Old 01-06-2014, 08:18 PM   #85
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by dren View Post
The check valve is a few inches after the bend towards the engine. It is about an inch long.
And now that I think about it, the check valve just makes sure you have power brakes if the engine dies when driving. It's a safety feature. I'll definitely get a replacement.
I ran without a check valve for a bit. It doesn't affect your driving unless you are driving spiritedly or on the track. Quick transitions from WOT to brakes will reveal a super hard brake pedal which will get softer after the cylinder fills with vacuum again. Def get a check valve if you do this type of driving.
I couldn't find any the right size and the hose from subaru was over $100 so I found this from another thread on here. It works perfectly and is cheap as hell:
http://www.usplastic.com/catalog/ite...rtnumber=64175
64175 is the part number. I bought a bunch.
Old 01-07-2014, 01:14 PM   #86
dren
I ordered the replacement hose from Subaru online store and it was $24. I'll receive it tomorrow so I'll let you know if it's the right part...
dren is offline   Reply With Quote
Old 01-07-2014, 01:20 PM   #87
dren
Originally Posted by digital_assassin View Post
Glad your up and running Dren! Are you going to have a dyno pull done to see where things are at?
I am not going to have a dyno pull, but since it is stock and I am running the below tune for stock, it should be this:
Old 01-07-2014, 01:27 PM   #88
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
I'm still waiting on injectors, oil cooler and some other bits to show up before tackling the install. I only want to pull the bumper once.
cobrabyte is offline   Reply With Quote
Old 01-07-2014, 02:30 PM   #89
sw20kosh
Here is unbiased 3rd party dynojet of the kit with a header:
Old 01-07-2014, 03:56 PM   #90
sw20kosh
Originally Posted by Ralph Spoilsport View Post
E85?
No, neither this graph nor the graph I posted in last page were E85. They were pump fuel.
Kraftwerks released an E85 graph that showed ~350 whp I believe.
Old 01-07-2014, 04:04 PM   #91
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Me confused. Okay, there's this http://cms.kraftwerksusa.com/id/954/...-Dyno-Updates/ 338 HP E85, header, etc. (fuel upgrades, one would suspect, but not listed...) vs 157 HP baseline stock.
Looking forward to seeing others results. It does seem a little ahhhhh, optimistic.
Ralph Spoilsport is offline   Reply With Quote
Old 01-08-2014, 02:27 AM   #92
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
This is my car and I have stock headers.
digital_assassin is offline   Reply With Quote
Old 01-08-2014, 08:11 AM   #93
Ralph Spoilsport
Thanks for clarifying. I like your numbers and this kit.
Old 01-08-2014, 09:48 AM   #94
dren
From what I have seen here and the Delicious Tuning 91 octane on a stock car graph I posted (and tune I am using) this kit does produce good numbers. 100+ hp at peak over stock at the wheels. If you back calculate assuming 22% losses (based this on the 200hp motor rating and 157hp at the wheels) the motor is making around 340-350hp.
Old 01-08-2014, 01:07 PM   #95
digital_assassin
This is a conservative tune on winter gas so numbers should change in the summer. On both the KW kit and the JR kit Bob kept our Rev Limiter at 7,400 and I can't recall for sure if this could be raised with higher flowing injectors and fuel pump or not, but I recall him saying he was having issues getting enough fuel.
Old 01-08-2014, 02:45 PM   #96
sw20kosh
If you look at your graph, it would make no sense to raise the limiter.
Old 01-08-2014, 05:16 PM   #97
digital_assassin
I've been testing the toothed pulleys on the kit with Kraftwerks and the results are very good. Here is a video of the kit with toothed pulleys at idle. Pretty big difference. I close the hood at the last part of the video and it's barely detectable when idling. When you get on it the whine is there though. Sounds great now! A finalized version will be going into production and will be on the streets soon.
[ame="http://youtu.be/JoqCUIKY3D8"]http://youtu.be/JoqCUIKY3D8[/ame]
Old 01-08-2014, 05:19 PM   #98
You'll need more fuel pressure to make more power; that's fairly easy. The larger concern, IMO, is how weak the valve springs are; I'm personally against raising the redline without some headwork.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
