#85 |
Anti stance.
#86 |
Drives: 2017 BRZ
It seems we have a good many folks who would pull the trigger on these if the gains are decent and/or it sounds cool. I think my threshold would be an independently verified +15 rwhp. Does SARD ever post here? I'm not really familiar with them. Seems like they would have some graphs to go with their marketing.
#87 |
Only users lose drugs.
Drives: All the time
The Greddy and SARD system both seem to have similar runner volume, at first eyeball...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#88 |
Drives: 2014 GT86
To me it also would be of interest how ITB gains stack or not with other bolton gains. It seemed that there is some "limit" of diminishing returns of +40whp that could be reached with different boltons (and tune of course) .. but wondering if ITB may let to get above it? All the other NA parts are already tried after all. Snorkel, filter, intake, spacers, headers of different designs, overpipe, frontpipe, catbacks, cat deletes, straight exits, side or above bonnet exits and mirriads of combinations of these parts .. so what interests me if there is anything else that may add up NA performance above that .. OR if it's simpler/cheaper to get to that limit by other boltons.
#89 |
Drives: GTS 86
What is the point of ITB's without any work on the head? the gains will be limited by the head flow straight off the bat! Or at least different cams...with that said however, you would have to be crazy fanatic for NA to spend this kind of coin that is in the supercharger territory already!! My opinion though!
Very cool to see these finally coming out! |
#90 | |
The Dictater
Drives: '13 Red Scion FRS
ITBs themselves are just going to increase throttle response, and probably quite significantly for a boxer. The interesting bit is what ITBs let you do with the rest of the intake system for both NA and FI. Say you were to make a larger intake plenum for some reason without changing anything else on the car. When you open the (single) throttle, the higher pressure air has to fill that space first before you can fill the cylinders. With ITBs you can tune the intake(s) however you want, and still have fantastic throttle response. It would be interesting to see a dual throttle intake with one throttle body per bank. Granted, it would be a hard sell since I don't expect there to be much of a price difference... Ramble ramble ramble... |
#91 |
#92 |
Our heads flow pretty well as it turns out. The cams are limiting for NA but still pretty aggressive for stock. There was a shop that ran 13.5 comp pistons with an other wise stock block and made 215-220whp. This is with our standard E85, tune and exhaust mods our course.
#93 | |
Anti stance.
Let me guess, CSG will be carrying one of these two offerings for the FA20? |
#94 |
We get it - you like being a douche. You had ample opportunity to prove us wrong, but bless your little heart, you kept at it and there's really no question about it at this point. Nice work.
#95 |
Anti stance.
Proved wrong that 45hp is the typical gain on an S2000 with ITBs though.
#96 |
Drives: 15 BRZ LTD, 05 FXT
Wonderful accomplishment.
Maybe by the next 7 pages of this nonsense thread, SARD or Greddy will actually release some dyno charts or someone can get their hands on one so we can actually see the value, or lack thereof, of the components...
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#97 |
Drives: none
I don't understand the obsession with HP/Torque gains... That's a very crude way to measure the value of a mod. WOT throttle dyno runs are fine for showing raw power increase but they are incapable of measuring things like throttle response. Sometimes a modification is worth it to the buyer just because it moves the torque curve around a little bit. People spend money on all sorts of mods that cannot show gains on a dyno: lightweight flywheels, lightweight pulleys, carbon fiber driveshafts, different rear-end ratios, you name it.
Why bash the product? If the vendor (SARD or Greddy) were in here making wild claims about the product then there might be something to say. If this mod isn't for you, then move along. People spend twice as much as these things cost just on paint and body work all the time. No one is forcing anyone to buy this product. -Matt |
#98 | |
![]() This thread has totally derailed from 'I wonder how these components will perform' into absolute nonsense.
| Part throttle faster than full throttle | brn12345 | Engine, Exhaust, Transmission | 38 | 10-21-2021 01:20 PM |
| SARD CF Intake Pipe, SARD Oil Catch Can, TRD Oil Cap, Rad Cap, Battery Clamp | Trojan_SC | Engine, Exhaust, Bolt-Ons | 19 | 03-28-2018 08:52 PM |
| Bad news good news | ls1ac | BRZ First-Gen (2012+) — General Topics | 2 | 10-01-2016 10:11 PM |
| SARD 86 GT1 Body Kit + SARD LSR Wing | nigel-jdmparts | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 04-27-2015 01:41 PM |
