#1107 |
Drives: 2013 satin white brz limited
I ran into this same issue. Not looking for them to be so much necessarily supplied but at least have a disclaimer that you will need extra hardware. Luckily I had some.
#1108 | |
Drives: between cars...
#1109 |
Drives: '17 BRZ PP
#1110 |
#1111 |
Drives: '17 BRZ PP
I wish, I'd like to know myself. Unfortunately, that would have been inconvenient to accomplish and more costly.
#1112 | |
Drives: '14 981CS, '99 NB1
We're getting @tony-brz's ACE'd 2017 and my Harrop SC'd 2017 tuned same day. |
#1113 | |
I'm looking forward to seeing your results... @tony-brz are you gonna use ecutek? |
#1114 | |
Drives: Subaru BRZ / Toyota 86 Experts
#1115 |
The true gains of the header are not realized until you have a proper tune. The header requires some unique calibration settings.
#1116 | |
The proven CSG x DT Ace tune is what I would recommend; it has hundreds of hours of development in it, and continues to evolve as drivers continue to send in logs of their track time. |
#1117 | |
Drives: '17 BRZ PP
#1118 | |
To be clear, there are plenty of dyno shops within a 10-15 drive from either Tony or I, but a baseline dyno is meaningless if you don't intend to also tune the car on that dyno... Different physical dynos do not match shop to shop, even if they are the same brand. |
#1119 | |
True But i think hes asking for gains of your header and tune over stock 2017. Be interesting to see given the 2017 manual has a better\ different stock tune and better header than the previous cars. It may result in less gain with tunes and header than the 2012-2016 cars ? |
#1120 | |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 11:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 06:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 09:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 05:12 PM |
| Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 11:34 PM |
