#10025 |
Drives: 2017 BRZ Limited PP
And there are examples of early adoption with specific applications such as hybrid systems with small displacement for the IC aspects. They use the electric SC to fill in spots just like our engine uses it where it can. I fully believe that as long as development of IC continues there will be a spot for the electric SC.
I am curious what the inside story is with Rob though. Seems like progress has slowed to a crawl. Honestly I have given up hope I would ever get the phantom. I'm either going to never get fi or plunk down money get a Jackson or Kraftwerks. Sent from my HTC6535LVW using Tapatalk |
#10026 | |
Drives: White 2014 BRZ
A couple hundred kits is not "mass production" lmao. I'm a mechanical engineer by day and yes I see everyone's frustration. Rob truly does have a good amount people saying "take my money". He apparently doesn't need the money. I can't see this kit being all that difficult to make. Send me the drawings I'll get it made lol.
JDL Turbo kit - Ecutek, HRI tuned.
#10027 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
To all who are waiting and are currently frustrated... Realize everytime we have had a slow down, new things have been added.
I'm sure something is being cooked up and I'm sure we will all benefit from it. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#10028 |
Time Traveller
True, IMO manufacturing is likely not the reason for the slow product turn. In my opinion, the test cycle for new iterations of the Phantom kit is appropriately long for the importance of the device. From what I know, this longer test cycle creates a more reliable, better performing product that requires less user maintenance and customer support frustrations. Remember, this is a multi-thousand watt device that people strap to their $30k cars and use at high stress and speeds. This is a responsibility Rob doesn't seem to be willing to underestimate or cut corners on. I for one am thankful. The current Phantom ESC 2.0 kit is very good. The version that many people on the waiting list end up with may be even better due to this long test cycle and the patience of those who choose to wait it out. Hang in there people. There's a good reason no one else has ever been able to pull off ESC's in the aftermarket with a high degree of success. It's a marathon, not a sprint. Not at least until after you get your kits.
Last edited by DAEMANO; 06-11-2016 at 01:15 PM. Reason: corrected error - volt to watt - Thanks Target! |
#10029 | |
the doers do
However, please dont take this as a complaint, as more of a suggestion for improvement: A little communication would go a long way. If Rob made a comment, not even an announcement, it would sooth a lot of savage souls here. Maybe even a pm or an email saying "hey! thanks for believing in me and my product. Thanks for your patience but X is why its taking so long. It will be worth the wait" In this day and age where "kickstarter" type efforts often fizzle, its easy to 'look away' when there is -0- comms. All kinds of respect to the doer though! |
#10030 |
Drives: 2013 Asphalt 6spd
I'm with you but, and maybe I'm being nit-picky here:
that doesn't sound right to me.
#10031 |
Drives: Stage 2 NA E85 ultramarine FRS
#10032 | |
Drives: n/a
@fenton one clarification: was the list you posted in sequence from first to last, or last to first? Sent from my HTC One M9 using Tapatalk |
#10033 |
after thinking about it I realized I had no idea how a brushless motor works. After some youtube videos I get the basics, but without specific motor details I can't find what they typical drive voltage should be, I can figure out the current based on the power wire size, but again without specifics I can't figure out the motor impedance/reactance. So in the end, I really have no idea what kind of signal is coming out of the controller.
#10034 |
It's multi-thousand Watt, just 28 volts. (In three phase)
If I say yes, will that make you think I understand?
#10035 |
wait, multi thousand watt? or multi thousand volt? I don't doubt at all multi thousand Watt, as a microwave is usually at least 1500 Watt. I don't know anything about the controller and for all I know it could have some step-up transformers in it and be out putting thousands of volts like DAEMANO said, I just didn't think it did which is why I even commented. But if it was misspoke and was supposed to be Watt then yeah, completely understandable.
E=I.R (voltage = current times resistance) and P=I.E (power = current times voltage) max current can't be above 80A due to 8awg wire according to random google charts. P=I.E converts to E=P/I so random estimate of 2,500W for power over 80A = 31.25V ~ 28V shown on the volt meter.. This is just a WAG, you wouldn't want to max out your cable capacity so you will run less than 80A and if it is 28V and only 70A you end up with just under 2,000W I'm just talking out loud here because It has been so many years since school and theory. I just think it is interesting getting into how this actually works. This is the video I watched on the motors: [ame="https://www.youtube.com/watch?v=ZAY5JInyHXY"]Brushless DC Motors & Control - How it Works (Part 1 of 2) - YouTube[/ame]
#10036 |
Drives: 2013 86
The Phantom supercharger throttle activation
Adjusting my Phantom electric supercharger throttle activation switch to make the system safer.
[ame="https://www.youtube.com/watch?v=yBq1uyrD6GA"]The Phantom supercharger throttle activation - YouTube[/ame] |
#10037 | |
Time Traveller
#10038 |
Drives: 93'Camry, 82'Corolla, 76' Celica
Just a quick note from one of the first "developement" testers:
Hey my ancient 1993 V-6 Camry is still running strong with the first Version 1.0 Phantom Supercharger, after 2.5 years, and currently at 374K Km.
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
