#1289 | |
Senior Addict
Drives: 86 GT
He also suggested welding a v-band on it and fab a custom stainless pipe to the airbox. But I think that's gonna be quite pricey and too much trouble. |
#1290 |
Drives: None
Where is your vacuum at when idling. Mine use to range in 19, and now it's around 20. Could it be Because of the bypass valve I installed
Also, what afr is everyone seeing in wot and about 70-80% throttle? Last edited by Astroboy; 11-18-2014 at 09:17 PM. |
#1291 | |
Senior Addict
Drives: 86 GT
So basically someone's AFR reading using a proper wideband may differ from yours if you're on a stock sensor....and any comparisons would have to be taken with a grain of salt. |
#1292 | |
Drives: None
AVO Turbo Kit Owners Topic
I've been using the android torque. My afr is 14.65-14.7 during idle. And during wot it is around the 12s so idk. Sent from my iPad using Tapatalk Last edited by Astroboy; 11-19-2014 at 02:57 AM. |
#1293 |
One issue I've had with the pipe from the airbox to the turbo is it is very picky about placement. I have the Perrin intake and it wants to push the pipe into the pulleys. I've got it pulled towards the front of the car with zip ties for the moment.
I would love to see an option or fab for metal piping instead of the silicon right there in the bay. Or at least a bead on the turbo to help keep that pipe on. Wonder how much that would cost to fab. |
#1294 | |
Drives: None
#1295 |
Senior Addict
Drives: 86 GT
Could someone please tell me the ID and OD for the turbo coolant hoses?
#1296 |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
#1297 |
uosɹǝdʎɐl ʇɹǝdxǝ
Drives: Asphalt AVO FR-S w/a Slushbox! :P
So what's your status? Are you still gathering "intelligence" or installing the parts?
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn |
#1298 | |
Senior Addict
Drives: 86 GT
Kit should arrive soon, but won't have time to install till mid December when I get some time off work. So at this stage I'm trying to gather as much intel on various install tips/tricks and just trying to learn from other peoples experiences. |
#1299 | |
uosɹǝdʎɐl ʇɹǝdxǝ
![]() I'm suspecting this flange to flange seam. I'm going to put the car in the air soon
#1300 |
Drives: dark grey metallic Toyota 86 MT
I got an AVO oil cooler
![]() ![]() I've had the AVO stage 1 for a year with oil temp up to 240F and water temp up to 200F. After the oil cooler, oil temp up to 200 and water temp up to 195. I got the anti tramp differential bushing. Power seems to be more instantaneous. Guess it works and it was easy to install. ![]()
#1301 | |
Senior Addict
Drives: 86 GT
You might want to try squirting some soapy water (dishwashing liquid works best) onto the flanges and see if they bubble. |
#1302 | |
LIke someone else suggested, spray some soapy water on the flange seam. Make sure you do it when the car is cold, and have someone assist you because you won't have much time. Once it's hot/warm, it will just evaporate.
| Tags |
| avo, avoturboworld |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 11:58 PM |
| FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 01:36 PM |
| OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 05:26 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
