Old 10-11-2014, 10:04 AM   #1009
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
Did it clear itself or did you have to clear it? What was the time between the first and second CELs?
Other than your catback, do you have any other breathing mods?
It was about a month btwn the CELs. I don't drive that much. I didn't try and let it clear itself. What I did was pull over to check what the code was for and cleared it.
I only have the Perrin 3" cat back and the intake that came with the JRSC.
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 10-11-2014, 11:46 AM   #1010
fasteddy
Originally Posted by Dezoris View Post
Its a Mocal plate, despite its thermostat its not fully closed to prevent air lock so there is always trickle flow to the cooler.
Been through 3 plates now and talked to Mocal directly doing testing.
Problem started in winter and I removed the plate during that time.
If you are on the track and depending on the track and oil used it would be easy to hit 245F in a 30 minute session if you are flat out.
Again depends on the fuel, our tracks all run Sunoco race fuels. At autobahn there are race teams onsite who put warnings out for street cars to only use the 100+ octane without cats. They have had plenty of people with issues. It started with guys loosing cats on a Ferrari or GT3 so they warn everyone.
You don't need race fuel on a tune designed for 91/92 octane if the tune is sound, its just insurance. You should be able to know this logging right away on street and first track session.
Maybe I should disconnect the cooler for the winter? I wont be going to the track between October and May anyways and I should not need the oil cooler for street driving.
We can get 93 octane here, but not everywhere. Most of the time I am stuck filling up with 91.
What problem did you have in the winter?
Pat
fasteddy is offline   Reply With Quote
Old 10-11-2014, 12:12 PM   #1011
Dezoris
Dezoris's Avatar
Pat
Took forever for oil to get up to temp and clung around 175. Never was able to get above 195F. Never able to reach 212F to get any moisture out of oil.
Not a huge issue 0w20. But stock oil temps without cooler are normally 195F to 205F without cooler. In winter and up to 212F on a hard run.
If you are running all winter daily just unplug sandwich plate and plug lines. Its not absolutely needed mind you.
I cant speak for JRSC in winter but the Rotrex oil is far more versitile than Vortech so you wont have issues.
Old 10-11-2014, 01:10 PM   #1012
fasteddy
Ok Thanks, maybe I can get them to make me a set of oil cooler lines with shutoff valves built in, that would keep things really simple.
Pat
Old 10-14-2014, 01:18 PM   #1013
ofuts
Drives: 2013 Toyota 86 MT
Hey, i will install the kit soon, one of friends told me that i need to change the clutch too, well he olso told me to change many other motor components if i install SC kit to prevent blowing up the engine, so i m not sure if he is correct.
ofuts is offline   Reply With Quote
Old 10-14-2014, 03:23 PM   #1014
The kit is plug and play
Old 10-14-2014, 03:28 PM   #1015
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
There is no need to change any internal engine components on this engine. These engines are solid/reliable (with a proper tune) to about 350+ whp, versus stock numbers of 175whp.
You do need a clutch around 300whp but usually you will only reach this with E85. On 91 octane you will not need a clutch, the stock one works perfectly. As CSG stated, this is plug and play.
Cheers,
William Knose
Old 10-16-2014, 02:43 PM   #1016
ofuts
How about the recommended fuel type after the kit?
I only can find 93 or 97 octane here.
Old 10-16-2014, 03:12 PM   #1017
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Minimum of 91 octane. 93 or higher is fine.
JDMChris is offline   Reply With Quote
Old 10-16-2014, 05:03 PM   #1018
SamS
Drives: '13 BRZ, '99 Forester,'06 Duc S2R1k
97 RON is about 92 AKI, so you should be okay using that.
SamS is offline   Reply With Quote
Old 10-17-2014, 02:02 PM   #1019
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
How is everyone's JR Kit running?
We have all had the kit for several thousands miles now...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 10-17-2014, 03:18 PM   #1020
alpax
alpax's Avatar
Drives: 2013 Subaru BRZ AT JRSC
It's been one month, about 1200km supercharged, and I got my first CEL yesterday. Seems like the same what @Xerious mentioned just recently. The fault code is P0172: System too Rich (Bank 1).
It was actually a bit scary: I was accelerating from a traffic light (not a hard launch, just normal start), and the car kind of choked, and hesitated for a bit, the engine light and the traction-control lights came on, but in a couple of seconds the engine continued working normally. I stopped soon, checked the fault codes with the Torque, and found that P0172 code. Came home in 5 minutes, visually inspected the engine and the SC system - everything looked normal. The car started and worked without noticeable issues.
I cleared the code to see if it would come up again, and drove to work today - haven't noticed any issues.
I can get some logs from the ECU with the Torque, but what should check? There are Fuel Trim Bank 1 Long Term and Short Term sensors, I guess those are the ones, but what values would be expected for those?
What else to look for?
alpax is offline   Reply With Quote
Old 10-17-2014, 03:20 PM   #1021
Xerious
Xerious's Avatar
I just hit 5k on mine and did an oil change.
My Build
Old 10-17-2014, 03:22 PM   #1022
Xerious
Xerious's Avatar
That is exactly what happened to me. It hasn't happened since but I've had two total in 5k miles.
My Build
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
