Old 02-10-2019, 07:54 PM   #8275
jflogerzi
jflogerzi's Avatar
Originally Posted by 86TOYO2k17 View Post
I had the oem TB oil cooler from my NA days so decided to see if the mishimoto radiator would help the oil cooler work better as it is way cheaper then JR dual radiator. Feel like so far it’s working. Let us know your oil temps from tracking with he oem cooler.
Also how are your 225/45r17 tires handling the power? I can’t launch at all. If I take off anything over idle I just spin all the way through 1st till 2nd. Maybe I need to change camber and or lower tire pressure in rears.
Install is scheduled for the end of the month. Will let you know with tires and my suspension setup.
2013 Series 10 FRS #553
Old 02-12-2019, 09:31 PM   #8276
jflogerzi
jflogerzi's Avatar
To those who have the intercooled version and run an oil cooler do you run it in front of your of intercooler? If so does it affect your IAT? Or other performance aspects of the kit?
Map has a mocal based kit with either a 13 row for 399$ or 429 for a 19 row cooler.. rather spend this vs 850$ for the JR dual radiator...
Old 02-13-2019, 09:38 PM   #8277
86TOYO2k17
Drives: 2017 toyota 86
This has been discussed a lot throughout this thread. But to save you some time. On the track IAT is hard to keep down, once intercooler is heatsoaked IATs gonup a lot and power goes down.
To help counteract this, E85 and or water meth, as well as hood louvre vents should be enough to help the intercooler. However you would not want to mount a oil cooler blocking airflow to intercooler.
So most people run the JR oil/rad cooler as it’s the easiest solution.
You can also modify the intercooler mount to run the two coolers in tandem (side by side)
Or you could run it in the “fog light duct area” but this has shown to have minimal airflow and you would probably have to get creative and or run one in each fog light area for efficient cooling.
you might be able to get away with a mishimoto rad and oem cooler if you can do E85, water/meth and hood vents. But longer track runs would be pushing it.
Old 02-20-2019, 11:55 AM   #8278
86TOYO2k17
@jflogerzi
Another option i have been looking at to help the intercooler and keep IATs and overall temps down is called Peacekeeper HDS from USRT.
Tap a line and pump to the windshield washer bottle, connected to 7 mist sprayers, and you can spray washer fluid on your intercooler, radiator, and or oil cooler.
About 200$ looks pretty simple to install. seems like the best solution for IATs if your going to track this charger or do numerous back to back hard pulls. Some data i saw showed to keep the intercooler about 50F cooler under hard driving.
Old 02-24-2019, 09:37 PM   #8279
jflogerzi
jflogerzi's Avatar
@jflogerzi
Keep that in mind! If I start to get more serious at the track I will look this up for sure. Here in CA I never use my windshield wipper fluid lol
Old 02-27-2019, 05:29 PM   #8280
brybot
Drives: 13 DGM BRZ 6MT
Should be installing the intercooler kit on my car soon. Any advice or instructions to make it easy?
Thanks!
brybot is offline   Reply With Quote
Old 02-28-2019, 04:34 PM   #8281
BRZ_F
BRZ_F's Avatar
Drives: 2013 WRB BRZ
Thanks!
I installed a used intercooled kit and it's not that bad. The instructions are pretty solid but I would suggest these few things:
-upgrade the plastic barbs on the elbow to brass and ensure they have enough teflon to seal them correctly. It's a pain trying to remove them once you have the SC is on.
-Remove the PCV valve after you remove the old intake manifold and clean it or replace it with a new one. Once the SC is on you really can't get to it. I also put a clamp on it just to secure it better.
-Fill the sc with fluid before you mount it, it's easier to do so and check the fluid level. I think for this kit you want to be almost exact on the amount and don't want to go over as it can cause too much pressure and blow the seals inside
-I'd use worm clamps on the coolant hoses for the intercooler. the ones they provide sometimes leak.
-be careful when mounting the sc onto the intake manifold ports. you'll need an extra set of hands and will want to make sure you mount it flush and the sc manifold runner gaskets are sealing correctly so you won't have to unmount it.
- besides that I just followed the instructions Sprintex provides
Enjoy the wine and extra power!
BRZ_F is offline   Reply With Quote
Old 03-02-2019, 02:59 PM   #8282
brybot
Thanks! For clarification I'm just adding the IC kit to mine. Having a bad time trying to get the blanking plug off the rear. Don't want to uninstall the entire thing but I guess I may have to. Anyone have any luck with flex extensions? Anything at all?
Old 03-13-2019, 10:24 AM   #8283
sqd
sqd's Avatar
Drives: '13 SWP GT86
Does anyone know the diameter of the black plastic intake tube/pipe, from the MAF to the throttle body?
I'd like to use a aftermarket air filter, and replace the plastic tube with a stainless steel pipe. But I need a MAF housing or MAF flange, but I'd ideally like to have the housing and intake pipe the same size.
Pretty much exactly like this, but with the intake pipe replaced as well.
Does anyone know whose car this is?
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 03-13-2019, 10:25 AM   #8284
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Does anyone know whos car this is?
Don't know whose car that is, but I do know who made that intake
Xero-Limit is offline   Reply With Quote
Old 03-17-2019, 03:25 AM   #8285
break
Drives: 86
Does anyone know the dimensions and specification of the rubber o-ring gaskets for the rear housing of the supercharger - for the elbow from the throttle body to the rear of the supercharger?
My car is getting the valve springs as part of recall, and they insist they need to remove the rear elbow to get to the mounting point to lift the motor out, so they've asked me to supply a new suitable gasket.
Sent from my SM-G950F using Tapatalk
break is offline   Reply With Quote
Old 03-17-2019, 08:34 AM   #8286
Kodename47
Kodename47's Avatar
Drives: UK GT86
Can they not just remove the SC before removing the engine?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-17-2019, 09:43 AM   #8287
sam69
Drives: GT 86
I lifted mine out without removing anything off the SC just used a different point to lift the motor with no issues at all .
sam69 is offline   Reply With Quote
Old 03-17-2019, 05:19 PM   #8288
break
Drives: 86
If it was me doing it, I'd do exactly the same.
However being Toyota, they need to follow the maintenance guide on what lift point to use (apparently).
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
