#715 | |
Drives: 2023 WRB BRZ (MT)
#716 |
Finished, sort of...
So I got my foglights installed and I think they look great so thanks Nigel JDM
![]() ![]() But they only worked for around 2 days and now I can't figure out what went bad... Did I mess up my wireing? The switches positive tap: ![]() The switches negative tap: ![]() The harness's positive tap (on battery near top of pic) and negative tap (on fuse box bolt) ![]() I think my relay may be blown, but I replaced it and when I flipped the switch I think I heard some sort of electrical zap type noise but the lights still don't work. I also didn't have the signal wire from the interior properly insulated in one spot and it may have grounded out. Could that cause the relay to blow? Thanks for the help ahead of time... |
#717 |
#1362
Drives: 2014 Ice Silver WRX
my nigeljdm harness fuse blew the other day. i think water got in to the little plastic box. quick fix but yea just a heads up if you find your fogs not working one day.
edit: @bfsnail
#718 |
The fuse still looks fine so no problems with that
#719 | |
Drives: 2013 scion frs blue
Where did you get that flush sitting fog light switch? |
#720 |
The switch came with the Nigel JDM kit and I got the bezel from the dealership for like 10 bucks
#721 |
#722 |
#723 | |
Thanks!!! |
#724 | |
#1362
so i linked your post with your issue to a friend who knows much more about this stuff than i do and this is what he told me to tell you:
firstly he made this which is i'm guessing how we (he) wired mine up: ![]() this is prob handy for anyone else still looking to diy these fogs then he said this (copied and pasted from google hangouts): Quote:
#725 |
Awesome thanks! I'll give this a try tomorrow
#726 |
Drives: White 2013 Scion FR-S
how much for just only the fog light lamps?
#727 | ||
Drives: 86
So even our option 1 Fog Light Kit will be exactly the same as the Scion Fog Light Kit. Thanks for the link! We can now put this info for our customer, if they want to save some money and go with the button option. Thank you NJP |
| FR-S smoked tail lights and reverse lights | jjdrivesajazz | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 02-21-2013 09:38 PM |
| FINALLY - Got my FR-S | SkitterSkotter | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 08-03-2012 06:16 PM |
| FINALLY GOT IT! | Ayaz2589 | NY / NJ / CT / PA | 8 | 07-28-2012 03:52 AM |
| Finally got it!! | percyng | CANADA | 21 | 06-17-2012 02:50 AM |
| Fog lights on with parking/running lights possible? | BMWDavid | BRZ First-Gen (2012+) — General Topics | 1 | 06-16-2012 08:29 PM |
