Old 02-10-2019, 07:03 PM   #897
steve99
Yes you can message me
Old 02-10-2019, 08:57 PM   #898
steve99
B01C is compatable with 700C just later factory version
Old 02-12-2019, 12:33 AM   #899
iiTz-PeRSiaN
Drives: 2014 Hot Lava
Does anyone have N10C / ZA1JN10C EcuFlash definition file?
iiTz-PeRSiaN is offline   Reply With Quote
Old 02-12-2019, 07:23 AM   #900
steve99
No its not been defined, however you can use the euro K00G as a subsitiute rom amd its been defined
If you jist want to flash back a stock N10C you can make a flash only definition see first post in this thread
Old 02-14-2019, 01:11 AM   #901
freddydo
Drives: 1234
v4.03 for MY17 US MT (ZA1JK00C) has been giving more and more bucking after an upshift and a throttle, so I flashed back to stock.
Are there v2 or v3 available for this model? Not sure how to fix the bucking issue, but am on the search of it / learning how to modify values on RomRaider.
freddydo is offline   Reply With Quote
Old 02-14-2019, 05:03 AM   #902
ermax
ermax's Avatar
Did going back to stock help? Not sure I’ve seen anyone complain about bucking on OTS tunes.
Old 03-02-2019, 05:00 PM   #903
Chuckls
Moutain Runner
I hate to be that guy...but can someone spoonfeed me the process of flashing my 2018 BRZ MT to the v4.03 e85 tune?
I have everything done except for the checksum modifications. Tried speaking with Steve, but I could not figure out where to move the def.zip from the first page to...nor where to add the below text to.
< rom> <romid> <xmlid> ZA1JK00G</xmlid>
<internalidaddress>8000</internalidaddress>
<internalidstring>ZA1JF00C</internalidstring>
<ecuid>A929703007</ecuid>
<year>2017</year>
<market>USDM</market>
<make>Subaru</make>
<model>BRZ</model>
<submodel>FA20</submodel>
<transmission>MT</transmission>
<memmodel>SH72531</memmodel>
<flashmethod>subarubrz</flashmethod>
<checksummodule>subarudbw</checksummodule>
Chuckls is offline   Reply With Quote
Old 03-04-2019, 05:35 AM   #904
Conti93
Conti93's Avatar
Drives: '02 Speedster n°586 - '23 GR86
Did anyone find out the address to log the rear O2 sensor voltage on A01G?
Interested in fitting a wideband at the rear and feeding the narrowband signal back to the ECU. OFT can read it, but I didn't find anything for OpenPort.
Maybe @ztan?
Conti93 is offline   Reply With Quote
Old 03-04-2019, 06:02 AM   #905
steve99
Maybe @ztan?
Other option is to recale thte srock front 02 sensor it reaels pretty well down to about 10 afr
no real need for separate wideband
http://www.ft86club.com/forums/showthread.php?t=82875
Old 03-04-2019, 06:18 AM   #906
steve99
<year>2017</year>
<make>Subaru</make>
<model>BRZ</model>
attached is a flash only def for K00G rom for ECUFlash do your editing in romraider then flash with ecuflash
File Type: zip ZA1JK00G_Ecuflash.zip (432 Bytes, 173 views)
Old 03-13-2019, 07:27 PM   #907
ML
ML's Avatar
Drives: 13 White MT FR-S
Possible to use tactrix and RR to turn off abs and vsc like the 86nanny did?
Old 03-14-2019, 05:48 AM   #908
steve99
Ill say no as those feafures controlled by the abs\vsc module not the engine ecu, so tactrix doesnt flash that module also no one has decoed the firmwsrs for abs\vsc.module
Old 03-14-2019, 05:54 AM   #909
tomm.brz
Drives: brz 2017 hksv2
how do OFT and obd modules force Pedal dance mode?
Old 03-14-2019, 07:54 AM   #910
ermax
ermax's Avatar
Tactrix EcuFlash Info for BRZ 86 FRS Rom flash update and logging
The OFT does it by sending packets, not by changing the rom. You could write an app to send the CAN bus packets using the Tactrix to do all sorts of things but you can’t use RR to customize the rom and then flash it for a permanent fix.
If you want to get into CAN bus hacking you would be better of with an Arduino and a CAN bus shield. There aren’t any Linux drivers for the Tactrix and you don’t want a full windows machine in your car just to send some CAN bus packets.
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
