Old 12-31-2017, 11:11 AM   #841
ermax
ermax's Avatar
Tactrix EcuFlash Info for BRZ 86 FRS Rom flash update and logging
Originally Posted by freerunner View Post
∆ this :-)
I just went through your config again and still didn’t see OilTemp. Turns out Tapatalk only shows the tail end of your config. I had to read your post in a web browser to see the whole thing. What CalID are you on? I see several channels I’d like to snag.
Edit: never mind I see in the config it says ZA1JA01G. I’m on B01C. Darn.
Old 12-31-2017, 11:25 PM   #842
steve99
@ermax
For oil temp in your B01C use same scaling as A01G subsiture in ram address below.
Ot will come out as celcius though
B01C/B01D Oil temp address
Ram_Engine_Oil_Temperature FFF8DC20
Old 02-09-2018, 04:12 PM   #843
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Arduino based Boost control
The only guy that done any opensource development is linked below, hes also said hes not rearly interedted in persuing it anymore.
The oft open flash tablet guys used this work and are funnjng this flex and overboost mods on their turbo tunes with speed by design turbo kit think they go to about 12 psi on e85 arround tge 350whp mark.
http://www.ft86club.com/forums/showthread.php?p=2388566
The other issue with opensource development is a complete unbricking solution for these ecu. Software guys often brick the ecu, Their is no full unbrick solution for thix ecu yet, i know a guy whos bricked several trying stuff.
So its certianly possible to do opensource boost, but you wont have electronic boost control intergrated like ecutek or map switching.
The chances of someone develloping opensource features similar to ecutek are pretty slim i think you guys on evo and wrx were very lucky..
Realisticly if you wsnt say map switching and other high end features above what oft guys have then id say just buy ecutek, unfortunatly you tunes eill be locked excetp got maybe James Martin from HRI tuning and i thing VitVviper tuning
If you use an arduino based flex fuel analyzer it would be extremely easy to add a second voltage output to control boost based on e85 content. Have it run waste gate pressure at 50hz and 12psi at 135hz.
I could write the code for anyone who's interested for an arduino based flex fuel and integrated boost control.
Jaden
Jaden is offline   Reply With Quote
Old 02-10-2018, 02:00 PM   #844
Jaden
Road-hole
Additionally...
Jaden
With the can solutions that are coming out, it would be possible to program in boost control by gear etc... anything that be read on the fly and converted to a voltage or frequency signal can be programmed in to a arduino based controller.
It's time we started seeing and using canbus for the benefits instead of just the negatives.
IOW, we don't have to be able to program everything into the engine ecu. We can start creating our own controllers for additional features.
A simple algorithm that will adjust voltage output going to an electronic boost controller based on gear inputs as well. So it would be incrementally increased based on a combination of FF sensor freq and reported gear.
Jaden
p.s. In a way this would be even better than Ecutek's solution because you aren't limited by the number of inputs, i.e. you can keep both O2 sensors and still have flex fuel AND boost control.
Old 02-28-2018, 06:09 PM   #845
Tor
Tor's Avatar
Drives: Toyota GT86
Can anyone help with the correct RAM address for logging AFR command on B01C?
Thanks.
Tor is offline   Reply With Quote
Old 02-28-2018, 07:29 PM   #846
ermax
ermax's Avatar
Thanks.
paramname = AFR
paramid = 0xFFF89330
isfloat = 1
scalingrpn = x,14.7,*
Old 02-28-2018, 08:22 PM   #847
Tor
Tor's Avatar
Drives: Toyota GT86
Originally Posted by ermax View Post
paramname = AFR
isfloat = 1
I have that one, thanks. What I look for is targeted AFR or AFR_Command. It's not super important, but it would be nice to have.
Last edited by Tor; 02-28-2018 at 09:25 PM. Reason: Deleted a second question - solved with Kodename47's definitions.
Old 02-28-2018, 11:14 PM   #848
ermax
ermax's Avatar
Oh duh. Missed the “command” part.
paramname = AFR_command
paramid = 0xFFF8DBE8
isfloat = 1
Old 02-28-2018, 11:22 PM   #849
Tor
Tor's Avatar
Drives: Toyota GT86
isfloat = 1
Thanks a lot!
Old 03-10-2018, 08:19 PM   #850
steve99
Added ZA1JN10C USA 2018 Manual rom to first post
Old 03-10-2018, 08:24 PM   #851
Tor
Tor's Avatar
Drives: Toyota GT86
I'll contribute with a bit better B01C logcfg.txt than the earlier ones linked.
c/f mph/kph bar/psi - default metric.
Old 03-31-2018, 08:57 PM   #852
phrosty
@steve99 now that OFT is based on A01I, which of these files has the correct addresses?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 03-31-2018, 10:46 PM   #853
steve99
Luckly A01I and A01G ecu ram addresses for logging are same, ie jist use A01G ram addresses
Old 04-05-2018, 11:11 PM   #854
steve99
Added ZA1JN00P 2018 australian Manual, this is very likely same as ZA1JN00Q but not confirmed yet
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
