#8961 | |
Drives: 2015 Firestorm 08/05/15
Supercharger run dry
#8962 |
Drives: '14
I have PCV oil seeping out of my SC from the back. Is there supposed to be some sort of PCV valve in the back or something? If so, where can it be found on the SC? Going to try and fix it myself.
#8963 | |
Drives: Subaru BRZ 2013 6AT& Honda Odyssey
2013 Subaru BRZ 6AT; Rays 57XTREME STD SPEC 18' 9.5J Wheels; TEIN FLEX Z Coilovers; Brembo OE Gold Front Brake Kit(STI); Sprintex 210 SC;GReddy GT ver.2 Exhaust; CUSCO strut bar F/R...
#8964 |
Drives: '15 WRB Brz
I just picked up this kit a few weeks ago. I have a shop that is going to do all the work for me, although he has never installed this specific kit.
My car is a show car/weekend warrior road car. I was wondering if there is anything I should be upgrading/replacing since I will be ripping into the car? I was thinking a larger alternator for starters, since mine is starting to look nasty and corroded. And had thoughts of upgrading the sound system to something with better sound.
Follow me on Instagram
https://instagram.com/anamishwoman/ '15 WRB BRZ Limited (Summer) '93 Ford Festiva L (Work Horse / Race Project) |
#8965 | |
Drives: 2017 toyota 86
Injectors if going E85 Supercharger has nothing to do with need for alternator, although your sound system may. Supercharger idler/tension pulley mentioned in thread previously. With 69mm pulley you won’t need to change belts to fit it. Perrin cold air intake Gold heat tape entire intake pipe. Really nothing special you need, besides good tires to put the power down. |
#8966 | |
Drives: '15 WRB Brz
I have a Grimspeed intake and good tires
#8967 | |
The idler/tensioner that comes with supercharger. But really depends more what supercharger pulley you are using. You can’t use the grimmspeed intake, unless you can retrofit it to work somehow. Possible to do, but easier to just sell it and buy a Perrin cai or just use factory airbox. But the perrin makes it whine more. |
#8968 | |
Drives: '15 WRB Brz
Well that stinks. I liked the Grimspeed one. It dressed up much nicer.
#8969 | |
Now I refilled the right amount of engine oil. It seems that it cannot stop the rise of oil and gas, especially in cold weather. and I am going to install the oil catch tank. But I do n’t know if it is a mistake to completely ban these oils and gases from entering the intake manifold. The same situation, refer to the post near page 191.
#8970 |
Thanks for replying - Do you know where I can get in contact with Jon Bond Performance?
#8971 | |
As far as the supercharger goes, its breathing oil through the rear of the blower where my AOS (air oil separator) connects. It doesnt look like a leak just heavy breathing oil residue. |
#8972 |
Some people have had trouble with the plastic fittings on the back of the supercharger and have had to remove the unit to fix. You might look into brass before installing. I have had no trouble yet, six years.
#8973 |
Jon Bond info
#8974 | |
POV oil.
Some not as bad as others and some none at all. But never ever let the charger run low on oil. Good insurance is check it every Sunday as a routine and then do a look phase inspection as well . Hope this helps 👍 |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
