Old 10-02-2014, 04:08 PM   #9731
TilesMeague
TilesMeague's Avatar
Drives: 2013 SSM BRZ
Originally Posted by RobertPaulson View Post
so open the driver side door, then hold down on the lock and panic button on the key fob. wait about 3-5 seconds and you'll hear the car beep and the setting will be changed.
share this with your dealer guys so they'll know the next time a customer comes in with this request.
Thank you so much! I knew there had to be a way to do it.
Drop several gears and become slightly further away
TilesMeague is offline   Reply With Quote
Old 10-02-2014, 05:36 PM   #9732
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
Originally Posted by pinski View Post
Thanks!! Going to try this later today.
np, i knew there had to be a way too and finally found it while taking a dump the other morning after having my way with Marla.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 10-02-2014, 08:17 PM   #9733
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Now a single piece, alcantara. Spent about 4 hours. First time wrapping suede.
Totally ripped of da @Jive Turkey
Only the wheel plastic and buttons left to swap!
Old 10-02-2014, 09:28 PM   #9734
wallace03
wallace03's Avatar
Drives: WRB BRZ
Looks good, what kind of suede did yo use? Where did you get it?
wallace03 is offline   Reply With Quote
Old 10-02-2014, 10:33 PM   #9735
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
looks good man! one piece just is SO much cleaner. i remember when i first wrapped mine, looks much easier than it is
Jive Turkey is offline   Reply With Quote
Old 10-02-2014, 11:19 PM   #9736
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
@Overland Designs ...Your up!
He needs some factory black alcantara suede stat! IIRC they sell by the meter. The roll is 36" wide so one meter can do 3 sets of dash panels or almost all your silver (if brz) trim pieces.
Old 10-03-2014, 04:54 AM   #9737
GGVF
GGVF's Avatar
Drives: 2014 BRZ Limited DGM
Finally got a pair of helix side markers to clean up the look of the front end, not a big fan of the orange side markers. Quick minute video I made for a youtube build journal I'm going to start doing for my car.
GGVF is offline   Reply With Quote
Old 10-03-2014, 11:11 PM   #9738
kberkel
kberkel's Avatar
Got a letter from my Apartment manager this week.
Several neighbors complaining about my Top Speed catback in the morning (and I don't leave for work till 8am).
When I start it the car hovers at 1500RPM or whatever for 1 minute.. it sounds like a megaphone. Does it hurt to start and drive right away with low RPMs? I noticed if I start it and start backing out right away, the idle settles within about 3 seconds. Is there a purpose for the long high idle?
Should I fight it? My apartment doesn't have "quiet hours".. but 8AM seems late enough for noise right?
kberkel is offline   Reply With Quote
Old 10-03-2014, 11:28 PM   #9739
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Just don't get on the gas hard until oil temp is up and it isn't a problem.
8am is definitely late enough for noise I would say.
Old 10-03-2014, 11:30 PM   #9740
t.chk
Drives: Subaru BRZ Limited
Where I live there are 'reduced noise pollution' time frames usually till 9:30am. Nothing loud, mowing the lawn, sawing, running loud catback for 2s before then. So it might not be your apartment you have to be compliant with it is your localities (your manager is being nice before they report you to the locals).
But the high idle is just to get everything warmed up so you can beat on it sooner...since beating on a cold engine is bad things to do to a car 101.
I feel there should be a way to turn that off. I'd check your manual.
t.chk is offline   Reply With Quote
Old 10-04-2014, 12:31 AM   #9741
Andrew025
Andrew025's Avatar
There is a thread that details how to reduce the cold start through tuning.
Old 10-04-2014, 01:09 AM   #9742
alan.chalkley
Drives: 4wd zooks
Originally Posted by Turkish View Post
Michelin Pilot Super Sports about to be installed. Going with 225/45r17.
On the stock 17x7 rims?
Let us know how this goes!
alan.chalkley is offline   Reply With Quote
Old 10-04-2014, 01:33 AM   #9743
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
The high-rpm on cold start is just to get the catalysts warmed up, because they are most effective at high temperature (SCIENCE!).
You can just start up, wait a second or two for oil to circulate, and then drive off before the rpm drops.
aegisdrgn is offline   Reply With Quote
Old 10-04-2014, 03:04 AM   #9744
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
FYI, 225/45/17 on stock wheels fits without an issue
