#10781 | ||
Drives: 2013 Asphalt 6spd
my battery mount wouldn't be track legal, but it does what I wanted it to while not damaging the stock interior. I used 2ga welding wire from northern tool I think, very flexible and thick protective sheathing. I went kind of overboard with the double grounds. I eventually swapped out to an AGM battery when the factory starter batt died in late 2017, but otherwise I haven't had any problems. Still running on the original dump packs. I probably need to do another datalog run to see if I am still hitting the same boost levels. I'll try to get good copies from photobucket if you want to see the pictures for ideas.
#10782 | |
Sent from my GM1915 using Tapatalk |
#10783 | |
#10784 |
Drives: 2017 toyota 86
You running tandem or parallel? The torqamps looked to surge pretty bad in parallel. Also could look at some sort of bypass valve to bring in air when off boost so they aren’t such a bottleneck, as long as everything is pre maf it wont effect air reading. Just some thoughts. Interested in seeing what you end up doing.
#10785 | |
#10786 | |
Your idea should work fine. But you need some sort of bypass valve so under boost the “open filter” side is closed so boost won’t leak out, but under vacuum its open to bypass the twin chargers. This could be a low end torque monster. And with all that extra weight in the trunk to help traction. Sounds like a good time. |
#10787 | |
#10788 | |
![]() Sent from my GM1915 using Tapatalk |
#10789 | |
#10790 |
#10791 | |
https://www.ebay.com/i/173877579100?...yABEgJKmfD_BwE |
#10792 | |
#10793 | |
i don't know how beneficial an intercooler will be with these, i don't see them generating too much heat. and then with how you would probably have to route the pluming for everything you will create a lot of lag and possibly less boost. negating most of the benefit of running two. you could try to do a air to water setup so you could have the rad in the front bumper and then have a small heat exchanger post charger so its still a pretty straight shot to the manifold. probably a lot less headache routing everything. or just do WMI and get the cooling and octane increase with having no air restrictions in the system. |
#10794 | |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 05:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 07:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 08:07 AM |
