#85 |
Drives: gts 86
They are not lying, if the car is stock it would fit without much issues
#86 |
Drives: 2013 Scion FR-S Asphault
I just went with the Skunk2 ultra radiator and the sandwich plate. I know the radiator has the 1/2 fittings, but could not find the connection size anywhere for the plate. It's not even listed on Skunk2's site. I would like to have my fittings ordered sonic not waiting another week to get them after these parts arrive. Does anyone know what size or the links to where you bought your lines and fittings? Any help is greatly appreciated!!
#87 | |
That Guy
Drives: 2013 asphalt FRS MT
#88 |
Thanks Calum
#89 | |
#90 |
Drives: 2013 WRB BRZ Sport Tech
No it didn't. Stay away from this rad. The design is terrible. I sent mine back.
installing KRAFTWERKS C38 FROM RICKSPECD MOTOEAST TUNE & SKUNK2 ULTRA RAD / SANDWICH PLATE / GRAMS 550cc
JDL UEL PERRIN EXHAUST 2.5" OP 3" CATTED F 3" CATBACK - PERRIN MOUNTS PERRIN PULLEY KIT WHITELINE BUSHINGS WILDWOOD BBK ACT CLUTCH & FLYWHEEL KW V3 MTEC KARTBOY SS SEIBON ROOF SPOILER & FRONT LIP 57XTREME 18x9.5 +40 W/ 255/55/R18 MICHELIN PSS |
#91 |
![]() Skunk2 originally told me that the thread was 3/4 as well. Which is not correct. This rad was nice. Quality was very good and it is indeed beefy. The only way to get this rad to fit is to trim and notch ur shroud and notch ur frame rail. . If u have a c38 kit this will be a extremely extremely tight. i sent mine back. I have to give skunk2 a big thumbs up as they took the rad back and gave me some good customer service.
#92 |
http://www.spencerfabrication.square...relocation-kit
I can see this working as it would push the rad forward a bit so the outlet should clear the side of the frame rail.
#93 |
Here is the list of parts I used for this setup. I took pics but I can't get them to upload.
1 1/2npt male to 8an male 1 1/2npt male to 8an male 90 degree 2 90 degree 8an hose fittings 2 45 degree 8an hose fittings 3 ft 8an hose 2 8an male to 8am male fittings I used a hole saw and cut out a little of my headlight mounting bracket. Fan shroud still has to be cut but I'm sure I will need to modify again for the turbo. I'll do it all at once when I get to that point. Last edited by g0odspeed; 10-28-2015 at 01:09 PM. |
| Skunk2 Header? | FirestormFRS | Engine, Exhaust, Transmission | 69 | 10-11-2019 10:42 AM |
| Skunk2 Review. | FirestormFRS | Engine, Exhaust, Transmission | 1 | 12-31-2014 09:55 PM |
| Skunk2 BRZ Intake Results! | Xero-Limit | Engine, Exhaust, Transmission | 21 | 10-20-2014 02:43 PM |
| New skunk2 frs brz cold air intake | 831GT86 | Engine, Exhaust, Transmission | 17 | 09-09-2014 05:09 PM |
| FS: Robispec Radiator (Massive radiator and liquid to liquid oil cooler in one) | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 15 | 05-27-2014 01:18 PM |
