#71 |
Drives: 2013 Ultramarine FR-S
Shiv Based his kit off of this. So I assume he is using the same pin, which may not pass emissions.
#72 | |
Im pretty sure the openflash guys are just using ztans flex rom coded A01G rom and flashing that directly into USA 700C to B01C ecus. The ECU hardware is likely same and the A01G roms dont have evap code enabled as we dont have evap system here . So unlikly you will pass emissions in some states depending on tests done as evap will show failed. I think any auto guy will be out of luck at present as their is no auto flex coded roms although wayno is close on that, but again it will be A01I rom, and its a crap load of work to port code to other roms and test. |
#73 | |
Drives: Toyota 86 GTS
#74 | |
I'm going to fill with E85 for the first time tomorrow using the OFT ESC E85 tune. Let me know if you want to help me port this to a US A/T rom. Edit; I'm NOT going to switch to E85 yet. All my local stations closed. I'm not driving 30 miles round trip just to fill up, then constantly worry whether or not I have enough fuel to get back to the station again. Plus, it's in Oregon where I can't pump my own gas.
If I say yes, will that make you think I understand?
![]() Last edited by KoolBRZ; 07-30-2016 at 04:10 PM. Reason: All closed |
#75 |
#76 |
Anyone who wants a flex tune for any AU/EU/US MY12-MY16 can message me.
Not for free. And do not message me for MY17. Calibrations: A01G A01G as 700G A01G as A00G A01G as A02G A01G as D00G A01G as F10G A01G as F20P A01I A01I as 700I A01I as A00I A01I as A02I A01I as E00I A01I as F20Q A01G as 500C A01G as 700C A01G as 900C A01G as A00C A01G as A01C A01G as B00C A01G as B01C A01G as D00C A01G as F00C A01G as F40C A01I as 500D A01I as 700D A01I as 900D A01I as A00D A01I as A01D A01I as B00D A01I as B01D A01I as D00D A01I as F00D A01I as F40D |
#77 |
Drives: Toyota GT86
I want to share with you about the adaptation of Ztan flex fuel analyzer.
I designed the PCB, and instead of the PLX display, used the small OLED SSD1306, because it is cheaper. I also added fuel temperature and sensor frequency measurement. Is not yet connected to Evap pin A35-20, because I have a not modified ROM (01G), as instructed by Ztan. The voltage at the output is the same as for Ztan. You can also use Arduino Nano or Uno, and use Ztan wiring diagram, but instead of the PLX display, plug in the A4 and A5 OLED SSD1306. Wiring Diagram with Eagle software. https://drive.google.com/file/d/1KJb...ew?usp=sharing List of parts C1, C2, C4 = 100nF C6, C7 = 22pF C5 = crystal 16mhz C8, C9 = 330nF C3 = 10uF C10 = 100uF R2, R5 = 3k3 R4, R6, R7 = 1k8 R1 = 10k R3 = 6k8 T1 = BC547 E_SENSOR = 13577429 flexfuel sensor Code:
#include <Arduino.h>
#include <Wire.h>
#include <EEPROM.h>
#include <U8glib.h>
U8GLIB_SSD1306_128X64 mujOled(U8G_I2C_OPT_NONE);
uint16_t pwm_output = 0; //integer for storing PWM value (0-255 value)
int HZ = 0; //unsigned 16bit integer for st
int inpPin = 8;
int V_out_int;
float V_out, V_out_avg, E_scalar;
//Define global variables
volatile uint16_t revTick; //Ticks per revolutionoring HZ input
int ethanol = 0; //Store ethanol percentage here
float expectedv; //store expected voltage here - range for typical GM sensors is usually 0.5-4.5v
uint16_t voltage = 0; //store display millivoltage here (0-5000)
//temperature variables
int duty; //Duty cycle (0.0-100.0)
float period; //Store period time here (eg.0.0025 s)
float temperature = 0; //Store fuel temperature here
int fahr = 0;
int cels = 0;
int celstemp = 0;
float fahrtemp = 0;
static long highTime = 0;
static long lowTime = 0;
static long tempPulse;
//EEPROM store
int EE_V_addr = 0;
float V_out_default = 147;
long Elast, Enow, Edelta;
//TRAC switch double click
bool TRAC_buttonMonitor = HIGH;
int debounce = 20;
int doubleClick = 200;
int longClick = 3000;
int TRAC_initializeDelay = 5000;
int TRAC_buttonState = 4; //initialize to 0 for normal operation, 4 for on by default after delay
long TRAC_buttonCounter = 0;
void setupTimer() // setup timer1
TCCR1A = 0; // normal mode
TCCR1B = 132; // (10000100) Falling edge trigger, Timer = CPU Clock/256, noise cancellation on
