Old 12-14-2014, 11:34 AM   #1261
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
It's because you have a 2015. Contact @Jacksonracing and just let them know. Your vendor is supposed to ask you what year and transmission your car is
Once you have the right tune, you'll be good to go. EcuTek won't let you flash a mismatched tune onto your ECU; every tune is specific to your EcuTek license and ECU.
Alright, it's because I bought the kit used, so I didn't get it specific to the 2015. Thanks, Mike.
ScionOfHorus is offline   Reply With Quote
Old 12-14-2014, 02:29 PM   #1262
enivid
enivid's Avatar
Drives: WRB JR BRZED
Originally Posted by CSG David View Post
It exists but only for those who are serious.
How much hp increase does it provide?
enivid is offline   Reply With Quote
Old 12-14-2014, 05:28 PM   #1263
Originally Posted by JerseyMike View Post
CSG can I get more info on the smaller pulley? How much psi and does it kick in sooner? I use 93 octane. I'm very interested!
It increases the slope of the boost curve, and gives approximately a 10% increase absolute. Depending on conditions and your other supporting, you will generally see a 2-4 psi increase.
Even with 93 octane, you will be pushing the bleeding edge of knock threshold. E85 or 100 octane is highly recommended to reduce cylinder pressures and potential for knock.
We're not sure, since we never tested the pulley by itself only, only with supporting mods (Tomei header, joint pipe, front pipe). Compared to customer cars with the exact same supporting mods, but without the smaller pulley, there was a 25hp difference. This is with the same tuner, same dyno, and both on stock injectors and pump. However, the smaller pulley WILL NOT be able to redline on 91 octane; you'll need to cut the redline short. The 25hp difference was with 93.25 octane on the CSG car, vs 91 octane on the customer cars. The hp gap increases as fuel quality increases.
Old 12-14-2014, 06:06 PM   #1264
Calum
That Guy
Drives: 2013 asphalt FRS MT
If there an intermediate pulley?
Old 12-14-2014, 06:07 PM   #1265
enivid
enivid's Avatar
So you are recommending a full tank of 100 octane while on the track?
Old 12-14-2014, 06:42 PM   #1266
enivid
enivid's Avatar
Our belief is that e-tuning is not as good as an actual tune on a dyno. You can see/hear/smell/feel things on a dyno that a log does not show.
How aggressive is the tune you run? Did you dial it back 10-20 hp for the track or is it to the max?
Old 12-14-2014, 06:58 PM   #1267
We recommend at least a mix of 100, even for guys with completely stock engines.
The numbers are from a track tune, not a dyno queen. I'd imagine we can squeeze out quite a bit more if we wanted to see how high we could push the number without blowing up the engine. Tunes were performed with a fully heat soaked engine, not a fully cooled engine with a few minutes in between each pull. This isn't how most people will do it, but this is what we need, and is how we have it done.
Old 12-14-2014, 07:17 PM   #1268
FirestormFRS
By the way anyone that hasn't checked out crazy sideways Mikes Youtube videos you should!
Mike how are the Tomei products?
FirestormFRS is offline   Reply With Quote
Old 12-15-2014, 02:22 PM   #1269
Solid! Our Tomei stuff has been being abused for a while now without issue or any leaks.
Old 12-15-2014, 09:35 PM   #1270
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
I second that. My setup has been solid.
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 12-15-2014, 11:23 PM   #1271
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
link?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 12-15-2014, 11:25 PM   #1272
Originally Posted by Boofneenee View Post
link?
Our first test with the JRSC back in Dec 2013...
[ame="https://www.youtube.com/watch?v=-r7EgQGxA4g"]Jackson Racing Supercharged BRZ Track Shakedown - YouTube[/ame]
Tomei?
http://counterspacegarage.com/tomei-...-frs-gt86.html
Youtube? This is my (poor) attempt at pretending I'm a drifter.
[ame="https://www.youtube.com/watch?v=3FkCXleL8MI"]Subaru BRZ Drift at Streets of Willow Springs - YouTube[/ame]
Some chase action
[ame="https://www.youtube.com/watch?v=VWcYdp0rqww"]Following Counter Space Garage's Turbo BRZ at Super Lap Battle - YouTube[/ame]
Some in-car action with a GT3, GT3 CUP, and a Boss 302
[ame="https://www.youtube.com/watch?v=HCWz5ymLKrI"]Scion FRS vs Porsche GT3 86Fest II - YouTube[/ame]
Old 12-18-2014, 10:54 AM   #1273
enivid
enivid's Avatar
So what about the upgraded blower? When our engines blow and we upgrade to something stronger, is there upgradeable parts to use the bigger blower?
Old 12-18-2014, 06:37 PM   #1274
The better question is, why would your engine fail with the CARB tune?
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
