Old 11-14-2016, 04:45 PM   #813
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
wow. really?
i am not looking to build a dyno queen, my main goal is a flat torque curve = linear power curve so i guess stick with stage 1 with catted headers and FP ?
can someone point to a dyno compilation for OEM vs Stage 1 vs Stage 2 ...etc. i am searching but keep finding conflicting pieces.
Originally Posted by guybo View Post
catless only. A bigger diameter catted header still has a huge clog in it. Stage 2 is for catless setups only. What will end up happening is that the exhaust gas temps will run too high and you'll melt the cat.
neilvosko is offline   Reply With Quote
Old 11-14-2016, 05:24 PM   #814
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Originally Posted by neilvosko View Post
well, that helps. catless or catted doesnt matter?
, aftermarket systems are 2.5"+ inner diameter while OEM is 2.125" so i guess even catted headers is Stage 2 ?
Stage 2 is meant for catless, as removing the cats give much more flow than just widening the pipe. You can use stage 2 for bigger pipes, or if you remove one cat, or a combination, but whether you gain or lose power has to be tested. Not everyone's car is the same, then there are mods on top of that. You will never know until you try, worst case you can just switch back to stage 1.
"Chasing speed with patience"
MurderousPandas is offline   Reply With Quote
Old 11-14-2016, 05:29 PM   #815
neilvosko
neilvosko's Avatar
the reason i am harping on this is stage 1 has been a bit disappointing for me (drop in filter + ARK) and i have JDL UEL catted + JDL UQ FPOP on order and curious if stage 2 has anything to offer over stage 1 with my setup or i may have to stick with stage 1 with Catted setup, but based on dynos on the interweb and my own experience i am not sure there is a lot to gain with stage 1.
Old 11-14-2016, 08:48 PM   #816
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
It's a common misconception that going for a bigger exhaust nets more power. Often times, you lose power by just going bigger. With a small 4 banger 2.0L NA engine, you don't need anything bigger than the OEM size (that's why they chose it). You may see some more high end power, but how much time do you spend at 7000 RPM? You'll lose low end torque where you do actually need the power. But it'll look good on the dyno....
However, losing the cats does a lot of good for your power curve and helps a lot with the torque dip. I'm not a tuner, but I do know that cats limit how much exhaust valve timing you can run because you can melt the ceramic that the catalyst material is in and then you can do actual damage to your engine. Stage 1 or 2 isn't just tuning to push it as far as you dare- it's tuning your ECU for the mods you have, which happens to be a catless exhaust for stage 2.
Old 11-14-2016, 09:17 PM   #817
neilvosko
neilvosko's Avatar
do you have to reflash stage 1 after adding catted headers to and OEM setup with stage 1?
Old 11-14-2016, 10:03 PM   #818
MurderousPandas
I would reflash so the ECU is more open to learning again, but you don't have to.
Old 11-14-2016, 11:56 PM   #819
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Edit 2: That file worked, I can use the realtime data display now!
Edit: I think I figured it out. I found a "FRS Template 8.2.SLT" file that @steve99 had posted a while ago and updated that to the OFT. Will try it tomorrow.
Bump. Anyone know? It appears that the link to download the "template file" is no longer working.
What was the solution to this?
Originally Posted by smbstyle
So I've plugged my OFT into the computer for the first time in about 3 years, it did a bunch of automatic updates for a while, plugged it back into the car to do some logging and keep getting "please update template file", but do not see any updated template file on the OFT website, and the OFT manager is showing everything has been updated. Any help? Thx
Originally Posted by humfrz
I'm old and lazy
Old 11-15-2016, 07:27 AM   #820
guybo
Huge E85 fan!
guybo's Avatar
No, just disconnect the battery for 10 mins. This will reset your fuel trims and everything else.
Old 11-20-2016, 09:48 PM   #821
neilvosko
neilvosko's Avatar
question for the community: 1 day after JDL UEL HFC CATTED header install (o2 spacer for sensor) i got a 2096 code, running stage 1, so is this because stage 2 is required to clear these codes due to catless ?? i am guessing the HFCat even with the spacer is not good enough for ECU or is there another issue?
please advise
Old 11-20-2016, 10:27 PM   #822
MurderousPandas
please advise
Exhaust leak maybe? O2 sensor is reading lean. Check the torques on the bolts, maybe it loosened a little while driving.
Old 11-20-2016, 10:35 PM   #823
steve99
please advise
Ok P2096 is not normal and not good
https://www.obd-codes.com/p2096
The code you might throw running anything but stock header on stage1 tune is P0420 cat efficiency and is easly disabled in tune using romraider.
P2096 indicated a serious fueling problem in that the fuel trims have maxed out (40% adjustment) and the ecu is still not getting the correct afr.
As you have jist installed header its most likely a exhaust leak or damaged 02sensor.
or you put the 02 spacer on the front sensor.
if you have access to tune you dont need any spacers and they should always go on rear sensor after cat, but remove any spacer .
log the tune you will liky see very high ltft and lean afr, this is most likely due to your o2 spacer being on front sensor of exhaust leak or damaged sensor or sensors plugged into wrong socket black to black and grey to grey the grey sensor plug is for front sensor
Old 11-20-2016, 11:13 PM   #824
neilvosko
neilvosko's Avatar
thanks, i put the spacer on the rear sensor behind the cat next to the connector to the overpipe (See pic), thought that it would give more space for O2 sensor and maybe was gonna try without a tune in the future.
Old 11-20-2016, 11:15 PM   #825
neilvosko
neilvosko's Avatar
i guess i will log with OFT, so check AFR? what number should i expect 12-14 ?
Old 11-20-2016, 11:26 PM   #826
86Speedy
Drives: 2013 scion frs
yeah. around there
86Speedy is offline   Reply With Quote
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
