#99 |
Drives: 2017 WR BLUE BRZ
Been looking at pulley systems and it looks like most of the companies have customizable kits that come with waterpump, alternator and a/c compressor...most are between 2-3k.
Here's one. http://www.eddiemotorsports.com/prod...chevy-less-ps/ Also thinking about supercharging...would probably require a different set up altogether Hopefully Vorshlag offers up something a bit less costly. |
#100 |
Drives: 2013 Ultramarine FR-S
I believe this dirty dingo set-up will work. Most likely requiring the wiring harness to be modified though.
Driver Side Pulley Bracket ![]() Low Mount Alternator Driver Side ![]() Low Mount Mini-A/C Bracket
#101 |
Looks like that would be a two belt set up...kind of like the gen III truck style.
#102 | |
#103 |
Drives: RX-7 / BRZ
So I'm guessing no 4x4 mode this winter... :O
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#104 |
Señor Member
Drives: 2013 Raven, Drifty things
Any updates @DustinS ?
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris '13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross. |
#105 | |
I was told 2 weeks on the transmission, but seems as though those that have ordered have waited around 2 months to finally receive it. Hoping that was just an early ordering ordeal. It is still a special order item at this point though. I can't order Crank/waterpump until I know what accessories/accessory mounts I can/need to run. Which is all waiting on Vorshlag (along with clutch master cylinder, engine/trans mounts, headers, driveshaft). I have a feeling the LS3 stuff I had chosen will work, but the 2010-2015 Camaro it is based on uses the truck spacing and sticks quite far out from the block (from what I can find). Which makes custom brackets a must at least for the low mount alternator to keep things as close as possible using corvette parts. I am also waiting on MRS to feel comfortable selling the final-ish revision of their CAN translator. Edit: I sent an email to Dirty Dingo asking about the Low mount mini a/c / alternator mounts. Making sure they fit the 2010-2015 Camaro Crank Pulley.
#106 |
After staring at the Vorshlag Posts and doing some searching. I do believe they are using CTS-V accessories with the LS3 Water Pump. Running a pulley on the lower CTS-V Alternator bracket using some washers/custom spacer and a custom bolt.
CTS-V Accessories from an LS Swap Miata: ![]() (Not LS3 Water Pump, but note how the belt sits at the very back of the pulley) ![]() Vorshlag: ![]() ![]() Custom Spacer: ![]() The Crank Pulley is a Cadillac Crank Pulley and the water pump is a LS3 pump.
#107 | |
Drives: 2001 Impreza 2.5 RS
Also got some more scan tool stuff working today so I should be able to finalize the rest of the code before long.
Colin Beck
#108 |
...Just add nauseum
Drives: 2003 (AP1) S2000
The C7 corvette accessory drive is simpler, easier, and works much better than anything else.
The C7 LT1 water pump fits the LS blocks, and puts the water necks in a better place for the FRS. Shown here. Only concern is alternator height, and whether it fouls with the fuse box on the side...
There are many ways to displace.
-Spartarus |
#109 |
Drives: 2015 frs
Good info I was wondering about a LT water pump on a ls. I was thinking that pump, and custom low mount compressor and alternator bracket. Or a LT motor instead of a LS. Haven't ordered a engine yet so I may look it to the LT if it will mount to my transmission.
#110 | |
...Just add nauseum
The LT motor will bring you only disappointment.
-Spartarus |
#111 | |
#112 |
Drives: 2015 frs
Your correct but if you ran a LT water pump it gives you more room on the front of the engine if you could find a single belt crank pulley that matches the spacing of the LT pump you would gain even more room.
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| Ls or 2jz swap? | sgoldberg01 | BRZ First-Gen (2012+) — General Topics | 13 | 03-22-2016 04:07 PM |
| Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-22-2015 12:38 AM |
| AT-->MT swap | AlwaysSideways | Want-To-Buy Requests | 3 | 12-15-2014 12:14 PM |
| Should I swap? | michaelahess | BRZ First-Gen (2012+) — General Topics | 8 | 06-12-2012 08:32 PM |
