Old 01-01-2015, 09:47 PM   #8121
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by DAEMANO View Post
Video looks good. Covered the most important points. Later, you may want to clarify references to DR in the vid, but that's minimal. Huge help to every owner. Great job man!
Yeah I removed the big references. I thought I got them all. Any chance you remember where it was?
I plan on revisiting the video at a later time and doing a complete redo.
Thanks for the heads up as always! I also plan on doing a mishimoto catch can install video.
Installed Mods:
Old 01-02-2015, 02:19 AM   #8122
DAEMANO
Time Traveller
DR references were in the original install part (where you discuss routing the DR vacuum tube) and during the demonstration of LCD display. Looking forward to that Mishi can video. Might just end up going that way after all. I know @WRB5titch will appreciate it that's for sure.
Old 01-02-2015, 05:14 AM   #8123
reignerabellera
Drives: GTX 86 2014
Originally Posted by fenton View Post
Hello Phantom faithfuls:
Been getting alot of questions about the wait list....below is the list of people that Rob has noted are interested in purchasing the Phantom SC TQ250. If you are not mentioned below, you have been missed. Please PM Robftss with any correspondents so he can ascertain your priority on the list.
Please note that the list is not in order so the only important thing is that you are on the list.
@Robftss has 5 kits that are ready to go, people will be getting PM's for those this week. If a response is not received he will move down the list.
Thanks all!
@GTO5005
@s2d4
@LazyZed
@keen as
@SuperKazRacing
@Target70
@reneezak90
@gtfapollo
@werunbklynn
@JuicyFruits
@FingR-S
@godzuki
@MelloFlow
@Emac
@PantsDants
@Jonsey
@natemathFT
@l0aded
@Thobjo
@MagicBobert
@SimplePortal
@jwSubMOA
@ChiStig
@yamsta
@Larkin
@Terrapin77
@Pistol
@statlab
@Account Attempt No. 4
@taiquach
@RRIII
@reignerabellera
@KGB
@jwvand02
@far east autopart
@Infidel86
@GotBRZ1691
@kchar
@Technotweak
@GhostOp86
@murselyfe
@BadHabit
@SOAZ
@killy
@j_Zer0
@Namuna
@alex345
@Bigbadvoodooguru
@MmmHamSandwich
@og25491
@Necric
@JoonPrime
@KoolBRZ
im still and will always be interested. just waiting for my turn. and havent received any pm yet.
reignerabellera is offline   Reply With Quote
Old 01-02-2015, 07:44 PM   #8124
jflogerzi
jflogerzi's Avatar
@fenton
With the new lighter compressor wheel and battery upgrades, have there been any new dyno's? Does the system hold boost a bit better, or is mainly the same and it just comes on a bit quicker? Any more top end HP? Either way looking forward to E85, a full exhaust including header and the ECS setup. 225-230 WHP plus 200 WTQ should be nice.
Old 01-02-2015, 09:36 PM   #8125
fenton
Originally Posted by jflogerzi View Post
@fenton
The new compressor wheel reduces spool up by about 40 percent. Before was about 800ms to peak boost and now it is about 500ms...it doesn't sound like much but surprisingly makes quite a big difference.
Boost holds the exact same as before...the new batteries simplify wiring and provide a bit more juice than the last 1.5 conversion setup.
These new batteries seem to need no conditioning or heat to perform at full capacity.
E85 plus those mods will be good for 225 to 235....the torque will hit harder with the quicker spool up.
fenton is offline   Reply With Quote
Old 01-02-2015, 09:40 PM   #8126
fenton
@fenton
No new dynos. I believe shiv is getting one of the new kits to play with.
The key to the partial boost is to set it to 70 to 75 percent OFT throttle as read by the ECU....when set to the above the system kicks in to provide a bit more once all the NA power is used up.
To set this up the user must disable the ESC...turn the car ON....connect the oft and monitor throttle...get in the footwell and adjust the WOT switch so the first click is at 75 percent and ensure the second click happens before 100 percent throttle.
Old 01-02-2015, 09:43 PM   #8127
sam69
Drives: GT 86
Fenton it would be good if you could put a date when you do an update on your first post so it gives people a timeline of progress with this setup.
I have been following this on and off for quite sometime as I find it very interesting to see this new tech progress so just a suggestion to make it a bit easier to follow.
sam69 is offline   Reply With Quote
Old 01-02-2015, 10:53 PM   #8128
jflogerzi
jflogerzi's Avatar
225 to 235 wtq peak? Or you talking whp?
2013 Series 10 FRS #553
Old 01-02-2015, 11:40 PM   #8129
Sojhinn
Sojhinn's Avatar
He's talking whp. My car produced 225 whp with e85 on the original setup of the phantom.
Installed Mods:
Old 01-03-2015, 11:08 AM   #8130
Urmyson
Any idea how much the upgrade will cost those of us with the old system and when Rob will start taking kits to upgrade?
Urmyson is offline   Reply With Quote
Old 01-03-2015, 02:11 PM   #8131
fenton
Contact Rob he will let you know.
Old 01-03-2015, 02:13 PM   #8132
fenton
Yes 225whp not wtq. Wtq with full mods and the new batteries should be good for 205wtq on e85.
We will know when shiv gets his on the dyno again.
Old 01-05-2015, 01:11 PM   #8133
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Cost has dropped however the cost of the batteries is more. The new batteries are awesome and simplify wiring and packaging alot!
New starter:
http://www.batterymart.com/p-odyssey-pc680-battery.html
New Dump batteries(need 2 of these):
http://www.batterymart.com/p-Big-Cra...6-Battery.html
I've been off the thread for awhile because I've been busy and the weather's been unseasonably warm.
Reviewing the thread posts, I see this Odyssey PC680 as the recommended battery. I assume that will resolve the cold starting issues? I sure hope so... it appears to be almost identical in size to the one Powersonic I've been using.
Thanks!
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 01-06-2015, 07:21 AM   #8134
BRAWL
Drives: Toyota 86 GTS Velocity Orange
I'm a rhd buyer, so waiting for confirmation that the kit is available for RHD applications before considering it.
Sadly I was made redundant recently so money will be tight
BRAWL is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
