Old 05-03-2017, 10:48 AM   #113
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
My car idles from 19-20 vacuum at idle. Hows the 2 barbs under the plastic cover on your intake? Do you got those pigs clamped?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 05-03-2017, 05:45 PM   #114
Kris86
Kris86's Avatar
Drives: RHD Gt86
so I assume I should be seeing around the same reading as you on my boost gauge?
yes we have all hoses secured with hose clamps
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 05-03-2017, 05:49 PM   #115
Kris86
Kris86's Avatar
Drives: RHD Gt86
i was told to make sure i have the one under the intake manifold and behind the aircon compressor secured properly.
thing is that hose runs to one of my radium catch cans and is vented to atmosphere
Old 05-03-2017, 07:52 PM   #116
Amputechture
Drives: 2014 BRZ
You're talking about the crankcase vent. He's talking about the EVAP purge shits;
http://www.ft86club.com/forums/showthread.php?t=109444
Amputechture is offline   Reply With Quote
Old 05-04-2017, 02:10 AM   #117
FRS Justin
Drives: 2013 Asphalt FRS
Hey Kris didn't you lower the compression?
for the EXACT same combination of parts...a higher compression motor draws harder on the intake, and thus has more vacuum.
the bigger the difference in compression...the bigger the difference in vacuum...
1-2 inches of vacuum per point seems realistic...
I would check fuel trims for signs of a vacuum leak not the gauge
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 05-04-2017, 07:35 AM   #118
Kris86
Kris86's Avatar
Drives: RHD Gt86
Hey Justin, thanks for the info !
This is what my tuner sent me letting me know I have a vacuum leak
"I can see that manifold absolute pressure is at .52 BAR and 18% short term fuel trims. Trims should be close to 0%, and manifold absolute pressure at unassisted idle should be .27-.35 or so with no vacuum leaks."
Old 05-04-2017, 08:27 AM   #119
GsxrMe
GsxrMe's Avatar
You beat me to it. I thought of this yesterday while working on the jeep. He changed his comp so 14-15 sounds about right.
I know your looking at fuel trims but hows the MAF? Is it solid readings when at idle or is it all over the place?
2014 Subaru BRZ
Old 05-04-2017, 12:18 PM   #120
FRS Justin
The only thing I can think of left would be the orings on the bottom of the intake flange, that bolts to the heads.
710whp
Old 05-04-2017, 12:29 PM   #121
Kris86
Kris86's Avatar
Drives: RHD Gt86
so I was just checking my logs
when I turn the ignition and engine speed at "0" rpms. my MAF reads 0.76 volts.
once started and idling on its own it jumps between 1.3 V - 1.4 V
the g/s for the MAF jumps between 2.9 g/s - 4.3g/s
( don't know what the hell all that is supposed to mean but hoping you guys will see something unusual
@GsxrMe
Old 05-04-2017, 12:37 PM   #122
Kris86
Kris86's Avatar
Drives: RHD Gt86
had to take my oil pan off to get the turbo feed re welded
the issues with living on a island in the Caribbean, u cant even get a proper weld done.
so tomorrow when the oil pan is back on im gonna be doing what u suggested with the carb cleaner and spraying the said areas
Old 05-04-2017, 01:31 PM   #123
GsxrMe
GsxrMe's Avatar
At hooters atm, once im home ill pull some logs to compare.
2014 Subaru BRZ
Old 05-04-2017, 01:46 PM   #124
FRS Justin
cool keep me posted
710whp
Old 05-05-2017, 10:28 AM   #125
Kris86
Kris86's Avatar
Drives: RHD Gt86
So we did the vacuum test with the fancy smoke machine last night, found out my turbo has a very small leaking through the front cover on one particular section, possibly the o-ring that seals the cover. This tho, I don't think will cause my issue at idle. No other leaks anywhere what so ever. USED THE VACUUM FROM THE BRAKE BOOSTER TO DO VACUUM TEST
My tuner sent me this
"your manifold absolute pressure at a stable idle should be between .28 and .36 at most. Yours was around .5 or higher, with correspondingly high fuel trims. This indicates a leak. "
Old 05-05-2017, 10:50 AM   #126
Kris86
Kris86's Avatar
Drives: RHD Gt86
The tuner also stated that if I do not find any vacuum leaks, then my motor isn't holding compression.
what I find weird is that the car has a wont idle once is cold, I have to keep my foot on the throttle to prevent it from stalling, but once it warms up, it idles perfectly, if I shut off the engine and start back when its hot I don't need to apply any throttle
my mechanic is saying that the piston rings need some more time to be seated and then my compression will go up.
whats you guy thoughts on this?
Who's tired of the "Pedal Dance" and wants to be in real control of their car? FT-86 SpeedFactory Tracking / Autocross / HPDE / Drifting 61 10-01-2015 08:44 PM
I drive fast because the car feel "slow" fang_gt86 Scion FR-S / Toyota 86 GT86 General Forum 65 05-04-2015 02:06 PM
Most effective ways to make a "fast" NA car Kronos Engine, Exhaust, Transmission 68 02-16-2014 02:59 PM
XSXV: Nissan R34 Skyline from "Fast and Furious" goat_cheese Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 29 10-25-2012 05:15 PM
come and hoon they say.... it will be "like Fast and the Furious", they say... davey90 AUSTRALIA 5 10-23-2012 01:11 AM
