Old 09-22-2020, 02:22 AM   #10963
BlOody_BoOger
BlOody_BoOger's Avatar
Twin phantom supercharger Update!
So it's been a lil while since I've updated what I've done to the twin phantom setup, and most of it has just been trying different things to see what would get me the best results so now that I've finally came to a final setup I will list the items needed to complete this build and total prices.
Originally the idea was to run an intercooler and torqamps bypass valve. The intercooler was because at 7psi I figured I would be pushing the same amount as jrsc low boost pulley, sprintex and vortech superchargers, and all these have some sort of cooling. So since I would be running an intercooler it would have been ideal to have the bypass valve in order to help with low rpm restrictions due to the intercooler and twin phantoms. Well we decided not to go with the intercooler because we found the intercooler to rob us of ~2psi and the loss in psi vs the temps wasn't worth it. So intercooler had to go. Then after speaking with jelke the guy who developed the torqamp. He suggested that since I was no longer running an intercooler than I really didn't need the bypass valve. Also removing the bypass valve I would no longer be taking in hot engine bay air since now I would only be running the filter inside the front bumper. So bypass valve was removed and replaced with a straight piece. The good news is that this makes the whole build a lot cheaper and less complicated than before. Jelke did mention that I should make the intake pipes as short as possible so running the phantoms straight into the throttle body rather than around the front grill and back over would be best. But I've switched up this set up on Steve so many times I wouldn't want to make him work more again lol. Maybe next year once it's time for a retune I'll switch it up. But for now it's gonna stay how it is in the picture. So here is the list and prices in the end if anyone else decides to try this they can do it with either a second phantom or torqamp. The build would ultimately be the same but I feel with the torqamp the results would be much better.
Ebay purchase
- intercooler pipes $80
- 45° 2"-2.5" coupler $12.99
- 90° 2"-3" coupler $13.99
- 45° 2.5" coupler $12.99
- 2.5 intake filter $12.99
- crank case breather $4.99
- turbo wastegate mount $30
- 3.0 mas airflow housing $69.99
Amazon purchases
- 22 awg wire $13.97
- 2 awg battery cable 20ft $78.60 (not needed with torqamp kit)
- 8 awg cable 15.79
Home depot
- sheet metal 22G 12x18 8.98
- x24 pipe clamps 48$
- batteries $228 (not needed with torqamp kit)
- delicious tuning oft flex kit $595
- Steve99 custom tune $200
Total price
Twin phantoms $2940 ( this is estimated with a phantom price of 1500$)
Phantom+torqamp set up $3618 ( this does not include shipping price of the torqamp.
Anyways I hope you guys really enjoyed reading about this as much as I've enjoyed building it. I will say this its so much fun running g37s and Z boys. Hopefully soon I can get you guys an actual dyno run print. Cheers!
Sent from my IN2017 using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Old 09-22-2020, 02:33 AM   #10964
BlOody_BoOger
Originally Posted by WNDSRFR View Post
Have you checked these wires?
They're under the loom from the motor. Mine corroded before and caused me problems.
I spliced mine and used these small copper clamps that they sell at home depot I crimped them down and then used heat shrink and electrical tape to insulate the splices.
Old 09-22-2020, 02:38 AM   #10965
BlOody_BoOger
Originally Posted by Aztec View Post
Btw man I'm in the same boat as you. The controller isn't giving the signal the SC any longer, doesn't activate at all. I bet it's a fairly easy fix but it's not easy at all to take apart the multi-layered circuit boards inside the controller to figure out what's not working in it. My fuse inside is good as well, getting a good voltage from the batteries and everything.
I would pay to have it repaired ������
@BlOody_BoOger
Could I ship you my controller and you swap it into your setup to see if it works for you? I'm curious if it's something else in my setup
It would just have to be the same connections because some of the phantoms came with an extra wire or so. Send me a pic of the connection part and I'll compare with the ones I have it its a match we'll try it.
Old 09-22-2020, 02:52 PM   #10966
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
Sure thing, i'll send you some pics. At this point for me the system is useless if the controller can't send the electricity to the impeller.
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 09-22-2020, 03:04 PM   #10967
86TOYO2k17
Drives: 2017 toyota 86
@BlOody_BoOger get a dragy and get some times.
Old 09-22-2020, 03:05 PM   #10968
BlOody_BoOger
Could just be the switch itself
Old 09-22-2020, 03:27 PM   #10969
Aztec
Aztec's Avatar
Naw, I was using the procede controller and the voltage was going down to 26v like it was trying to send it, then briefly spiked to 30v as it failed to send.
All of that said, I didn't try recently with the pedal switch.
If the controller is similar to what you have i'm very curious what is causing the issue
NEW CAR!🚨🏎️⛽
Old 09-22-2020, 04:00 PM   #10970
BlOody_BoOger
I just gotta be careful how I launch cuz 7psi at 2500rpm in 1st gear could go boom
Old 09-22-2020, 04:02 PM   #10971
BlOody_BoOger
Im lot using the procede so I'll try it just like that with the pedal switch if that works then it could be the procede.
Old 09-22-2020, 04:37 PM   #10972
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
what about me? can you fix mine too?
he and i have same situation. difference is i use pedal switch not procede
switch can be burned too? because i found same exact switch online but i dont know about electrical stuff so i didn't order it yet.
voltage reading battery correctly just it does not engage it.
all my connections are clean
Old 09-22-2020, 04:38 PM   #10973
BlOody_BoOger
U can send me yours too and I can test it with mine and see if anything but same thing take pics of the connections just to make sure it's the same
Old 09-22-2020, 04:45 PM   #10974
zc06_kisstherain
Drives: SWP BRZ
Thanks, i will pictures of my controller tonight. is there anything else that you want me take pictures of?
Old 09-22-2020, 04:53 PM   #10975
BlOody_BoOger
No just the connection on the controller to the voltmeter. The problem could bro. The switch or the voltmeter housing. There may be a connection issue from the voltmeter to the switch since the voltmeter reads fine
Old 09-22-2020, 09:40 PM   #10976
zc06_kisstherain
Drives: SWP BRZ
I just snapped all pictures
https://photos.app.goo.gl/nNBPa3aGg1CsDiXx6
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
