Old 01-14-2015, 02:25 AM   #99
HotLavaChick
HotLavaChick's Avatar
Drives: '15 Hot Lava FRS
Originally Posted by Beebe View Post
Really? Lol, you obviously don't know what you're talking about.
The brightening mod is for the boomerang LED's, which are diffused through the acrylic "boomerang" within the headlight. Once modded, these are no brighter than the DRL's on the bumper.
Individuals that don't know how to properly use High beams is what blinds people.
you obviously are on your period a sensitive hmmm?
HotLavaChick is offline   Reply With Quote
Old 01-14-2015, 02:28 AM   #100
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
DIY - BRZ Boomerangs - Brighter, Better
Nope. They don't directly shine out. Diffused by the acrylic tube. We've opened up over 8 pairs for Houston 86. They are bright but doesn't throw glare out like improper hid setups.
I'd be more concerned with jacked up f150s with hids in their halogen housings while lifted
#TrackDayBro
Kuri is offline   Reply With Quote
Old 01-14-2015, 02:32 AM   #101
HotLavaChick
those photos are deceiving. they look super bright. i'm jealous i don't have them with this FRS .
Old 01-14-2015, 02:33 AM   #102
Kuri
Kuri's Avatar
It's really hard to capture them on photo. It's definitely something you have to see in person
Me and Beebe were the first ones to do it in Houston. We've learned not to look directly at the smd while testing
#TrackDayBro
Old 01-14-2015, 02:37 AM   #103
Beebe
Beebe's Avatar
Drives: Totalled 2/7/15 :'(
Beebe is offline   Reply With Quote
Old 04-15-2015, 11:14 PM   #104
Mikebrz
Drives: 2014 Subaru BRZ
Is this still a thing? I'd really like this on my brz.
Mikebrz is offline   Reply With Quote
Old 04-27-2015, 03:53 PM   #105
I like the tuna here
Drives: Subaru BRZ
This would help a lot to the noobs out there if there was a YouTube diy video. I was also wondering If anyone had condensation problems after baking and pulling it apart and sealing it again does it always seal air tight?
I like the tuna here is offline   Reply With Quote
Old 04-27-2015, 04:07 PM   #106
Beebe
Beebe's Avatar
A video would be difficult due to all the steps required. This DIY is as on point as you can get. If you're skeptical, don't do it.
Furthermore, I have opened up my fair share of BRZ & FRS headlights (35+ pairs and counting), and not a single one of them has had condensation issues after re-assembly. Also, let me note that I didn't have to add additional sealant either, since they already have plenty supplied from the factory.
PS- I just did another one of these installs on a local BRZ within 4hrs a few weeks back. So all in all, if you have the right TOOLS you can get this done easily in a day.
Beebs
Old 04-27-2015, 04:09 PM   #107
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
...This DIY is as on point as you can get. If you're skeptical, don't do it.
Furthermore, I have opened up my fair share of BRZ & FRS headlights (35+ pairs and counting)...
Beebs
That makes this man far more of an authority on headlights than I.
Good to hear Beebs.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 04-27-2015, 04:13 PM   #108
Beebe
Beebe's Avatar
Good to hear Beebs.
Stop making me blush @Acree, if it wasn't for your excellent initial write-up, I highly doubt this would be as popular of a mod as it's become. Thanks again man!
Beebs
Old 05-14-2015, 08:44 AM   #109
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
I just did a buddies. My second set now. Total time was about 3 hours. And that was with me letting the epoxy for the heat sinks to set for an hour before reassembling. Its actually really easy and fast to mod. Takes longer and harder to bake the lights and disassemble/reassemble than the solder work.
One trick I used was yo use a dremel with a small grinding tool for the traces. That allowed me to cut the necessary traces in 5 secs vs before I used a exacto and scraped/scored them which took a few minutes.
Next time I do a set I will take some better pics of the board cutting, as the pics here are not very good and hard to understand where to cut.
Biggest advice here I would say is to take your time, and use a meter to double check the connections and board cuts to ensure proper trace cutting.
gdrider77 is offline   Reply With Quote
Old 05-14-2015, 09:58 PM   #110
Unappreciated
Drives: 2014 WRB BRZ
i have a spare boomerang if anyone wanna buy it and then send it to Andrew to do the mod for a fee and all you have to do is swap it out like i did! PM me if interested
Unappreciated is offline   Reply With Quote
Old 05-29-2015, 03:49 PM   #111
SoonerCory
Alright, I FINALLY decided to do this but I have one question. In step 5, where you score the traces, on the drivers side the image shows only 1 trace being cut (red line) next to the blue wire. The passenger side image shows 2 cuts, the one next to the blue wire and one on the other side of the LED near the mounting hole.
These are two identical, separate circuits (no connection between them). Why the difference in the number of traces cut?
SoonerCory is offline   Reply With Quote
Old 05-29-2015, 04:01 PM   #112
Acree
Acree's Avatar
Because the board layouts are not identical.
brighter fog light bulb for BRZ? chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 17 01-11-2016 02:57 AM
Interior LED Dome Light Diffuser | DIY | 6X Brighter Dezoris Cosmetic Modification (Interior/Exterior/Lighting) 8 04-21-2013 09:59 PM
Brighter "Boomerangs" Jaylyons1 Mid-Atlantic 3 02-05-2013 08:53 PM
