Old 03-14-2019, 08:31 AM   #911
ML
ML's Avatar
Drives: 13 White MT FR-S
I’ve always wanted to get into arduinos, but this does not seem like a first time project. I guess it’s back to pulling the fuse.
Old 03-14-2019, 09:25 AM   #912
steve99
See here
http://www.ft86club.com/forums/showp...7&postcount=30
Old 05-17-2019, 11:19 PM   #913
FRS_2016
Drives: 2016 61K FR-S
ZA1JF00D
Uploading the stock ROM pulled from my MY2016 AT USDM FR-S (ZA1JF00D) in case anyone needs it.
Just flashed OFT stage 1 v4.03, it had a checksum error with the flash only definition I created (not sure why EcuFlash never asked for a checksum module in the definition creation wizard? ), so I flashed back to stock (without turning off the car) and tried again with Steve's K00G flash only xml from earlier in the thread with a few changes to suit my car and it worked great.
Big thanks to Steve!
File Type: zip 2016 Scion FR-S AT STOCK USDM ECU ROM ZA1JF00D.zip (543.1 KB, 167 views)
FRS_2016 is offline   Reply With Quote
Old 05-19-2019, 01:17 PM   #914
steve99
Thanks ill add that stock rom to lust in first post soon
Old 05-19-2019, 01:22 PM   #915
steve99
If youd caf was F00D auto , you should use K01I for auto not K00G as that is manual car rom
Old 05-19-2019, 07:51 PM   #916
FRS_2016
For flash only I used this
<?xml version="1.0" encoding="UTF-8"?>
<rom>
<romid>
<xmlid>ZA1JF00D</xmlid>
<internalidaddress>8000</internalidaddress>
<internalidstring>ZA1JF00D</internalidstring>
<caseid>8644387107</caseid>
<year>2013</year>
<market>AUDM</market>
<make>Subaru</make>
<model>BRZ</model>
<submodel>FA20</submodel>
<transmission>AT</transmission>
<flashmethod>subarubrz</flashmethod>
<memmodel>SH72531</memmodel>
<checksummodule>subarudbw</checksummodule>
</romid>
<include>32BITBASE</include>
</rom>
Old 07-03-2019, 11:36 PM   #917
steve99
Added 2017 Thailand manual K00R rom and USA auto F00D roms to stock rom lisy in first post
Old 07-23-2019, 07:03 AM   #918
dave-
Drives: 86 GT
Possible to use tactrix and RR to turn off abs and vsc like the 86nanny did?
Came to ask this....
Originally Posted by ermax View Post
The OFT does it by sending packets, not by changing the rom. You could write an app to send the CAN bus packets using the Tactrix to do all sorts of things but you can’t use RR to customize the rom and then flash it for a permanent fix.
Nuts! Though could it be done with BRZedit? Though the dev would need to know he sequence used by OFT/ECUtek to do it and they're not likely to share the info...
dave- is offline   Reply With Quote
Old 08-17-2019, 12:01 PM   #919
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
Quick question: is it possible to dump an Ecutek ROM? My 86 has an AVO Turbo-Kit with an Ecutek tune on it. Was just digging into my STIs ROM, as I had to make a few changes and was curious to look at the 86 tune. But for some reason ECUflash is throwing an error, everytime I try to read the ECU.
[16:54:42.735] using metadata XML ID read_subarush72531brz from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_subarush72531brz.xml
[16:54:42.747] J2534 API Version: 04.04
[16:54:42.747] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[16:54:42.747] Device Firmware Version: 1.17.4877
[16:54:42.747] Device Serial Number: TArX50nP
[16:54:47.706] reading vehicle info...
[16:54:47.714] CALID : ZA1JA01G
[16:54:47.722] CVN : E0E15E45
[16:54:47.726] VIN : JF1ZN6L81DG123456*
[16:54:47.844] starting programming session...
[16:54:47.848] interface close
*it is showing the actual VIN, just changed it for confidentiality reasons
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker
Flasher is offline   Reply With Quote
Old 08-17-2019, 09:29 PM   #920
steve99
No you canmpt read ecutek or brzedit tuned cars with tactrix, both those systems alter the seed key access routine to access ecu.
If the tuner would give you a copy of the unlocked ecutek rom, then you could chamge it but this would be unlikey​ to happen
Old 08-21-2019, 04:39 PM   #921
Flukester
Flukester's Avatar
Drives: 2019 BRZ - Raiu
Attaching a copy of my stock ROM (Cal ID ZA1JS10C), pulled from my 2019 BRZ 6MT USDM (Canada) with Red Manifold, in case anyone wants it.
Also, before messing up my car, I'm looking for a spare ECU. Please see my thread here: http://www.ft86club.com/forums/showthread.php?t=136476
Thanks
Mr.Fluke
File Type: zip 2019_BRZ_6MT_RedManifold_STOCK_ROM_ZA1JS10C.zip (588.0 KB, 151 views)
Flukester is offline   Reply With Quote
Old 10-13-2019, 02:20 AM   #922
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Hey guys. Does anyone know what it means when the status lights on the OP2 stay solid red and green when connected to the OBDII? I tried changing the SD card already but there is no difference; I cant log anymore. I also tried contact tactrix but I think their email is down.
D-VO is offline   Reply With Quote
Old 10-13-2019, 05:59 PM   #923
steve99
Check the obd connection by trting an ecu READ.
Make sure SD card is formatted fat 32 file system
Make sure the logcfg.txt is in the root directory and its name must be exact
If you edited the logcfg.txt tactrix coesnt like any control or formatting characters that some editors add.
try the original logcfg.txt file.
Make sure you jave latest version of ecuflash, one of the older versions the logging didnt work. So you need to update ecu flash then connect tactrix so it can update its firmware
Oh it wont log if it connected to computer must be standalone to log.
Check SD card see if it produces a logcfg.out file tgis may have some error messages in it
Old 10-14-2019, 03:27 PM   #924
D-VO
Well now that's interesting. The last set of data the OUT file had looked like this:
param name: Ram_GDI_Flow_Rate
param id: 0x00000000 <---WTH?
read width: 4 bytes
data width: 32 bits
data offset: 0 bits
float: 1
raw int: 0
signed int: 0
sign/magnitude int: 0
mode: 0x23
scaling: x
This was included in some of the RAM logging stuff that I added. I guess I forgot I did that. Anyway I removed those parameters that I added and I'm good to go again. Now on the thread I posted: http://www.ft86club.com/forums/showthread.php?t=137258
you asked that I log pulse width to see if it changes before the O2 or vice versa, which one is correct for logging pulse width on Za1jb01c?
;paramname = Base_Pulse_Width(ms?)
;paramid = 0xFFF89744
;isfloat = 1
;paramname = Fuel_Injector_1_Pulse_Width_4byteExt_E60
;paramid = 0xFFF887C8
;isfloat = 1
;paramname = Port_Injector_PW
;isfloat = 1
;scalingrpn = x,0.001,*
;paramname = Port_Injector_PW_Ram
;paramid = 0xFFF887D8
;isfloat = 1
;paramname = Direct_Injector_PW
;paramid = 0xFFF887E8
;isfloat = 1
;paramname = Direct_Injector_PW_Ram
;paramid = 0xFFF887F0
;isfloat = 1
They are commented out because I couldn't get them working right. Also, will the O2 sensor sway wildly and hold lean or rich for days like that with no codes?
Also, would the O2 sensor still be affecting fueling even though I have it set to forced open loop?
Thanks!
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
