#7379 |
Drives: Scion FR-S A/T, Whiteout
So on the topic of running lean, I've noticed that every time I hit boost, my AFR consistently reads > 1 point higher than my commanded AFR. I know it's been mentioned that the transition from closed to open loop takes some time, but wouldn't the ECU still be targeting closed loop AFR if it hadn't yet transitioned?
Check out this log to see what I'm talking about: http://datazap.me/u/pantsdants/9-7-t...2058&mark=2020 This is running on 92 octane, OFH + Nameless OP/FP, with the OpenFlash ESC 91 tune. I plan to have my exhaust checked for leaks when I get my catback installed this week, just to rule out leaking in front of the O2 sensors. Failing that, what would be causing this discrepancy? I'm fairly certain this is contributing to the FLKC you can also see in the log. If it can be attributed to this closed to open loop transition, how do I minimize that? One thing I've already tried is modifying the closed loop AFR compensation tables to target 12.0 in the boost load ranges, but that had zero effect. Any insight would be appreciated! |
#7381 |
FRS610
This has probably been asked already , can I install the TRD air box and plug it in the supercharger will it need any mods?
#7382 |
Time Traveller
You'll need to use the stock airbox as the Phantom compressor attaches directly to it. Get a drop-in filter if you want to make sure you have the least restriction at the airbox. TRD makes one, but really, even this is not required. The kit is plug and play with a stock car so you'll be good to go.
#7383 | |
PhoneFlash by EcuTeK
Being these cars were designed around NA applications, I am sure they did not think about how to transition between no boost and boost. In EcuTeK we have created a couple custom maps to relieve this problem, though it was definitely and art to get them to work as we want. Cheers, William Knose Delicious Tuning |
#7384 | |
FRS610
#7385 | |
Drives: Passat
Here is a great baseline for VR46. 2013 FRS AT Blue: Borla UEL, Tsudo catted front pipe, stock cat-back, 93, no tune. Red: Borla UEL, Tsudo catted front pipe, stock cat-back, 93 with Visconti stage 2 tune. It's exactly like his car except for the E85 and ESC.
#7386 |
Drives: 2013 Scion FR-S, Nissan Pathfinder
IMO a great baseline would be one from the same car, on the same dyno, plus-minus the mods you are trying to compare. Not directing this at you, through out this entire forum so many ppl compare dyno's from different cars from different locations, and its realistically inaccurate.
#7387 | |
#7388 |
#7389 |
Drives: Passat
Even in this glass house?
So maybe it isn't "realistically accurate" to compare the highest ever Phantom dyno results, obtained after hours of custom tuning, to low-end, canned-tune Innovate stage 1 results from a different car on a different dyno in different weather and make assumptions based on this inaccurate comparison? I could agree with that. Last edited by Fast_Freddy; 09-10-2014 at 05:31 AM. |
#7390 | |
Drives: 2013 FRS
#7391 | |
The main difference between the dynos in my opinion is the fact they are different brands. Dyno dynamics read low...very similar to mustangs. On a dyno dynamics I got 167hp with ecutek stage 1. Other cars were getting 155 to 160 stock.... And theses were MTs. Its pretty easy for a AT to get ten HP less that a MT....I figure in ptunings dyno a AT would get around 150hp....still looking for proof on that one though. As far as my highest results....I'm running the same tune of everyone else....and shivs OTS tune is stronger than the custom tune that I got from BRZedit. Looking forward to @Shiv@Openflash to try out the new tq300 that I have. Double the boost at redline makes a big difference when it's non parasitic. |
#7392 |
Drives: White BRZ
bypass for the track
I will be running a road course track event at Buttonwillow Raceway (central CA) in a few weeks and want to temporarily bypass the system for the weekend. I don't want to push the charging hardware limit and want consistent laps. I was going to just substitute my Perin inlet tube back in, and reflash back to stock. Do I need to change or reverse anything else to keep it running healthy. Can all the battery stuff and wiring stay in place for the ride as long as the switch is off?
I will also have unleaded race gas available and was wondering if anyone had run any of the other "stock" tunes that come with the OFT device and had any recommendations. |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
