Old 08-21-2020, 07:27 PM   #9031
jflogerzi
jflogerzi's Avatar
I think with all these options your looking at demenishing results. Better off going turbo if your seeking more power
2013 Series 10 FRS #553
Old 08-21-2020, 08:22 PM   #9032
86TOYO2k17
Drives: 2017 toyota 86
Their quick easy cheap mods.
OEM bosch Pumps that flow like 2-3x the rate for about 100$
Larger dual pass radiators around 150$
Haven’t really seen a good alternative to larger reservoir.
But not for more power but more consistent power/safety.
Old 08-22-2020, 10:53 AM   #9033
sam69
Drives: GT 86
Originally Posted by 86TOYO2k17 View Post
Anyone fitted a bigger intercooler radiator, water pump, or reservoir?
What’s the hose diameter?
I was running dual radiators but that was to add extra cooling for the water jacket I was running which made a big difference .
Hose diameter is 19mm .
sam69 is offline   Reply With Quote
Old 08-22-2020, 01:19 PM   #9034
86TOYO2k17
I wish i had that jacket, looks like it would be very effective.
Probably going to get a larger pump that moves 2x the fluid.
It’s a toss up between
Johnson CM30P7
And
bosch 0392022010
Then I’ll just wire it to a “on” fuse to bypass the injector plug.
Old 08-22-2020, 10:31 PM   #9035
sam69
Drives: GT 86
You can buy that one if you want to as I no longer have that 210 kit (sold it ).
PM me if you want to know more.
Old 08-22-2020, 11:46 PM   #9036
kev0
Drives: '14
Are there any pros and cons to running a speed density tune with this car that is purely street driven?
kev0 is offline   Reply With Quote
Old 08-24-2020, 12:33 PM   #9037
Kodename47
Kodename47's Avatar
Drives: UK GT86
No need as you're not maxing the MAF (or near to) and you can't run one if using the OEM MAP sensor. Plus you don't gain anything over running MAF fuelling.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-26-2020, 01:46 PM   #9038
86TOYO2k17
anyone know where to get a replacement water to air heat exchanger radiator with the return overflow port on top? either exact replacement or good alternative? and or what the dimension on the Sprintex one is?
Old 08-30-2020, 01:57 AM   #9039
kev0
Drives: '14
I took off the Moto-East short ram air intake and went back to stock (got it retuned ofc). My IAT's were about 40F cooler now but I don't hear my SC whine anymore. Isn't the SC supposed to have an audible whine even with stock airbox? I could hear it easily with the previous intake but not anymore with the stock one..
Old 08-30-2020, 02:06 AM   #9040
jflogerzi
jflogerzi's Avatar
Yes but I mostly hear it in the upper rpm range. 4000 and on. Plus it will be dependant to your throttle
Old 08-30-2020, 02:38 AM   #9041
86TOYO2k17
Can only hear it at WOT, and depending on exhaust it can cover it up a little. But with perrin intake it’s got a pretty good whine to it.
https://streamable.com/ztq6x7
https://streamable.com/sgmpqt
Old 09-10-2020, 12:53 AM   #9042
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
So is this still a viable kit to consider? I'm curious why newer owners chose it over other kits such as Harrop or Edelbrock.
MS, CSCS, TSAC-F, CPT
Old 09-10-2020, 01:19 AM   #9043
jflogerzi
jflogerzi's Avatar
It's a gem if your more driving the car on the street and back roads. E85 and a smaller pulley with the IC is a must imo. Used it's a good deal but new I think it's over priced. The power and tq curve is fantastic. For serious track use looks else where as even with the IC it will heat soak. I enjoy my kit and the price I got it used for was good 2800$
Old 09-10-2020, 10:13 AM   #9044
weederr33
weederr33's Avatar
My car is purely DD and back roads spirited driving. But yeah, I would rather buy something like a supercharger new and the price is steep.
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
