#813 |
Drives: FR-S | 335i | S13
It's possible either way, but yes. I'm sure everyone double checks their work before reinstalling. Hopefully.
#814 |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
dont pull on it, there is a gasket that seals it, ruin the gasket seal and you can end up with a leak, that you then have to dab rtv on
ask me how I know.. you guys are making this harder than it needs to be reacharound method works with kinky assed pliers and shit the screwdriver holes from factory I refer to are what you see looking down between the two legs of spider on manifoldm they small, but again, you will be using a small clamp I will see I can make a video if you need me to |
#815 |
Drives: vrooom...
#816 | |
NASA SpecE30 Racer
2. They might have sheered off and cracked for you, but I have had no issues with mine. 3. Anyone that has installed injectors should be more than capable of removing those on both sides. Sure a few of the bolts are difficult to remove, but get used to it. 4. It was my first time, and it took under an hour. 5. YRMV
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#817 | |
Seriously man? Let me translate the crap you just posted. 1. Don't worry if your intake manifold no longer maintains a quality seal after and ignore the service manual. In some odd chance your seal is compromised just order an intake manifold gasket and do the procedure all over again. Boost leak is no biggy. 2. It's impossible to sheer an o-ring or crack one and have a fuel leak. In some odd chance that happens the fuel spray is normal. Just turn off your car and park it. Lead time to get o-rings from the dealer is about 14 days. Again ignore the service manual. And don't bother replacing them. 3. Almost everyone has pulled injectors and pulled the manifold before, on multiple cars. Don't worry about the 20 bolts and some that are hard to access, or pulling fuel rails and doing fuel system precautions that's not needed. 4. With all these helpful tips you should have all this done in the street or with minimal tools in 30 minutes.
#818 | |
NASA SpecE30 Racer
By the way, when I removed the intake manifold, I left the fuel rails and injectors in place so there is no worry about the injector O rings. You simply disconnect the fuel lines from the rails on both sides.
- King Tut
#819 |
In Test:Oil Fed SC
Either way is fine, just gitrdone
#820 |
Finally going to try to do mine tomorrow... It would be nice to be able to get on it without worrying about that hose falling off every time i spool up lol.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#821 |
In Test:Oil Fed SC
How did it go?
#822 |
cheap vortech mod to get the crackcase hot air and oil out of intake box make sure the inlet that is marked on oil separator (from Lowes) is being fed from the crankcase hose and the arrow is pointing towards the filter (from autozone) don't for get to cap the port on the intake box
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#823 |
Or just run a hose to the ground so we can pollute the earth and then get oil on our tires causing us to spin out while going 100 causing us to flip 40 times and then die.
#824 | |
or put the hose directly on the front right caliper
#825 |
What kind of IATs are you guys seeing at 8.5psi and 12psi?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#826 |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Put it infront of the tire and do sick drift bro!
Nolan
| Vortech Supercharger | denverizzles | Forced Induction | 176 | 10-19-2013 07:48 PM |
| New Vortech Supercharging System Information... | Brian@Vortech | Forced Induction | 306 | 11-08-2012 06:49 PM |
| Supercharging the GT86 | Billy2224 | Engine, Exhaust, Transmission | 13 | 06-05-2012 04:58 PM |
| Turbo/Supercharging Your FRS | BoostJunkie | Engine, Exhaust, Transmission | 123 | 05-18-2012 07:26 PM |
| Supercharging: the forgotten form of FI | madfast | Engine, Exhaust, Transmission | 76 | 03-02-2012 06:06 PM |
