Old 12-01-2014, 09:31 PM   #1191
gmsii
gmsii's Avatar
on the subject of upgrades...a certain little birdie said this....
“Yes, there are multiple C38 JRSC cars running around, and also multiple high boost cars. Every single one of these cars are heavily tracked cars.
It is only available by calling CSG or Jackson Racing directly. It is
not publicly available through every JR dealer because it is a highly
application specific product.
You *CANNOT* properly utilize a C38 unless you have a built engine. You need to be pushing more CFM and boost with a C38 than a C30 can at peak, to actually be getting any more flow or power with the C38. Anyone running a C38 at 12 psi or lower, quite frankly, is using the wrong supercharger.
The problem is, if you're running 12+ psi, you need to be running either race gas or E85. Most people will opt for E85. This means output will be north of 325 torque and 400 horsepower.
325 torque is where the stock transmission's failure point is, and you already need to have a clutch to even get to that torque level. Guess what fails? The trans. At this point, the cheapest aftermarket
transmission option is 18k.
The C38 JRSC has been around since day 1. It is not released because it is not the right product for 99% of the general public. JR is not in the business of selling the wrong product to people, and nor is CSG.
The price for the C38 and C30 are the same from Rotrex.
Next, the high boost pulley. This is also available, and has been from day 1. The reason the 110mm pulley was chosen for the stock kit, is that a LOT of tuners like to tune for higher redlines. For some reason, the general public thinks this is safe (it's not), so the pulley
was sized to max out the blower near 8000 RPM, so that the supercharger is less likely to be overspun by a third party tuner. The 100mm pulley takes the supercharger to max at about 7350 RPM. The 110mm pulley also happens to high the limitation of CA 91 right as you hit the stock redline.
Obviously, the other parts are not part of the CARB kit, and if you do
get a ref ticket, you'll need to have the stock pulley on (they measure
it), but you will pass with a CARB tune and cats on.
A pulley swap is a 10 minute job, at most.”
gmsii is offline   Reply With Quote
Old 12-01-2014, 10:35 PM   #1192
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
That is basically what we tell our customers. C38 superchargers really are not worth it unless you are on race fuel or E85.
Cheers,
William Knose
Old 12-01-2014, 10:38 PM   #1193
Why yes, yes I did say that.
Old 12-01-2014, 11:53 PM   #1194
enivid
enivid's Avatar
Drives: WRB JR BRZED
Can you run the C38 on 91 octane?
enivid is offline   Reply With Quote
Old 12-02-2014, 12:05 AM   #1195
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Cheers,
William Knose
I'm sure that doesn't stop some people from demanding a C38 for their 91oct street setup anyway.
Thanks for the info @gmsii
campy is offline   Reply With Quote
Old 12-02-2014, 01:58 AM   #1196
DeliciousTuning
Naturally, though they seem to quickly regret it and either go E85 full time or go back to the C30 blower, or sell the kit altogether in the case of these Kraftwerks kits. It's just not viable on 91.
Sincerely,
Zach
Old 12-02-2014, 10:49 AM   #1197
enivid
enivid's Avatar
How much extra hp to people typically get with the smaller pulley on the C30?
Old 12-02-2014, 12:22 PM   #1198
DeliciousTuning
Depending on the tune and quality of gas, anywhere from 15-20 would be my guess at peak. Keep in mind that a C30 on a smaller pulley gets questionable above 7000rpm, however; at least on 91 octane.
Sincerely,
Zach
Old 12-02-2014, 12:23 PM   #1199
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Sincerely,
Zach
How is it on 93 octane?
ScionOfHorus is offline   Reply With Quote
Old 12-02-2014, 12:36 PM   #1200
DeliciousTuning
93 octane tends to be leaps and bounds over 91, especially CA 91. I wouldn't foresee any issues running the smaller pulley on 93 octane.
Sincerely,
Zach
Old 12-02-2014, 12:37 PM   #1201
ScionOfHorus
Fuck yeah, states not California
Old 12-02-2014, 12:45 PM   #1202
CSG David
CSG David's Avatar
I want your gas. I want your oil. All your oil belong to us! jk
Old 12-02-2014, 12:51 PM   #1203
ScionOfHorus
Me being in Texas and all
Old 12-02-2014, 01:26 PM   #1204
fasteddy
Hey David, are the RaceRom features such as auto blip, map switching and advanced traction control included with the carb tune?
Thanks.
Pat
fasteddy is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
