#113 | |
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
No no, your math is correct. The point I was trying to make to you is that a 48mm offset on a 7" wheel and the same offset on a 7.5" wheel will not equal the same distance from hub mounting surface to edge of the wheel
#114 |
Drives: ZN6 / GDB-G
+44 will fill the gap better, with 50+ the wheel goes more inside, you can do +33 with no issues
#115 |
Drives: 07 scion tc 06 Evo 9 mr 10 4runner
Will a 18x9 +42mm offset. With a 245/35 tire rub at full lock with a 1inch drop???
I plan on puttin spacers to make them flush. Also add some camber. |
#116 |
It's actually 18x9 +35mm offset not 42mm
#117 |
Drives: '13 BRZ Ltd WRB
You should be fine. Mine are 17x9 +28. They stick out like a bitch in front, but no rubbing on turns or anything. I'm not dropped, but if anything you'd want camber bolts up front.
With +35, I don't think you'll need spacers. |
#118 |
Get a Bowl
Drives: 2017 BRZ PP
Will 17x8 ±53 with 225 45 r17s fit up front?
Sent from my SCH-I535 using Tapatalk 2 |
#119 |
VehicleDynamicsSpecialist
Drives: iG FR-S
Wouldn't be my choice. May rub the strut up front.
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
#120 |
Get a Bowl
Drives: 2017 BRZ PP
#121 | |
Drives: iG FR-S
Ah, gotcha. Yeah spacer (25mm) would work. Don't buy junk though. ![]() It *may* fit without. But you're getting real close to the strut before mounting the tire..
#122 |
Drives: Whiteout FR-S
I would say 15mm to make it plus 38 on the front, 15mm is probably the widest spacer I'd feel comfortable with.
#123 |
Get a Bowl
Drives: 2017 BRZ PP
#124 |
All 4 maybe even a bigger one in the rear
#125 |
Get a Bowl
Drives: 2017 BRZ PP
#126 | |
Drives: iG FR-S
Whether or not he wants 10, 15, 20 or 25mm is irrelevant to me. He must choose his own spec. 10mm is hardly going to make or break it, as long as he moves the wheel away from the strut. ![]() That said- I would only recommend ones that come with their own pressed studs. Some people call these wheel adapters even though the p.c.d. doesnt necessarily have to change. In addition to the studs, "wheel adapters" will be hub or lug centric. They can also be both hub and lug centric if designed for a specific wheel. This reduces any chance of vibration. I woud not run a "spacer" (plate, no studs) thicker than 8mm without replacing with longer studs. |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