TCCR1C = 0; // normal mode
TIMSK1 = 33; // (00100001) Input capture and overflow interupts enabled
TCNT1 = 0; // start from 0
ISR(TIMER1_CAPT_vect) // PULSE DETECTED! (interrupt automatically triggered, not called by main program)
revTick = ICR1; // save duration of last revolution
TCNT1 = 0; // restart timer for next revolution
ISR(TIMER1_OVF_vect) // counter overflow/timeout
{ revTick = 0; } // Ticks per second = 0
void setup() {
pinMode (3, OUTPUT);
pinMode (10, OUTPUT);
digitalWrite (10, LOW);
pinMode (6, INPUT);
EEPROM.get(EE_V_addr, V_out_avg); //load last V_out_avg
if (isnan(V_out_avg))
V_out_avg = V_out_default;
V_out_int = (int)V_out_avg; //convert to integer for analogWrite
analogWrite(3, V_out_int); //output V_out as PWM voltage on pin 3
setupTimer();
Serial.begin(9600);
void loop() {
getfueltemp(inpPin); //read fuel temp from input duty cycle
if (revTick > 0) // Avoid dividing by zero, sample in the HZ
{HZ = 62700 / revTick;} // (62200) 3456000ticks per minute, 57600 per second
else // 62200 calibrated for more accuracy
{HZ = 0;}
//calculate ethanol percentage
if (HZ > 50) // Avoid dividing by zero
{ethanol = HZ-50;}
else
{ethanol = 0;}
if (ethanol > 99) // Avoid overflow in PWM
{ethanol = 99;}
V_out = 255 - (2.73 * ethanol);
V_out_avg = V_out_avg + (0.1 * (V_out - V_out_avg)); //V_out_avg as moving average
//Store EEPROM data every 5 minutes
Enow = millis();
Edelta = Enow - Elast;
if (Edelta >= 300000)
Elast = Enow;
EEPROM.put(EE_V_addr, V_out_avg ); //store V_out_avg to EEPROM
mujOled.firstPage();
do {
mujOled.setFont(u8g_font_helvB08);
//Printing the data on the OLED
mujOled.drawStr(0, 15, "Eth: ");
mujOled.drawStr(0, 30, "Temp: ");
mujOled.drawStr(0, 45, "Freq: ");
mujOled.setPrintPos(72, 15); //setting the dimensions to print the ethanol
mujOled.print(ethanol, 10);
mujOled.println("%");
mujOled.setPrintPos(72, 30); //setting the dimensions to print the temperature fuel
mujOled.print(cels, 10);
mujOled.println("C");
mujOled.setPrintPos(72, 45); //setting the dimensions to print the frequency
mujOled.print(HZ, 10);
mujOled.println("Hz");
while( mujOled.nextPage() );
delay(250);
void getfueltemp(int inpPin){ //read fuel temp from input duty cycle
highTime = 0;
lowTime = 0;
tempPulse = pulseIn(inpPin,HIGH);
if(tempPulse>highTime){
highTime = tempPulse;
tempPulse = pulseIn(inpPin,LOW);
if(tempPulse>lowTime){
lowTime = tempPulse;
duty = ((100*(highTime/(double (lowTime+highTime))))); //Calculate duty cycle (integer extra decimal)
float T = (float(1.0/float(HZ))); //Calculate total period time
float period = float(100-duty)*T; //Calculate the active period time (100-duty)*T
float temp2 = float(10) * float(period); //Convert ms to whole number
temperature = ((40.25 * temp2)-81.25); //Calculate temperature for display (1ms = -40, 5ms = 80)
celstemp = int(temperature);
cels = celstemp;
fahrtemp = ((temperature*1.8)+32);
fahr = fahrtemp;
//TRAC switch doubleclick
TRAC_buttonMonitor = digitalRead(6);
switch (TRAC_buttonState)
case 0: //inactive
if (TRAC_buttonMonitor == LOW) // button pressed
digitalWrite (10, HIGH); //Transistor on
TRAC_buttonState = 1; //increment state
break;
case 1: //check for release
if (TRAC_buttonMonitor == HIGH) //if button released
TRAC_buttonCounter = millis(); //start counter
TRAC_buttonState = 2; //increment state
break;
case 2: //wait for doubleClick
if (TRAC_buttonMonitor == LOW && (millis() - TRAC_buttonCounter) > debounce && (millis() - TRAC_buttonCounter) < doubleClick) //second click registered
TRAC_buttonState = 3; //increment state
else if ((millis() - TRAC_buttonCounter) > doubleClick)
digitalWrite (10, LOW); //Transistor off
TRAC_buttonState = 0; //reset state
break;
case 3: //doubleClick made
if ((millis() - TRAC_buttonCounter) > longClick)
break;
case 4: //initialize after delay by default
if (millis() > TRAC_initializeDelay)
TRAC_buttonState = 3; //set state to doubleClick
break;
#78 | |
Message me if you need modified rom Nice work :-) |
#79 |
Drives: BR86
Great stuff although I would rather a bigger display = easier to read.
