Old 11-24-2016, 07:29 AM   #7659
nmastereal
Originally Posted by Kodename47 View Post
It's fairly common practice, just about everything is grounded to the engine or chassis and therefore it will be designed as such. If there was an additional wire it would just be connected to one of those so cut out the unnecessary and bolt it direct. Saves on costs of additional wiring.
Welp, now i know.
nmastereal is offline   Reply With Quote
Old 11-25-2016, 03:30 PM   #7660
xjohnx
Grip>Slip
xjohnx's Avatar
Anyone tried the Grams 72mm throttle body with the 210 yet?
Old 11-28-2016, 03:43 AM   #7661
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
I'm looking into maybe getting an Innovate Stage 2 (intercooled) system, and likely having it dyno tuned somewhere reputable/experienced from the start... But I'd like to know what you (experienced owners) would say the top three supporting mods are, and what fluid is best for the air/water cooler (i.e. water and what additives). Any input is appreciated, it's a matter of me saving up and deciding between an Innovative Stage 2 or a Jackson Racing system. The car will be autocrossed fairly regularly (mostly second gear stuff) and I *may* start track duty next season.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 11-28-2016, 08:13 AM   #7662
sam69
Drives: GT 86
I have had the intercooled 210 for 40,000 odd KM now and have not been nice to it in any way shape or form (have a spare motor) and so far the only issue I've had is one belt and I have to top the oil in the SC up every now and then.
Have run the 69mm pulley from day one and the redline cut out is set to 7800 rpm .
Best addition so far is a set of TOG EL bigger bore headers and 2.5" full Perrin exhaust which bought it to life and an oil cooler to keep temps in check .
sam69 is offline   Reply With Quote
Old 11-28-2016, 01:30 PM   #7663
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Top 3 mods to get with the supercharger would be:
1. An oil cooler if you plan on doing any type of racing, but no need it you'll just be doing street driving. If only street driving then a higher flow air filter or new intake system like the Moto-East or Perrin.
2. Temperature sensor in the MAP plate to get an accurate temp reading so it can be tuned to it's potential.
3. Full 2.5 exhaust.
4. (Adding a fourth) Get a 70mm or 69mm pulley to maximize the supercharger with either the next size down in the standard belt or the Gates blue racing belt the same size as standard.
*For fluids just use 50/50 antifreeze that your car uses.
I'd recommend taking it to Moto-East as that's were my tune it from and it's been working well.
If I were to buy a kit new (I got mine used for $1300 cheaper), I'd buy an Edlebrock instead of the ones you listed, mainly because of the expand-ability and cooling potential. The Sprintex runs hot even with the intercooler when racing.
stockysnail is offline   Reply With Quote
Old 11-28-2016, 06:36 PM   #7664
Keenercarguy
Mountain Runner
What about heat soak? Has anyone done lots of back to back testing? I know an oil cooler would help (and I intend to run a 72.5mm pulley, maybeeee a 70mm) but I'm trying to cover my bases
Old 11-28-2016, 07:13 PM   #7665
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
To throw a thought out there (having run the non-intercooled 210 for 2000 miles now): I bought my 210 unit used for $2000, and was out the door all said and done for $2250 (the price of ecutek license was offset by sale of my open flash tablet). I did the install myself (fairly easy). For the money i'd definitely do it all again. You can get an intercooled setup for $2500-3000 used for sure. That'll put you about $1000 cheaper than jackson racing before tune. If money isn't a big concern than $1000 may not matter.
For the track and for those who rev higher on the street the Jackson Racing is a better package -- but for autocross and street driving I think the 210 is great.
ajcarson11 is offline   Reply With Quote
Old 11-28-2016, 07:15 PM   #7666
ajcarson11
Personally, I can't say i've really experienced any obvious heat soak. But I also live in Indiana where we don't see temps above 80deg for more than about 2 months out of the year. I'm running a 72.5mm pulley, on moto-east tune, non-intercooled.
Old 11-29-2016, 02:28 AM   #7667
8686
8686's Avatar
Drives: 86
I was thinking about it but my tuner says it will not do anything as the stock 65 mm TB is more than enough
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 11-29-2016, 05:47 AM   #7668
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
That's the irony behind people getting bigger intakes. They're still restricted by the 2.5in throttle body anyway.
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 12-03-2016, 03:44 PM   #7669
jwvand02
Drives: 2013 SWP BRZ Limited
To me, the biggest mod to do with this kit is run E85. I understand that some of us are unfortunate and don't have access, but if you do it's worth it. With this kit and E85 the car is about as fast as it has any business being.
jwvand02 is offline   Reply With Quote
Old 12-03-2016, 03:44 PM   #7670
jwvand02
Originally Posted by ajcarson11 View Post
Fellas it honestly took me 40 seconds to find the bolt, reach down and screw the bolt in. It took me longer to find my 10mm socket. Instant relief.
yeah, I lost that bolt when I was installing my kit too. It threw lots of fuel CEL codes and stalled randomly until I fixed it.
Old 12-07-2016, 01:35 AM   #7671
riboyster
riboyster's Avatar
Does a tighter belt make a big difference? Is there a lot of slippage with the 69mm?
Old 12-08-2016, 02:05 AM   #7672
riboyster
riboyster's Avatar
Hearing a strange fluttering sound at mid/high boost from 3rd gear and up. I'm not sure if I've just picked up on it, or if it just started last week. Anyone else hear strange things like this?
Only started noticing it a few days after I smoked a centrifugally charged frs with the 69mm. Also worth noting that I can only hear it with the windows down - nothing out of the ordinary in the cab noise. Maybe my oil is aging and some valve noise is happening?
Any ideas?
@PitViper
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
