a 17x7.5 wheel with a 42 or 45mm offset? Any brands?
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