#80 |
Drives: Toyota GT86
#81 | |
Drives: Toyota GT86
I changed the font size, and the individual data is rotated every 5 seconds on the OLED display.
Recovery time can be changed Quote:
Code:
#include <Wire.h>
#include <EEPROM.h>
#include <U8glib.h>
int p;
void pageEthanol(); // Page-1
void pageTemp(); // Page-2
void pageFreq(); // Page-3
void (*pages[])() = { pageEthanol, pageTemp, pageFreq } ;
int inpPin = 8;
int V_out_int;
long int prepis = 0;
//float expectedv; //store expected voltage here - range for typical GM sensors is usually 0.5-4.5v
//uint16_t voltage = 0; //store display millivoltage here (0-5000)
int fahr = 0;
int cels = 0;
int celstemp = 0;
float fahrtemp = 0;
//EEPROM store
int EE_V_addr = 0;
int debounce = 20;
void setup() {
pinMode (6, INPUT);
mujOled.setFont(u8g_font_fub25);
mujOled.setColorIndex(1);
p = 0;
setupTimer();
Serial.begin(9600);
void loop() {
{HZ = 0;}
{ethanol = HZ-50;}
else
{ethanol = 0;}
{ethanol = 99;}
V_out = 255 - (2.65 * ethanol);
Enow = millis();
Elast = Enow;
do {
(*pages[p])();
} while( mujOled.nextPage() );
delay(3000); // recovery time Oled
p = p+1;
if (p == 3)
p=0;
highTime = 0;
lowTime = 0;
cels = celstemp;
fahr = fahrtemp;
case 0: //inactive
break;
break;
break;
break;
break;
void pageEthanol() {
mujOled.drawStr(0, 28, "Ethanol ");
mujOled.setPrintPos(32, 64); //setting the dimensions to print the ethanol
void pageTemp(){
mujOled.drawStr(10, 28, "Temp: ");
mujOled.setPrintPos(33, 64); //setting the dimensions to print the temperature fuel
void pageFreq() {
mujOled.drawStr(20, 28, "Freq: ");
mujOled.setPrintPos(12, 64); //setting the dimensions to print the frequency
#82 | |
Drives: European gt86
You may want to look at this if you wanna plug it to the obd: http://www.ft86club.com/forums/showthread.php?t=123339 (So you can show oil temp, intake temp, etc.) If you make a plugin using this project I'll be glad to add it to the git hub sources
#83 |
Drives: Toyota GT86
In winter I want to upgrade to a turbo.
I want to integrate other functions in this device (temperature and pressure oil, turbo pressure, etc.) Or I will build a separate device on the arduino platform. When I have this device built, I like to share it. |
#84 | |
Drives: 2013 Scion FR-S 6MT
http://www.ft86club.com/forums/showt...ht=instruments |
| Open source Over Boost Fuel Cut | ztan | Software Tuning | 19 | 02-15-2026 02:32 AM |
| Open Source Electric Supercharger | neutron256 | Forced Induction | 913 | 08-22-2021 06:16 PM |
| open source software question | GeeTee86 | AFRICA | 15 | 02-15-2015 07:52 PM |
| The Retrofit Source summer open house! | soundman98 | Southeast | 0 | 06-23-2014 09:41 PM |
| ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! | Visconti | Engine, Exhaust, Transmission | 356 | 05-20-2013 10:36 AM |
