Old 04-26-2017, 07:27 PM   #1177
Bobster
Drives: GT86 GTS
Originally Posted by AceHeader-MT View Post
Talk to your local tuner and they'll tell you why this is good for everything. If they can't, you need a new tuner
Better yet just contact @DeliciousTuning for their Ace v6.8+ tune and feel for yourself.
Besides the ridiculously cooler intake temps, we no longer need an oil cooler as oil and water doesn't get above 110*C. This is not recommended, but that was a main design requirement.
For a $200 part, we're not going to spend thousands for dyno time.
This item would compliment the OEM WRX oil cooler quite well then?
I am thinking about going with the Delicious Tuning flex kit actually
Bobster is offline   Reply With Quote
Old 05-29-2017, 12:29 AM   #1178
Bobster
Drives: GT86 GTS
Has anyone gone to a larger throttle body with the stock air box on ace headers?
I a thinking about getting the Grams 72mm TB
Old 05-29-2017, 10:17 AM   #1179
Reamer
Drives: 2015 FRS
If you're not running turbo/supercharger I don't think it'll do anything for you. The engine can only take in so much air unless you're cramming more air into it.
Sent from my Pixel using Tapatalk
Reamer is offline   Reply With Quote
Old 05-29-2017, 07:59 PM   #1180
Bobster
Drives: GT86 GTS
I have a greddy scoop that is effectively a ram air scoop
Old 05-29-2017, 09:38 PM   #1181
Hawk77FT
Drives: GTS 86
Not really! Greedy scoop is ramming cold air in the air box where the filter is NOT the intake manifold. At best you have a slightly pressurized air box so to be considered a ram air you will either have to travel with 200+ km/h (not even then because you will have to pass the filter and the angle in the intake pipe) or go straight pipe into to the throttle body. Even then, to get the benefits of it, will need a high speed to get the air ram/air pressure charge effect into the intake manifold. Depending on the design though. My 2 cents.
Hope this helps.
Hawk77FT is offline   Reply With Quote
Old 05-29-2017, 09:56 PM   #1182
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
It is better to optimize current setup including powertrain and suspension setup to improve efficiency.
CounterSpace Garage is offline   Reply With Quote
Old 06-07-2017, 11:33 PM   #1183
Cybmx
Drives: 2016 Hyperblue Brz
Finally got my Ace 4-2-1 a350 installed with a delicious tune. With a drop-in filter and stock everything else, car gained 8 peak hp. The torque dip is gone, but I would be lying if I say I wasn't hoping for more.
Cybmx is offline   Reply With Quote
Old 06-07-2017, 11:44 PM   #1184
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Something doesn't sound right about this.
Please send us or CSG an email and we'll see if we can figure this out.
AceHeader-MT is offline   Reply With Quote
Old 06-08-2017, 10:46 AM   #1185
steve99
Was that compared to stock tune/header or did you already have tune/header from different vendor ??
Old 06-08-2017, 01:20 PM   #1186
Cybmx
It was compared to everything stock. Stock dynoed 162, with drop-in filter, ace header and delicious tune, it made 170. The shop I'm working with is waiting to hear back from Delicious.
Old 06-08-2017, 01:59 PM   #1187
steve99
ok thanks, seems strange sure they will sort it out.
Old 06-08-2017, 02:23 PM   #1188
jasonojordan
Drives: 2013 satin white brz limited
Ill be the one to ask the stupid but obvious question. Was the car run before and after on the same dyno? Was it in the same day or week month year?
The numbers either way do seem very low considering either way.
jasonojordan is offline   Reply With Quote
Old 06-08-2017, 02:50 PM   #1189
Cybmx
Same day, same dyno. First run around 8am, then installed the header/tune, and dynoed again in the afternoon.
Old 06-08-2017, 03:10 PM   #1190
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Dang, I'd be extremely upset about that one. That's a difference of a dyno strap being done differently between runs, and definitely not worth the money invested.
I'm sure something is off, hopefully you figure it out!
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 06:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 09:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 11:34 PM
