Old 02-08-2024, 11:06 AM   #9927
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by Stephen W. View Post
As for small pedal boxes the Twins have huge space compared to my “new to me” 30 year old Super Seven.
Yep. Small in an Exige too. Have to wear ballet slippers.
Old 02-08-2024, 11:25 AM   #9928
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Have too...
Old 02-08-2024, 11:30 AM   #9929
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
Yep but, you still have more room than I will in my seven. You at least have room for a dead pedal to rest your left foot on. I'll have to do some adjusting and modding to move the brake and clutch pedals to the right. This so I can turn my ankle and slid my left foot past the clutch like in the other Seven that missed out on.
Old 02-08-2024, 11:44 PM   #9930
cjd
cjd's Avatar
Drives: 2017 BRZ
Huh. Really now, size doesn't matter. It's all in the technique.
Old 02-09-2024, 03:46 PM   #9931
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I guess I shouldn’t say the pedal box is too small. With the brake pedal so close to the gas it is very uncomfortable to get my feet that close together. Of course I would have a difficult time with heel toe. Should probably come up with a brake pedal cover that extends to the left.
Old 02-09-2024, 05:09 PM   #9932
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Old 02-09-2024, 05:14 PM   #9933
Ultramaroon
not playing cards
Ultramaroon's Avatar
Wow!
Old 02-09-2024, 07:07 PM   #9934
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
I knew I must’ve had a leak somewhere on the exhaust and sure as shit I did. Replaced the gaskets the Motiv OP came with for some grimspeed ones, tightened everything, but the leak is still there, between the OP and the front pipe. Maybe a double gasket?
Old 02-09-2024, 07:21 PM   #9935
Ultramaroon
not playing cards
Double gasket is ghetto. Pull them both and find the issue with Prussian blue or dry erase marker. I bet you can work it out with proper use of a bastard file. Lap the two faces together if you want to be really artistic.
Old 02-09-2024, 07:33 PM   #9936
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Double gasket might work. If the flanges are bent or warped in any way though it won't help, which is likely the issue.
While my exhaust never leaked to begin with (perrin resonated), I read that adding a bit of copper high temp RTV to a flat gasket exhaust connection can help ensure a good seal. So I did... 3 years later and it's never leaked. The annoying part was having to let it sit and cure for 24 hours before I could start the car again.
Now it may not have ever leaked without it... but it didn't hurt.
wolffbite is offline   Reply With Quote
Old 02-09-2024, 07:35 PM   #9937
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Remflex. Warped AF flanges. Reflex ain’t no care.
https://catalog.remflex.com/category_s/31.htm
proper way is to lap the flanges
Old 02-09-2024, 08:13 PM   #9938
spcmafia
spcmafia's Avatar
Which one am I looking at. I don’t see anything for the FA20
Old 02-09-2024, 08:23 PM   #9939
spcmafia
spcmafia's Avatar
Im assuming you used the RTV seal in lieu of the gasket?
Old 02-09-2024, 08:52 PM   #9940
Ultramaroon
not playing cards
lol props those look dope af
cnc'r? i barely know er!, have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money
Random Thoughts - Part Deux [NO POLITICS] Ultramaroon Off-Topic Lounge [WARNING: NO POLITICS] 84004 03-07-2022 12:00 PM
OEM BRZ spark plug part number? qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 05-27-2017 12:33 AM
Random search on bing sdwagonjp Off-Topic Lounge [WARNING: NO POLITICS] 11 11-19-2014 08:35 PM
