Old 05-20-2014, 08:48 PM   #1107
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by glamcem View Post
Why do I need one?
Because you'll be pushing 8psi into your crank case. And if you put it before your catch can you'll be boosting that too.
post_break is offline   Reply With Quote
Old 05-20-2014, 08:56 PM   #1108
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I suppose this doesn't effect vented catch cans?
Freeman is offline   Reply With Quote
Old 05-20-2014, 10:38 PM   #1109
TmP
TmP's Avatar
Drives: A bunch of 'em...
Noooooooooooooooooooooooooooooooooooooo...
Kit won't come in time for the weekend.
Another week of NA queerness. Meh.
Oh well, more time to read up on what else I need that doesn't come with the kit I guess...
TmP is offline   Reply With Quote
Old 05-20-2014, 10:47 PM   #1110
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
Crap that means I won't get mine either, did they sent you a tracking number?
Sent from my SGH-M919 using Tapatalk
Taino-BRZ is offline   Reply With Quote
Old 05-20-2014, 11:13 PM   #1111
TmP
TmP's Avatar
Yeah, got a tracking number.
Estimated delivery is Tuesday next week.
I'm gonna check back tomorrow morning to see if it changed, but I doubt it.
Old 05-20-2014, 11:24 PM   #1112
Taino-BRZ
Taino-BRZ's Avatar
I ordered mine today but they haven't send me a tracking yet.
Old 05-20-2014, 11:28 PM   #1113
TmP
TmP's Avatar
Well, both our kits are going to TX, so if you get yours I'm gonna kill someone. LOL
Old 05-21-2014, 01:39 AM   #1114
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Do you think it becomes necessary after a catch can install? and why 8psi of boost? tuned KW kit typically makes 10-11 psi of boost IIRC
Can anyone from @KraftWerks chime in and explain ?
glamcem is offline   Reply With Quote
Old 05-21-2014, 01:41 AM   #1115
glamcem
glamcem's Avatar
Originally Posted by vgi View Post
heh, it doesn't come with MAP sensor either. JR kit does come with check valve, a metal one too.
yes but a check valve shouldn't cost anything and I am not sure how it can be overlooked if it may cause an issue
Old 05-21-2014, 01:48 AM   #1116
glamcem
glamcem's Avatar
for those who want to put clamps on the hoses, don't forget the third one under the intake manifold after I saw this post I noticed I forgot to add a clamp on the hose that right behind the throttle body.. that one should be a lot easier to reach since it doesn't require you to remove the AC compressor though
http://www.ft86club.com/forums/showp...21&postcount=3
Old 05-21-2014, 02:06 AM   #1117
gmsii
gmsii's Avatar
Originally Posted by protpibe View Post
Thanks for the info. I'm finding out for someone else so I wasn't 100% motivated to go digging. My interpretation was that the "Tuned" kit was +$600 or so but included the license and cable. The person looking at the kit already has a license and cable but would just require the tune file.
I'll just dig through the thread and see what comes up
if you have a KW kit and a ecutek cable already i believe the tune is available for a nominal charge...i'm not in sales so you should call KW customer service and speak with Joe or CJ...951-808-9888
gmsii is offline   Reply With Quote
Old 05-21-2014, 03:28 AM   #1118
glamcem
glamcem's Avatar
I was trying to get an answer regarding the check valve, can you please advise?
Old 05-21-2014, 03:35 AM   #1119
glamcem
glamcem's Avatar
@gmsii @KraftWerks this is the valve we are referring to
Old 05-21-2014, 04:08 AM   #1120
sw20kosh
Drives: 2013 Black FR-S
It's simple. Regardless of what comes in a kit you do not want positive pressure going into either the pcv system (it can leak) or the crank case (via the crank breather hose). If you have catch cans installed into these 2 breather systems, you don't want positive pressure going into the cans either. Put check valves in hoses to keep the positive pressure contained to the intake manifold/ic piping. They are cheap.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
