#1023 |
Drives: UK GT86
It's just what it does. There are different regions where LTFT is set, it's not a single figure for the entire range.
.: Stealth 86 :.
#1024 |
#1025 |
Drives: Scion FRS
#1026 |
Drives: Scion FRS
i was playing around with romriader and compared the stage 1 and stage 2 UEL tune,
with the stage 2, why are alot of the values for everything 0? |
#1027 | |
Drives: Scion FRS
this time my LTFT is always around 14, i believe i do need to change the MAF scaling. thank you for checking this for me, |
#1028 |
Drives: UK GT86
if you're comaring them, it shows you the difference so 0 means no change. The menu of the open table has an option to turn that off to see the actual values.
.: Stealth 86 :.
#1029 | |
Drives: Scion FRS
I meant compare just as in opening both maps up to look at them indivicidually Sorry for the misunderstanding |
#1030 | |
if you post your logs up to www.datazap.me they are much easier to read in graphical form. Yes look like maf scaling would benefit you ltft varying from -6 to plus 10 or more. could not see any full throttle run to redline in that log though |
#1031 |
Drives: 2016 Steel AT FRS
Is the template added at the bottom of the first post still the most current? I am having the 0 IAM issue and am wondering if cal file "F00D" isn't current.
Edit: No MAF voltage either, probably need an update. What would be the best way to contact OFT where they aren't swamped with messages? Last edited by Weigaldo; 06-24-2017 at 07:36 PM. |
#1032 | |
Drives: 2016 FR-S
#1033 |
A potentially dumb question, but with the IAM not registering, wouldn't I be able to just monitor the timing to determine if knock is occurring? It would go negative right?
#1034 | |||
Drives: '15 BRZ RA
If IAM monitor is not working, then you can derive the value from the KC Learned parameter. The latter is NOT knock, but the knock correction learned ignition advance. It is derived from the "Knock Correction Advance Max A" table in ROM and multiplied by IAM and subtract FLKC. So, you'll need to monitor Engine Load, Engine Speed (RPM), KC Learned and FLKC. You'll need to have also the table values of "Knock Correction Advance Max A". |
#1035 | |
#1036 |
Drives: UK GT86
.: Stealth 86 :.
| WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 08:13 PM |
| Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 09:27 PM |
| FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 03:08 PM |
| FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 03:49 PM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 08:14 PM |
