Old 04-21-2016, 12:16 AM   #771
Hawk77FT
Drives: GTS 86
Originally Posted by Calum View Post
I'm torn between installing mine at home or taking it to my favorite a shop just to see the reactions.
Easy install at home! If you lift the engine 1-1.5" that over pipe will fit in just nice!
Hawk77FT is offline   Reply With Quote
Old 04-21-2016, 10:26 AM   #772
retrofit
Drives: Toyota 86
@AceHeader-MT
Are there any plans for a 4-2-1 header similar to the CS400 but with larger collectors?
I'm interested in the 4-1 Anaconda headers with 44mm collectors as you've recommended them for supercharged builds >300hp. At the same time I want a 4-2-1 design for more low end torque. Of course it would be nice if there was a model that caters for both high hp forced induction and low end torque.
One more question about the 300hp figure quoted here:
https://www.ft86club.com/forums/showthread.php?p=2564247
Is that hp figure at the crank or wheels?
retrofit is offline   Reply With Quote
Old 04-21-2016, 11:37 AM   #773
Originally Posted by retrofit View Post
@AceHeader-MT
More top end power and low end torque? The proper answer, IMO, is larger supercharger. Fortunately you guys have the nice folks at Harrop available...
Old 04-21-2016, 09:05 PM   #774
Hawk77FT
Drives: GTS 86
@AceHeader-MT
Due to its construction I think CS400 is better suited for SC, (low end torque) as the header is designed to extract the gases at very high velocity. Shorter secondaries will potentially give you more power so unless someone comes up with a variable length runners to accommodate for both. What this car lacks is the torque as the power you will get by supercharging it anyways. or like CSG said...get a bigger boat...ermm a bigger Supercharger!
Old 04-21-2016, 11:20 PM   #775
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
@AceHeader-MT
Hey Retro,
We decided against the 44mm Anaconda as tubing ID was only slightly larger then the 42.7 and it was too heavy. For race use anything under 400 wheel HP the Anaconda 42.7 works very well.
We have done multiple custom flanges for customers to match different OP's or FP. Standard cost is +$100USD for this feature and we can do to any header.
If you're looking to maximize high-end HP and low-end torque all from a header it's going to be difficult. The best suggestions are a combination of CSG and Hawk- Get a nice SC for the power and a 4-2-1 header for the low end torque. Harrop, Edelbrock and Jackson racing SC customers are all running Type A 4-2-1's and seem to be pleased. There are dyno sheets all over the forum with their data.
The 4-1 headers really are not recommended for daily drivers. The vacuum draw from the merge doesn't show benefit until almost 5,000rpm.
Any other questions just let us know. There's also lots of good advice from other board members if you want opinions outside a manufacturers'.
Take care,
Ace Header
AceHeader-MT is offline   Reply With Quote
Old 04-22-2016, 06:29 AM   #776
Calum
That Guy
Drives: 2013 asphalt FRS MT
Is anyone running one of these with intake manifold spacers? I'm curious about how well they play together.
Old 04-24-2016, 03:54 PM   #777
I do not recommend it.
Old 04-25-2016, 09:32 AM   #778
retrofit
Drives: Toyota 86
Originally Posted by AceHeader-MT View Post
Hey Retro,
I'm already running a SC (the Harrop kit) with aftermarket header, over/front pipe, catback exhaust, all from different vendors.
The CS400 or the Alpha 250 seem to fit my requirements, for more torque and power, compared to my current header. Some dyno charts comparing both header designs on the same supercharger would definitely help me decide. Anyway I'll keep an eye out for dyno results on these forums.
Old 04-25-2016, 03:06 PM   #779
What is your priority, torque or power?
Old 04-25-2016, 08:14 PM   #780
Hawk77FT
Drives: GTS 86
I am! Very happy with it. I am actually running the Fiebruz ones. (same as the ACE ones). I can feel the power kicking in a bit earlier (500 rpm earlier) compared to when I didn't have them on.
Old 04-25-2016, 09:16 PM   #781
Calum
That Guy
I was unaware Ace sold them. I can't find them on their site, got a link?
Old 04-25-2016, 10:44 PM   #782
AceHeader-MT
Drives: 2012 FR-S
Hi Calum,
for some reason LHD owners don't generally run the intake risers. The 350 headers and the Delicious tunes are able to extract enough torque. The risers typically hurt top end power.
For the RHD owners only a 250 was previously available. The added intake runner length helped compliment the torque and didn't hurt the top end as much.
We do build intake risers, we do not have them on our website out of respect for Crawford. We typically have only sold to domestic market here in Taiwan.
If you have interest just ask CSG or contact us directly.
PS- your CS should be shipping out shortly.
Old 04-26-2016, 12:36 AM   #783
churchx
churchx's Avatar
Drives: 2014 GT86
Move powerband lower imho is a bit better describing then "hurt top end", as later just describes half of story and makes it up to seem as something worse then it is. But yes, story about RHD fitment limitations benefiting from them to get closer to what 350 gets by itself sounds perfectly logical, just as no need for them if CS400 can be installed on RHD as is. Sometimes wondering, if those spacers can be made of dynamical length & controllable from ECU to get most gains everywhere (didn't some motorcycles had something like that?) .. sounds expensive, but then again NA tuning in general is expensive
Old 04-26-2016, 07:34 AM   #784
Calum
That Guy
Hi Calum,
The respect for Crawford is admirable. I'm torn on the fact that he was the first to introduce the product, and the fact that if I buy from him I'll be buying from Crawford.
Thanks for the explanation, that makes complete sense.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
