| Member's Car Journals Car journals by our members. |
#99 |
Drives: 2016 Asphalt FR-S
How has that intake ducting worked out for you? it looks SWEET. I'm stacking a sprintex radiator plus maybe an oil cooler as well in the near future. Wondering if I should pull the trigger on that
#100 | |
The intake ducting is fantastic. Most folks use it as a base, and trim as needed to clear their water pump hoses, oil cooler lines, etc. |
#101 |
Your presence on this forum is amazing. BTW, I ordered this directly from the manufacturer. Do you have this in stock / can ship it out quickly? I'm working with Zach on the Sprintex E85 70mm pulley tune currently as well, so would be cool if I can just get the build done and over with as I'm doing some work on the car
#102 | |
#103 |
#104 | |
Pick the one that's right for you. If you're not sure, go with stock impact beam stock radiator (0001). If you have a large radiator, with stock impact beam get 0003. |
#105 | |
Sent from my Pixel 5 using Tapatalk |
| NA RECORD 221whp bolt on naturally aspirated 2 | WhiteFRS69 | Off-Topic Lounge [WARNING: NO POLITICS] | 53 | 11-25-2015 08:19 AM |
| 200+ WHP Naturally Aspirated on 91 Octane | DeliciousTuning | Software Tuning | 62 | 02-10-2015 09:34 PM |
| Naturally Aspirated - Backpressure | phenom86 | Engine, Exhaust, Transmission | 16 | 03-19-2014 01:07 AM |
| Naturally aspirated and 87 octane... | zooki | Engine, Exhaust, Transmission | 46 | 09-11-2013 12:25 PM |
| Who is happy the engine will be Naturally Aspirated? | Ryephile | Engine, Exhaust, Transmission | 491 | 05-02-2012 11:10 PM |
