#897 |
Drives: 2013 FR-S Firestorm
I am currently on the stage 2 UEL E85 tune. Is it safe to reprogram TPMS light at the tire shop when I switch between my sets of tires? Or will this mess up my tune somehow? I'm told the only way to reset the light is to bring it to the shop and have them pair the tpms system. I have TPMS on both sets of wheels and tires I own. I searched extensively on google and the forums and couldn't find anything... thanks in advance for the help.
#898 | |
Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
#899 | |
Drives: 2013 Scion FR-S 6MT
#900 | |
#901 |
Not a troll
Had a new CEL pop up today that I have not run into before, wondering how big of an issue it is.
Code is P0138. The car has been sitting for about a week now, and when I started it up, the code popped up. The car has a catless UEL header, tuned on an OTS 91 Stg 2 map. I haven't seen a whole lot of info about it, so I'm wondering if it's an ok code to disable? |
#902 |
Drives: UK GT86
@Cole
https://www.yourmechanic.com/article...by-jay-safford If you're still running the 2nd sensor it may have gone faulty. I would just confirm what's said in the link. It could impact running even if the CEL is disabled.
.: Stealth 86 :.
#903 | |
Not a troll
I'll do a log today, and check on it. |
#904 |
Yes +1 on what kode said
that code is not normal https://www.engine-codes.com/p0138_subaru.html oft logs rear 02 sensor as Widebamd 02, its not calobrated correctly but it should show some movement on that channel, however some roms the ram address is incorrect i think B01C is ok but later roms like D00C may not log correctly. front 02 is logged as afr. i think the oft can also log o2 sensor volts directly not sure if it can do front and rear o2 volts its possible that code may be caused by exhaust leak or loose sensor as well as damaged sensor. if you have techstream it would be usefull |
#905 |
Drives: WRB BRZ Limited
So apparently I got my OFT stolen and currently running an E85 tune. Is there anyway to get another brand new OFT to pair up to my car and get it tuned to 91?
#906 | |
If you get aonther new or unmarried oft it will marry up to your car ok. But your stock\original tune will be your E85 tune, but you will be able to flash any tune you like to car even real stock tune. The downside will be that if you ever unmarry oft you car will go back to the E85 tune, the oft originally married to. Alternative in this case maybe to buy tactrix cable instead and flash whatever tune you want. or if you know somone with tactrix cable who can flash you to stock before you marry up new oft |
#907 | |
Drives: 2013 Scion FRS
"Chasing speed with patience" |
#908 |
Drives: GTS
Randon question, but anyone got an easy fix to turn the display upside down?
Is there a setting somewhere? |
#909 |
#910 | |
Drives: Toyota GT86
Verstuurd vanaf mijn Xperia L met Tapatalk
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
| WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 08:13 PM |
| Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 09:27 PM |
| FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 03:08 PM |
| FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 03:49 PM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 08:14 PM |
