#71 |
Drives: 2023 WRB BRZ (MT)
now we gotta add the rear fog to the stalk DIY lol
#72 |
Boss
Drives: asdf
Does anyone know if on a japanese and/or euro spec the front vs. rear fog lights are controlled independently of one another or do they both turn on/off at the same time?
#73 | |
Drives: Toyota 86
As you can see, there is some sort of logic in the body ecu controlling the activation of the fog lights. |
#74 |
Drives: Awesome
aghhhh what the hell man this is getting complicated lol
#75 |
Boss
Drives: asdf
Agreed.
I ordered bezels and harness from Nigel that should be arriving Friday, and I already have the glass Subaru fog lights. I was originally planning on installing with the button that's coming with the harness from Nigel, but since reading all this would prefer to go with the stalk method as it's cleaner and the fog indicator being functional is quite appealing. The rear fog I could probably live without, but to get it all working like a japanese / euro spec 86 would be pretty sweet. I'm handy when in comes to cars, but i'm not up to speed on wiring or generally messing around with the electrical aspects of new cars such as the FR-S. I'm confident however with some proper instructions i'll be able to tackle this and get that OEM fit & finish I truly desire. Anyone out there with a thorough understanding of what needs to happen to make this feasible (and done correctly as I don't see pulling power/ground through that tiny wire being the correct approach) mind shedding some light and maybe adding some clarification? |
#76 |
use that ground ( from the stalk) as your relay trigger
#77 |
Thanks for the write up! You saved us hours of fiddling with multimeters tryign to find the correct trigger. We got it installed last weekend:
![]() 860467_10200265723702039_1277890102_o by Shinjiro N, on Flickr Used the FET japan Catz LED Fogs, Japanese bezels, and BRZ stalk. We also took the extra step of wiring it up through two relays. So the way it work son my car, is the fogs will only turn on in either the aux lights on, or headlights on posistion, and off otherwise. Will be wiring up the rear triangle fog as well this way.
#78 |
Boss
Drives: asdf
Anyone complete this mod with either the Prius or Tundra stalk yet? Personally i'd like to use the stalk option but not have the dead auto spot.
#79 | |
Drives: 2013 H8R FRS, 03 Miata (Sold)
Check the last few pages, looks like zooki has done it |
#80 |
Glad people are able to use this and mod it to their liking. I haven't messed with it since. Been too busy at work to get under there and fix the wiring.
#81 |
Drives: 2013 Raven Scion FR-S
so, I'm awaiting delivery of my FR-S, browsing DIY planning my future mods...
I have some basic working knowledge of automotive wiring and such, just trying to get this mod figured out in my head. when I do the fog light mod, I'm going to order up the tundra/corolla stalk, which has been described as a straight swap for the existing stalk. now, what I need help understanding is: is there a relay/place for a relay hiding somewhere in the engine compartment that I can hook the lamp harness up to when the stalk is installed -or- do I have to pass wires in through the firewall and somehow connect the switch wires from the lamp/relay harness up to the stalk? If it's the second scenario, which/where are the wires that you need to splice into? On an OEM harness near the steering column? Any clarification (or pics!) will help... Thanks, Patrick |
#82 |
Drives: Asphalt FR-S & S14
^exactly the question running through my head.
#83 |
Drives: 2013 Subaru SWP BRZ Limited 6AT
Don't know if this has been aswered already, but here goes.
On US cars you cannot turn on the fogs without the driving lights being on. So no, the fogs do not work independently of the driving lights. I wish they did though.
Man Law#17:A man in the company of a hot, seductively dressed, woman MUST remain sober enough to fight!
MODS: AVO tubes + filter, Cusco (F) strut brace w/ MC brace, Perrin CBE, Subaru OEM trunk tray, Grimmspeed front license re-locator & hood struts and Beatsonic rear cam. |
#84 | |
Drives: Toyota 86
| Who here has LEDs in their fogs/DRLs in their GT? | RZ86 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 03-30-2013 11:54 PM |
| Fogs wiring; Will this work? | Khánh | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 02-16-2013 01:44 PM |
| BRZ HID Bulb + HID Fogs | delusional | DIY (Do-It-Yourself) Guides | 4 | 02-05-2013 06:09 AM |
| new Camry fogs fit the frs?? | hislargeness | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 09-26-2012 04:20 AM |
| for everyone thinking of using rear fogs | xpicer | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 07-04-2012 01:53 AM |
