Old 10-03-2014, 06:53 PM   #57
Hawk77FT
Drives: GTS 86
Got mine ordered as well.
Hawk77FT is offline   Reply With Quote
Old 10-03-2014, 07:28 PM   #58
cmdboy_347
Drives: '13 FR-S, '12 CBR1000RR, 10 Cayenne
Just placed an order too!
'13 FR-S Blue (Daily Driver)
'12 CBR1000RR (Weekend toy)
'10 Porsche Cayenne S (EVOMSit tune)- Hauling toys
'10 BMW 550i (Burger Tuning) - church & late dinner car
'10 BMW 335i FBO (Sold) and many other cars....
cmdboy_347 is offline   Reply With Quote
Old 10-07-2014, 11:13 AM   #59
BRZ NA
Drives: WR blue
If u guys can help plz,since the oil filter is on top so No oil leak out,I don't need to wait until oil change to install oil cooler right?and do u need to put more oil every time or Just one time? Thx
BRZ NA is offline   Reply With Quote
Old 10-07-2014, 09:49 PM   #60
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
No extra oil required.
Old 10-07-2014, 09:54 PM   #61
Wayno
Wayno's Avatar
Here's a closer comparison. Exact same road but quicker time on second run due to alignment settings.
Before - 255F/124C
http://datazap.me/u/wayne/206-stg2-u...g=0&data=1-8-9
After - 240F/116C
http://datazap.me/u/wayne/206-stg2-u...=0&data=1-9-10
As we already knew, it's more useful as an oil warmer so good for a daily driver and autoX.
For track cooling an air cooler is much, much better (by a further 20F/11C).
Old 10-12-2014, 02:24 PM   #62
EZx2
Drives:
Before - 255F/124C
After - 240F/116C
Hi, good to hear from you,
..what tips can you share about installation?
In the kit, we got 2 hoses; one short, second- longer,
1. What route should they get?(a. short in, longer out? b. does it matter which one 2connect 2upper or lower water plug under throttle?)
2. What is the "patent" 2save water, when changing hoses?
Thanks!
EZx2 is offline   Reply With Quote
Old 10-14-2014, 07:46 AM   #63
EZx2
Drives:
..ok, so, anwers for my Q.by myself :
before installation open the water plug(in order to reduce pressure in the system).
Start changing with lower (under throttle 'nose'), route it to the angled out in the oil cooler. You should do it as quick as possible, in order to prevent loosong water. Prepare clamp for tightening, because hose is a bit bigger, than 'nose' under throttle (on the oil cooler it fits good though).
The upper nose under throttle should not leak at all, so changing it just a pleasure.
Hope it helps.
Old 10-14-2014, 01:53 PM   #64
EZx2
Drives:
Old 10-14-2014, 01:56 PM   #65
EZx2
Drives:
Old 11-11-2014, 06:22 PM   #66
Jyukai
Drives: scion FR-S MT
Hope it helps.
so the lower port is the one for coolant coming out from the engine into the cooler? the upper one for coolant coming back from the cooler into engine?
Jyukai is offline   Reply With Quote
Old 11-11-2014, 07:28 PM   #67
keen as
keen as's Avatar
Drives: 86 GT MT
It doesn't matter which way you connect the coolant hoses to the oil cooler. It will work the same either way.
keen as is offline   Reply With Quote
Old 11-11-2014, 08:50 PM   #68
Wayno
Wayno's Avatar
Technically:
The angled (1/2") port on the cooler is IN on the OEM installation.
The straight (3/8") port on the cooler is OUT on the OEM installation.
The lower (3/8") port on the engine is IN to the return line that goes to the radiator.
The upper (1/4") port on the TB is OUT of the TB.
Doesn't matter because there's bugger all coolant going through it anyway because of the 1/4" hole.
Old 11-12-2014, 01:20 PM   #69
Jyukai
Thank you very much!!
Old 01-17-2015, 01:35 AM   #70
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
Completed the install couple of week ago.
GT86drifter is offline   Reply With Quote
oil, oil cooler, oil temp, temperature
The need for an oil cooler when going FI (Temperature Data Inside) spdbydesign Forced Induction 145 11-05-2015 01:02 PM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 06:49 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 11:19 AM
Perrin oil cooler real world review. Impressions. Racecomp Engineering Engine, Exhaust, Transmission 40 03-18-2013 03:31 PM
