Old 03-06-2015, 08:45 PM   #897
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
How do I get in on this list? I've been following since this thread started! I had no idea there finally was a module.
I would like stock behavior
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 03-06-2015, 08:54 PM   #898
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
You just have to go here and order:
http://www.diodedynamics.com/store/c.../category/814/
Husker BRZ is offline   Reply With Quote
Old 03-06-2015, 09:00 PM   #899
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
crap, I was googling it but couldn't find it. Thank you.
Old 03-06-2015, 09:02 PM   #900
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Order online -
I ordered on 2/17 just got email of shipment today 3/7 .- est. delivery 3/12
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 03-06-2015, 11:58 PM   #901
btoast
Originally Posted by amaciose View Post
For those that can't view the functionality due to the parking brake, here's what I ended up doing: Set up your GoPro in front facing the car and view the camera remotely through your phone. If you don't have a GoPro, you can find a way to prop up your camera facing the car and record a video.
Thankfully, mine worked perfectly out of the box!
I just put a brick behind each front tire. Then you can disengage the e-brake without the car rolling away.
btoast is offline   Reply With Quote
Old 03-07-2015, 12:06 AM   #902
Burrcold
Drives: Subaru BRZ Limited
Ordered!
Old 03-07-2015, 04:38 PM   #903
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Exclamation
Service message for Diode Dynamics and for all users of "Always ON":
I INFORM YOU THAT IS POSSIBLE TO INSTALL brown relay OPENING THE FUSE BOX BY THE ENGINE SIDE.
You can see a little side and slide panel (red square in pic) along height of fuse box. Open it (from bottom to upper side) and you can avoid to stretch the little black wire onto cover of fuse box.
Install relay and insert black wire inside the fuse box.
Nick, Paul !!!!! installed and all is gone very well on EDM BRZ!.
Trap63 is offline   Reply With Quote
Old 03-07-2015, 06:32 PM   #904
Diode Dynamics
Diode Dynamics's Avatar
Thanks for everyone's continued patience. We shipped a bunch last week, and we expect to be caught up and stocked for immediate shipment by the end of this coming week. Finally!
Glad to see that most of you are getting perfect functionality right out of the box. If you think you do have a problem, please double-check that your stock DRL is activated (without the module) and then contact us if you're still seeing issues. Thanks!
John C.
Diode Dynamics
Old 03-07-2015, 08:25 PM   #905
Blue-Sensei
Blue-Sensei's Avatar
Drives: '14 WRB BRZ LTD Turbo
I started my rma on 2/26 but it's since just been put to preorder status...
Order # 11222124. So by the end of this week then(3/13)?
Blue-Sensei is offline   Reply With Quote
Old 03-08-2015, 10:56 AM   #906
Trap63
Trap63's Avatar
Exclamation
better solution for wire
Old 03-08-2015, 05:22 PM   #907
Elkton86er
Elkton86er's Avatar
Drives: 2014 Subaru BRZ Limited WRB AT
Installed mine today. Worked great right out of the box. I saw @Trap63's note about the black relay wire after I was done. Went back and took a look and I think in my case the way I've got things tied up I need the black wire to be a few cm longer for it to work better via the engine side. When you slide the side panel back on it will tend to pull on the wire. I decided to put it back the way I had it - I used a little piece of electrical tape to both protect the wire and lodge it into a groove to keep the wire in place as the fuse box lid is replaced.
Thanks @DiodeDynamics for a great product!
Cosworth Drop-In Air Filter, Diode Dynamics DRL module, Perrin Tips
Elkton86er is offline   Reply With Quote
Old 03-09-2015, 06:09 PM   #908
TIE Pilot
TIE Pilot's Avatar
As advertised. Thanks @DiodeDynamics and @Trap63 for the "better solution"
Old 03-10-2015, 12:31 AM   #909
996garage
996garage's Avatar
Drives: 03' NSX & 13' BRZ 6spd Ltd white
I appear to be having the same problem. (ordered on 2/17, and arrived today) I performed the simple install, and neither the DRL or boomerang come on unless I switch on the lights.
As you recommended, I removed the brown relay and replaced the stock one back, and now it works just like normal OEM. While testing I had the car running in neutral with parking brake off(brick behind wheels).
Forgot to add that the DRL's did come on now with the lights turned on.
Please reinstall the factory relay, and try turning on your DRLs.
Just as we've mentioned to the others above, this module does not affect the stock DRL function in any way, it just also sends the power to boomerangs.
If your DRLs are not coming on at all during the day as DRLs, you do not have them switched on. Thanks!
996garage is offline   Reply With Quote
Old 03-10-2015, 01:10 PM   #910
was385
Drives: MT WRB BRZ Limited, 2007 911s
I ordered mine on 2/14 and still haven't received a working one if it makes you feel any better about your wait time.
was385 is offline   Reply With Quote
[Closed] Gauging Interest thread pansontw Cosmetic Modification (Interior/Exterior/Lighting) 49 08-27-2014 04:14 PM
So has anyone managed to get the BRZ Boomerang/parking lights to operate as DRLs? gt8613 BRZ First-Gen (2012+) — General Topics 18 04-27-2014 03:09 AM
Gauging Interest ISC Suspension Announcements, Contests, Giveaways 17 04-03-2014 10:44 AM
Jdm headlights - gauging interest Hawk77FT Exterior Parts (Aero, Lighting, Etc.) 7 03-31-2014 10:38 AM
FS: Oil Pressure gauge (includes Block galley plug for free!) True plug and play! Sportsguy83 Engine, Exhaust, Bolt-Ons 10 08-30-2013 11:53 AM
