Old 02-08-2022, 04:01 AM   #1023
tomm.brz
Drives: brz 2017 hksv2
yes, pull timings there from base timing B table
Old 02-08-2022, 11:59 AM   #1024
15WhiteFRS
Drives: 15 FRS
look at the log screen when doing read will tell you CALID VIN and CVN
CAL ID ZA1JD00C
CVN 0E382D50
15WhiteFRS is offline   Reply With Quote
Old 02-08-2022, 02:25 PM   #1025
15WhiteFRS
Drives: 15 FRS
How do I log if romraider logger doesn't work? Does ecu flash log?
Old 02-08-2022, 02:30 PM   #1026
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Put a small microsd card in the tactrix, load in a logging file with your own settings, and it will log onto the tactrix unit itself. There's a tutorial somewhere around here.
Old 02-08-2022, 03:38 PM   #1027
15WhiteFRS
Drives: 15 FRS
It says I need romraider logger working.
How are people logging ?
Old 02-08-2022, 04:49 PM   #1028
EAGLE5
Dismember
EAGLE5's Avatar
Go to the start of this thread then control-f logcfg.txt
RomRaider is if you want to watch on RomRaider. But the ECUFlash can to it all solo and save to a csv on the flash drive. Then you load the CSV into the computer to read it without needing romraider.
Old 02-08-2022, 06:10 PM   #1029
15WhiteFRS
Drives: 15 FRS
So what I just drop the the logcfg.txt file on the fat32 sd card, put it in the tacktrix, then press the defogger?
Old 02-08-2022, 09:17 PM   #1030
15WhiteFRS
Drives: 15 FRS
Man I can't believe how difficult it is to tune these cars.
I couldn't get it to log. The tacktrix stays yellow
Edit. I got an .out log
Old 02-08-2022, 09:55 PM   #1031
EAGLE5
Dismember
EAGLE5's Avatar
Sounds like you're figuring it out. Tactrix ain't easy, but it is cheap.
Old 02-10-2022, 05:25 PM   #1032
15WhiteFRS
Drives: 15 FRS
Would anyone happen to know if it's possible to flash an v4..03 oft tune with the same ecu calib id?
Would I be able to edit the tune in romraider with the oft definitions provided from oft and flash the car with tacktrix
CAL ID ZA1JD00C
CVN 0E382D50
Old 02-10-2022, 08:43 PM   #1033
Ultramaroon
not playing cards
Ultramaroon's Avatar
gotta crawl before walking. Don't even think about flashing until you can log.
Next step is to be able to pull a good copy of your stock rom. That is as far as I've gotten to this point. At least I am able to open it with romraider. I haven't yet had the balls to write back.
Old 02-10-2022, 08:58 PM   #1034
15WhiteFRS
Drives: 15 FRS
I know how to log. Just can't seem to get rom raider to work with 64-bit Java. I used to flash and log my WRX on my old computer but it is way easier than a 86.
Old 02-10-2022, 10:00 PM   #1035
Ultramaroon
not playing cards
I know how to log.
Well, if it was your WRX then we wouldn't be having this pleasant exchange now, would we?
Old 02-10-2022, 10:11 PM   #1036
Compelica
Compelica's Avatar
Drives: 86 GT
CAL ID ZA1JD00C
CVN 0E382D50
All tunes from OFT are using the same 'internal' calibration ID, despite the number of calibrations on the OFT website - this calibration ID only differs if you're on a manual/auto, and whether its a pre-facelift/facelift. Since you are on D00C (which is a 2014 6MT on the OFT site) just take the ZA1JA01G tune and definitions from there and open it in Romraider.
Make sure to back up your tune and read the first page to figure out what to do if the flash fails for some reason.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
